03-19-2008, 08:51 PM | #1 |
Member#: 142206
Vehicle:06 WRX TR PPG's TBE |
a/f read out
so the new software version has an a/f ratio... how accurate is this?
my car is down right now, but the new software looks awesome.
03-19-2008, 09:14 PM | #2 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
i believe it's getting the AFR reading from the front o2 sensor, which isn't that accurate, and I believe it stops around 11.xx.
For a better, more accurate afr reading, get a real wideband |
03-19-2008, 09:51 PM | #3 |
Member#: 165106
Vehicle:2017 WRX Gray |
At WOT mine drops to a SOLID 11. I would guess its useful only to see if a lean condition exsits (kinda)
03-19-2008, 11:18 PM | #4 |
Member#: 145634
South East
Vehicle:2006 STi- 8374 AW |
i dont think it is accurate at all. and i am sketched out by it. i ordered a wideband o2 just to check things out...
03-24-2008, 09:46 PM | #5 |
Member#: 85938
NESIC
Vehicle:2004 WRX WRB |
If you are going to change your A/F. You should not use the stock narrowband o2 sensor. It is not sensitive enough for tunning. Do some searches on it.
03-25-2008, 10:38 PM | #6 |
Member#: 142206
ya i know the difference between narrow and wide band. and mine sticks at 11:1 all day
hydra wideband> is there i gauge i can use with it for read out | moorebl | Other Engine Management | 2 | 06-16-2008 05:45 PM |
Where to find Tail lights wiring/pin read out | Knightmare69 | Electrical & Lighting | 4 | 01-29-2008 02:12 PM |
compass/temperature read out? | bjsid | Interior & Exterior Modification | 4 | 03-01-2004 10:39 PM |
Analyse my AutoX set-up, photo & tire temp read out | makofoto | Motorsports | 17 | 02-14-2004 12:46 PM |
voltage read out on cap accurate for car system? | Sobelizard109 | Car Audio, Video & Security | 1 | 03-30-2003 10:40 PM |
