03-05-2008, 03:43 PM | #1 |
Member#: 147812
Vehicle:1998 2.5RS Brilliant Red |
What are GC turbo guys using for hood scoop splitter?
Just curious what the most effective way is to get air from the scoop onto the intercooler. Does an aftermarket company make an adaptor for the gc hood to the EJ20G TMIC?
03-05-2008, 04:03 PM | #2 |
Member#: 141232
NESIC
Vehicle:02 v7sti wagon signal green |
Just pick up a stock JDM one.
03-05-2008, 04:37 PM | #3 |
Member#: 145440
Vehicle:MY96 WRX GT2835-ProS EJ20G 2123cc!! |
03-05-2008, 06:24 PM | #4 |
Member#: 8263
Vehicle:2006 Sti Steel gray |
Where can I source a stock one at...I called EDO performance, and all Zero Sports *supposedly* makes is for 02+ turbo'd cars...so I can modify a WRX one to work, but If I am going to do that, I will just source a stock splitter....not baller factor needed here....baller on a budget It would be slick to find a stock JDM piece that will bolt right up and fit the intercooler properly from the start.
03-05-2008, 07:20 PM | #5 | |
Member#: 145440
03-05-2008, 07:41 PM | #6 |
Member#: 141232
NESIC
You can look on ebayUK . You could get 1 for about $60 shipped.
03-06-2008, 04:38 AM | #7 |
Member#: 70537
SCIC
Zerosports is the solution!
03-06-2008, 07:58 AM | #8 |
Member#: 145440
03-06-2008, 09:12 AM | #9 |
Member#: 27963
Vehicle:2017 series.yellow |
I have a slnted EJ20G splitter for sale in the classifieds right now if that is what you are looking for.
03-06-2008, 06:34 PM | #10 |
Member#: 147812
03-07-2008, 08:37 AM | #11 |
Member#: 27963
PM replied
03-07-2008, 01:33 PM | #12 |
Member#: 61077
SCIC
Vehicle:1993 WRX Silver |
Make sure you have the right hood first.
03-07-2008, 01:55 PM | #13 |
Member#: 38338
Vehicle:2003 Outback Sdn H6 Black |
^ Exactly. The old EJ20G's were mated with the old school 93-96 JDM hoods, which utilize a different scoop, and are a completely different style. I'm not sure if you would be able to even fit an OEM G splitter to a facelift (RS) hood. Can anyone shed some light on this?
03-07-2008, 04:27 PM | #14 |
Member#: 147812
^ I sure hope so (MY98 RS here), cause I bought a EJ20G splitter today.... I'd imagine redrilling some holes on the EJ20G splitter would help mate it up. I guess I will find out soon enough...
03-07-2008, 09:00 PM | #15 |
Member#: 61077
SCIC
The scoop from the v1/2 hoods is shorter and wider. Not sure it will work.... but good luck! Let us know how it goes.
03-16-2008, 02:15 PM | #16 |
Member#: 57152
NWIC
Vehicle:---- Subaru fleet garage ( 5 and counting) |
The Zerosports splitters were meant for the ver4-6 STI's which should fit our RS's here.
If you are running the earlier WRX hood scoops, then this option will not work for you. The slanty intercooler is what went under the earlier smaller scoop hoods. I have a splitter for that with the holes for the sprayers if that is what you are looking for. But unless you are using the slanty intercooler, the splitter is worthless. |
03-17-2008, 11:20 AM | #17 |
Member#: 74712
Vehicle:2006 Saab 92x Aero Obsidian Black Pearl |
What about a splitter to use with a ver1/2 hood, but ver3/4 straight mount IC? Cause that's what I have...
03-17-2008, 01:27 PM | #18 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
i too had that exact setup
the answer is: ebay front mount |
03-17-2008, 02:37 PM | #19 |
Member#: 74712
03-17-2008, 04:01 PM | #20 |
Member#: 108210
SCIC
im using a 02-03 wrx splitter on my 95L with an rs hood, the splitter needs to be mooded to fit, dremal and a drill,now it look very oem
05-14-2008, 02:57 PM | #21 |
Member#: 152176
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
did the spliter work on rs hood?
05-14-2008, 05:47 PM | #22 | |
Member#: 61077
SCIC
10-11-2008, 04:15 AM | #23 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
10-12-2008, 03:58 PM | #24 |
Member#: 152176
i have ej20g spliter on my v6 hood (2001 2.5rs)
what motor you have? and its preatty easy to mod it to work |
10-12-2008, 04:24 PM | #25 |
Member#: 157348
What are the 08 guys looking for? | JKL | Interior & Exterior Modification | 22 | 08-25-2008 01:23 AM |
what are you guys using for turbo heat shields? | IllNastyImpreza | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 26 | 05-16-2007 05:37 PM |
what are you guys using for turbo heat shields? | IllNastyImpreza | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 05-15-2007 12:52 PM |
what do you BE guys use for EM? | legacydreamz | Legacy Forum | 14 | 02-22-2007 01:07 PM |
What are you WRX guys using for suspension set ups? | _mike_ | Tri-State Area Forum | 9 | 09-08-2004 06:26 PM |
