Welcome to the North American Subaru Impreza Owners Club Tuesday January 23, 2018
Old 05-06-2008, 10:52 AM   #1
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Thumbs up H6 Phenolic Thermal Manifold Spacer
Sorry to double post, but anyone be interested in one for their swapped rides? Trying to see if enough interest for a group buy or start production on them. "Thermal spacers lift the intake manifold off the super heated engine to lessen the transfer of heat. Both the intake manifold and engine block are aluminum so the high heat transfers very quickly....well these spacers stop that. The cooler the intake charge the more HP and TQ your engine will make.
In addition to cooling your intake charge, these will also give you larger intake volume similar to that of a throttle body spacer."
calgearhead is offline   Reply With Quote
Old 05-06-2008, 12:06 PM   #2
Slack
Member#: 17548
I could see this being useful for the EZ30D or EG33 aluminum manifolds, but I don't know about the EZ30R. It already has the plastic manifold, which cuts down on intake temps. Would spacers really help at all?
Slack is offline   Reply With Quote
Old 05-08-2008, 09:57 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I think there would be minimal gains, if any at all, using phenolic spacers with a plastic intake manifold. My understanding is that the plastic manifolds aren't much above ambient temp when you touch them after driving, as opposed to a heat-soaked aluminum manifold that is hot to the touch.
Pat Olsen
Phenolic Thermal Manifold Spacer 3mm Brad023 Engine/Power/Exhaust 2 04-23-2010 08:55 AM
Phenolic Thermal Manifold Spacer txl146 Private 'Wanted' Classifieds 1 04-02-2009 06:28 PM
GrimmSpeed 3mm Phenolic Thermal Manifold Spacer kts262 Engine/Power/Exhaust 0 07-22-2008 09:46 PM
FS: Grimmspeed Phenolic Thermal 3mm Spacers jutes85 Engine/Power/Exhaust 2 07-22-2008 09:12 PM
H6 Phenolic Thermal Manifold Spacer calgearhead Normally Aspirated Powertrain 7 05-07-2008 05:47 PM
