Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 05-14-2008, 01:37 AM   #1
Anthonyx
Member#: 130556
2005 2.5RS Sedan
Aspen White!
Default transmission question
I have a 2005 impreza 2.5rs and want to swap a WRX motor into it, will i need to change the transmission or will the stock 2.5rs transmission be able to handle it?
Anthonyx is offline   Reply With Quote
Old 05-14-2008, 02:10 AM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Keep your stock transmission. I used to run an '04 STi motor with a stock '05 2.5i transmission in a '99 RS. I only used the car for track days and the transmission held up fine.
eastcoastbumps is offline   Reply With Quote
Old 05-14-2008, 02:36 AM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The transmission should be fine but the old stock clutch will probably be too weak. The ACT clutch is a favorite choice of swappers. Don't be too aggressive on the clutch or it might not last as long.
I might have one you could buy assuming I can fix a jammed WRX trans this weekend. I swapped an STI engine into a 98 RS and originally planned to use the stock RS trans but got a great deal on a WRX trans only after buying the ACT clutch.
Old 05-24-2008, 03:41 AM   #4
Anthonyx
Member#: 130556
2005 2.5RS Sedan
Aspen White!
thanks, have any idea were i could get a reliable wrx motor?
('93-'01) General transmission question/problem jeremy c Impreza Forum 3 05-24-2001 12:25 AM
transmission question smacksube Normally Aspirated Powertrain 0 05-19-2001 09:00 PM
Transmission questions goose Newbies & FAQs 6 01-28-2001 05:37 PM
OT- subaru transmission question micah General Forum Archive 0 12-20-2000 10:28 AM
Oil Cooler Kit for automatic transmission question. V6 Normally Aspirated Powertrain 5 10-19-2000 01:53 PM
