Welcome to the North American Subaru Impreza Owners Club Wednesday August 12, 2020
Old 02-22-2008, 04:21 PM   #1
thumpetto007
Member#: 156358
2001 Miata LS
Gay Blue
Default My brand new Fumoto valve is leaking
I've had the fumoto valve on my car for about a week now, and noticed it leaks (almost positive) from the opening in which the lever moves around.
I called (whatever the company is called who makes/sells these) and he insisted that this was impossible, because the chamber that the lever is in does not connect with the valve chamber when closed. He said that I must have misdiagnosed where the leak was coming from or overtightened the valve. I read that some people have leakage issues with the fumoto valve and some don't.
Maybe I got a bad one? The guy on the phone said he would send me a new one... but couldn't understand the conditions in which he would do so. (a bit foreign...)
Any pointers? I really don't like the minor convinience during oil changes if the time in between, I'm dripping oil when the engine is warm.
Also, if/when I replace the fumoto valve with the stock oil drain plug, or even a different fumoto valve, how do I not drain most of the oil I just put in with my very very limited budget???? Should I just live with the slow drip? I'm assuming it will have an negative effect on the amount of oil eventually.
Help would be much appreciated.
thumpetto007 is offline   Reply With Quote
Old 02-22-2008, 06:40 PM   #2
mikeythejew
Member#: 141672
You will most likely make a mess hoping to keep most oil in the pan while hot swapping to another valve or drain plug. I imagine you put high buck synthetic in. You can use a small amount of thread sealer on a FEW threads to help prevent leaks like permatex # 56750
More then likely, you are the culprit of the leak, but I highly doubt Fumoto has never made a defective product, so who knows. You can overtighting and distort the gasket to cause a leak. You should not use the crush gasket with the Fumoto valve.
mikeythejew is offline   Reply With Quote
Old 02-22-2008, 06:46 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
take a picture of it leaking and send it to them, it is some thing that would be very hard for some one to install improperly. They will probably send you a new one if it is a manufactures defect and not some thing like being cross threaded. If it was cross threaded it would be evident on the threads when you pull it out.
Fumoto valves are really just a 1/4 turn ball valve that locks in place. There are only 2-3 seals in them to leak. However being in the environment they are in it doesn't take much dirt in the seal are to make them leak.
I would leave it in and just watch the oil level until the next oil change and then put a regular plug back in. using a wrench is not that tuff to remove/install a drain plug.
flstffxe is offline   Reply With Quote
Old 02-23-2008, 08:12 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you didnt add a crush ring or use anything other than the gasket included with the fumoto valve did you?
just a thought....
Jamie
Old 02-23-2008, 08:36 AM   #5
orndog
Member#: 34670
2016 slowmobile
When I had mine installed I notched the threaded end so that the notch faced the bottom of the pan and spaced it out with an extra gasket to get the best drain. Probably silly on my part, but it made me feel better and more importantly it never leaked. I prefer the old fashioned change though and went back to a plug.
To the OP, I'm not sure what your leak is, but remember that it is notoriously difficult to find the source of a fluid leak especially in turbulent conditions - such as the undercarriage of a moving car. Maybe you can open and close the valve once over a pan just to make sure the lever is seated well, dry it all off, and then watch for a fresh leak?
orndog is offline   Reply With Quote
Old 02-23-2008, 12:31 PM   #6
Arctic Penguin
Member#: 119532
2006 WRX
my valve leaked a bit when it was new
Arctic Penguin is offline   Reply With Quote
Old 03-03-2008, 10:17 PM   #7
flyst1
Member#: 172980
Hello all,
I have just purchase this hardware and its soon to be installed. The products looks tough!! Holding it in my hand I had many questions and doubts (i tend to be critical) which eventually lead to WHAT IF THIS VALVE MALFUNCTIONS?
The nightmare of the valve giving way somehow and leaving your engine oil for the poor drivers behind then your engine... o poor engine. The valve is distributed world wide so i doubt this to be reality for anyone? But better to be safe than sorry.
