Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 02-05-2002, 11:50 AM   #1
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
Default Tire Fitment Calculator
NOTE: YOU WILL NEED WINZIP TO UNPACK THIS FILE, AND MS EXCEL TO LOOK AT THIS FILE.
A friend of mine found this the other day. It is a spreadsheet that calculates every aspect of change that can occur from a tire and/or wheel change on a car. Like ride height, speedometer changes, offset, etc... Everything is computed on the fly, as you change the values at the top. I zipped it so I could attach it to this forum post. The original file is ~38KB and the zipped version is ~10KB. If anyone knows if I can attach the *.xls version (original), please let me know.
Have fun, also, let me know if you have questions about how to use this.
daytontp is offline   Reply With Quote
Old 02-05-2002, 05:51 PM   #2
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
I case you are curious, this is what you enter into the spreadsheet. You can set the Original and Proposed Fitments to what ever you want.
Original Tire Fitment:
Width, Aspect Ratio, Wheel Diameter & Offset
(i.e. 205, 55, 16 & 55MM)
Proposed Tire Fitment:
(i.e. 215, 45, 17 & 48MM)
And this is what the spreadsheet tells you:
1. +1 inch wheel potential fit.
2. +2 inch wheel potential fit.
3. +3 inch wheel potential fit.
4. Change in ride height.
5. Inward additional width required.
6. Outward additional width required.
7. Original tire height.
8. Proposed tire height.
9. Additional total tire height.
10. Additional vertical clearance required.
11. Additional rolling diameter.
12. Change in drive ratio.
13. Speedometer reading >> to >> actual speed.
14. Desired speed >> to >> speedometer reading required for this speed.
15. As well as a graph that shows what the proposed tire would look like in relation to the original tire. An outline with each tire on top of the other with the mounting surface as a reference point. Helps in seeing if you need a spacer or not.
Old 02-05-2002, 11:10 PM   #3
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
And for those of you out there who hate office, here is a Java version:
http://www.trunkmonkeyracing.com/v00.../tirecalc.html
Fear the Trunkmonkey. There is no cone.
Trunkmonkey World Headquarters | Trunkmonkey Racing
[email protected] | What is a Trunkmonkey?
Somebody set up us the WRX. All your rice are belong to us!
Sean is offline   Reply With Quote
Awesome tire size calculator with lots of info spt_impreza Brakes, Steering & Suspension 0 09-12-2002 01:43 AM
Need Tire conversion calculator. Dolphin Overton Brakes, Steering & Suspension 5 04-08-2002 06:27 PM
tire/wheel calculator question Ken Levin Brakes, Steering & Suspension 2 03-16-2002 10:43 PM
Attn: Autocrossers - Tire Pressure Calculator Opie Motorsports 10 04-04-2001 08:45 AM
Tire Size Calculator stever General Forum Archive 5 01-05-2001 07:22 AM
