Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 05-19-2008, 02:50 AM   #1
MikeHall
Member#: 178716
Default WRX transmission (reverse rotation)?
Could you install the differential with the ring gear on the other side of the pinion to make the transmission run in reverse rotation? I bought a WRX transmission and a EG33 for a 914 project but I think im going to get a 911 now. This might not work due to the way the gears are cut in the transmission but then again I dont know and thats why im asking. LOL
Mike
MikeHall is offline   Reply With Quote
Old 05-19-2008, 04:01 AM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The Vanagon guys bolt Subaru engines to Volkswagen transmissions all the time...
Old 05-19-2008, 11:21 AM   #3
Einimas
Member#: 176111
If you'd flip the diff gears would go in correct way.
Einimas is offline   Reply With Quote
Old 05-19-2008, 11:59 AM   #4
MikeHall
Member#: 178716
It would go the correct way for a rear mounted engine right? Putting the Ring gear on the other side of the pinion would cause it to rotate in reverse but can this be done?
Mike
Old 05-19-2008, 01:43 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Mike,
What you want to do if you try that is to run the transmission upside down. It requires adding a new hole in the top for a vent. Then you plug the old vent and it turns into your drain going forward. You would also need to do something about the dipstick. I don't honestly know of anyone doing this, but I think it could be done. We do it all the time with Porsche transmissions in my shop.
But I would ask you why you want to use the Subaru transmission at all? Just use the Porsche one. For all the extra brain damage to run the Subaru tranny, I don't feel that it's substantially stronger than the Porsche tranny. Porsche and Subaru trannies are my business. Feel free to drop me a line and pick my brain as this moves forward.
Also go search on Pelican. There's a guy who put an SVX engine into a 911 earlier this year. It's a great thread with lots of good pictures and ideas. He even indicated that he might consider making some "kits" to ease the install.
Old 05-19-2008, 03:11 PM   #6
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
no. the pinion shaft isn't exactly centered, so if you flip the front diff, the gear mesh will get substantially screwed up.
also, IIRC there's an issue with clearance for the ring gear on the other side.
but, as mentioned, the best solution is to just use the porsche trans.
Numbchux is offline   Reply With Quote
Old 05-20-2008, 09:19 PM   #7
MikeHall
Member#: 178716
yeah I think that would be best. Good news is I came out of my temporary insanity and just going to finish my 914 as planned. This thing should be a rocket with stripped down EG33 with WRX transmission.
On a different note, I did not check but does the WRX transmission come with a LSD? If not what all is involved in installing one?
Mike
Are forester transmission 2006 stronger than 06 wrx transmission? 06wrxlbart Transmission (AT/MT) & Driveline 3 09-11-2007 08:39 AM
06 WRX Transmission VS. 02 WRX Transmission? 02BlueSuperRoo Transmission (AT/MT) & Driveline 17 08-06-2006 10:27 PM
Transmission Reverse Problems voteforpedro Transmission (AT/MT) & Driveline 0 04-24-2005 09:06 PM
Hard 4EAT Transmission Reverse shift naveeny Transmission (AT/MT) & Driveline 2 04-09-2002 12:16 PM
WRX Transmission VS RS Transmission VEGETA_GT Transmission (AT/MT) & Driveline 3 10-26-2001 11:49 PM