I am curious as to find out if anyone can confirm using the valve for many years without issues? Or if anyone has experienced this extravagant nightmare? - hope not
J
flyst1 is offline   Reply With Quote
Old 03-03-2008, 10:28 PM   #8
Arctic Penguin
Member#: 119532
2006 WRX
i saw a post with pics where a guy was autoxing and ran over a cone and it opened the valve ??? somehow
and dumped his oil
another guy hit a big turtle and bent the valve and pan and it leaked a bit at the pan
not the valve
Old 04-02-2008, 05:40 PM   #9
xreign
Member#: 123859
06 STI 330hp/357lb
hm.. yea i want some history excellent looking product and idea but how safe i'd kill someone if this stupid thing leaked somehow
xreign is offline   Reply With Quote
Old 04-03-2008, 02:36 PM   #10
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
Fumoto valves for almost 7 years here with nary a drop of leakage.
Captain Ned is offline   Reply With Quote
Old 04-03-2008, 06:08 PM   #11
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
i have been using mine for 5 years too. Not a drop on the floor.
lionken07 is offline   Reply With Quote
Old 04-05-2008, 08:25 PM   #12
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I'll bet it leaking from the pan not the valve, and that the oils i pooling in an area that makes it look like the valve part.
I had the same thing on mine when first installed, I gave it another 1/16 of a turn to tighten it.
No problems since.
moogoob is offline   Reply With Quote
Old 05-12-2008, 04:29 AM   #13
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
Been using mine for... probably 7 years now, no problems at all. The only issue I had was when I put on a skid plate and then plate was touching the valve which caused some marks on the plate, but some washers solved that problem. Other than that, not a drop. Just ordered 2 more for my other cars.
yuletak is offline   Reply With Quote
Old 05-13-2008, 10:43 AM   #14
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I had the same problem when I installed the aluminum Rally Armor skid plate. I just took a ball peen hammer and put a little "bowl" in the skid plate to clear the fumoto valve.
I don't think I would feel comfortable installing this valve without having some protection around it. Even though it has a "lift and turn" lever, its possible something could hit it, and it would open up.
As far as the leak, I would agree with a lot of other posters, I think its coming from the threaded connection to the oil pan.
coyote73176 is offline   Reply With Quote
Old 05-14-2008, 09:38 AM   #15
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
I want to run one on my car but I'd probably shear it off. Lowered car + no under panel = exposed valve = bad.
Old 05-14-2008, 04:15 PM   #16
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I have the Fumoto oil drain valve and have no problems.
I installed it using a Subaru crush washer and not the fiber one that was supplied.
I got the one with the nipple and so I use a vaccum cap to cover the nipple.
I also installed the Carbing underpanel, but since I have a 2006, I had to shim the rear Carbing bracket to make it work and so the Carbing underpanel is about 1/4" away from the end of the nipple.
It's always possible that the valve could have a leak.
But if you double stacked the washers to "notch" the placement of the lever, then this may be your problem.
Perhaps you should reinstall it using only one washer and see if this makes a difference?
Old 05-19-2008, 02:52 PM   #17
Craig A.
Member#: 122519
2005 LGT, 2018 BRZ
I use a zip tie on mine to make sure the lever will never lift up and turn. I have had it about 2 years and its great!
Craig A. is offline   Reply With Quote
Old 05-19-2008, 07:56 PM   #18
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
How did you set that up? Does the zip tie block where the lever moves up out of its little detent?
flyboymike is offline   Reply With Quote
Brand new 09 with water leaking problems. Please help darren94 Newbies & FAQs 2 11-20-2009 11:25 PM
Brand new updated radiator already leaking? Blue2002WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-17-2009 10:05 PM
Brand new Manley Valves +1mm over Blue06STI Engine/Power/Exhaust 13 02-25-2009 02:38 AM
Pa Brand New Iac Valve Cheap 2.5 99-01 on EBAY ENDING SOON veedubshafer Private 'For Sale' Classifieds 3 05-04-2006 08:04 PM
Brand new guaranteed not to leak tent... Kiwi Off-Topic 12 09-14-2005 04:17 PM
