Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 05-14-2008, 12:32 AM   #1
AWD_FTW93
Member#: 179968
Default question about my swap
i have a 1995 impreza L with the 1.8 in it. i just bought from a good friend of mine a 2.5 out of his 1998 2.5RS. i have the full motor and the ecu. its obviously be needing the 2.5 engine wiring harness. and i also know that i need to upgrade my clutch since i am using my 1.8 tranny. now one question i have is, i know that the 2.2 clutch fits my tranny. but will the 2.2 clutch handle the power of that RS engine. my other question is. are there going to be any other problems that i'm going to run into with this swap? any and all info is greatly appreciated.
AWD_FTW93 is offline   Reply With Quote
Old 05-14-2008, 01:21 AM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
IIRC the clutch from your 2.2 will be the same as the 2.5 with regards to size and function. I doubt either has the original disk so there is no way to know which has more gripping force (it could go either way).
Why can't you get the engine harness from the original car?
Old 05-14-2008, 03:58 PM   #3
AWD_FTW93
Member#: 179968
i am going from a 1.8 harness from a 95 to a 2.5 from a 98. i'm going from obd1 to obd2. there would be more wire splicing than what i would want to deal with. it will easier to just get the 2.5 harness that way it will be for the most part plug and play
Question about my engine swap and a turbo LegacyEast Legacy Forum 4 08-11-2006 07:39 PM
Question about my OEM HID kit -- swapping bulbs samwY Electrical & Lighting 3 05-08-2005 03:29 PM
Antsy about my swap - ease my mind? vennt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-15-2005 10:08 PM
Questions about my wrecked car/STi engine swap? WRXskier Southern California Impreza Club Forum -- SCIC 5 07-01-2004 12:42 AM
Stupid but legit question about engine swap Die Civic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-12-2001 12:22 PM
