Welcome to the North American Subaru Impreza Owners Club Saturday January 20, 2018
Old 05-20-2008, 08:26 PM   #1
George42
Member#: 178493
2001 Impreza 2.5RS
RED
Default STI into RS parts list
I was wondering how much the stock tranny can handle in the gc's
also what would be a list of all the required parts do to a full swap? running stock sti ecu and all. I know you need the engine, ecu, wireing harness, intercooler and pipping. What else like misc. lil piseces and all.
Thanx for your time. I know this has propably done befor but couldn;t find a list of hand.
George42 is offline   Reply With Quote
Old 05-20-2008, 09:52 PM   #2
ejoy1220
Member#: 157762
2002 WRX wagon
Crossmember
Pedal Box
Throttle linkage assembly?
ejoy1220 is offline   Reply With Quote
Old 05-21-2008, 12:24 AM   #3
jakeachy
Member#: 162893
00 STM GC8
Youre looking at roughly 300 horse, and you had better know how to shift well.
jakeachy is offline   Reply With Quote
Old 05-21-2008, 06:03 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You will need to modify the STI pedal in some way. You will also need a larger radiator and its matching fans. If the STI engine is 05 or later you need the matching immobilizer and key, plus an ignition antenna. You will need a new fuel pump. The new fuel pump and ECU also requires the fuel pump controller. You will also need to swap a gas tank sensor or have a tuner flash away the CEL for that missing sensor. Dont forget the matching exhaust, the full stock STI exhaust will fit perfectly. Make sure you get the MAF and intake box to match the engine. An ACT stage 2 clutch or greater is pretty much requried since the stock clutch would slip at full throttle. The stock STI power steering lines wont fit without some creative rework with zip ties. The power steering tank needs a custom mounting bracket made. Since you have to remove the entire dash area the AC will need a recharge once you are done.
There are probably a few more things but I can't remember at the moment.
Old 05-21-2008, 06:58 PM   #5
George42
Member#: 178493
2001 Impreza 2.5RS
RED
WOW a fair bit of work what is the general price range for the required parts? also curious about shops that offer to do this and do they provide the eices for swaps at certain prices
Old 05-21-2008, 07:53 PM   #6
RobK0000
Member#: 62230
10K - 13k full swap.
RobK0000 is offline   Reply With Quote
Old 05-24-2008, 09:42 PM   #7
beaviscih
Member#: 123362
'93 Crapcan EJ22
FTW
I am just starting my '98L to STi swap. For the engine, I'll be using '04 heads and a new OEM short block. 650cc injectors (maybe), walbro with a TMIC and VF43 turbo. I'm not looking for huge power goals (250-270whp) tops. I'll keep the OEM 5spd and upgrade the brakes front and rear as well as suspension parts. I unloaded the '04 wiring harness today so I could send it to ECS so they can do the merger (no way I'm attempting that job). My budget is 15k including the cost of the '98L ($2500). I have a detailed spreadsheet of parts needed for the swap if you're interested.
Here's the project car...
beaviscih is offline   Reply With Quote
FS ASAP: STI Seats/JDM Seats/STi Wheels/RS Parts... 05Subie SCIC Private Classifieds 27 08-26-2008 04:35 PM
NYS DMV inspection issues ,STi into RS conversion? wrxxed Subaru Conversions 1 10-29-2007 06:08 PM
STI 6spd conversion parts...list inside sxewrx Private 'Wanted' Classifieds 17 06-28-2005 07:43 PM
STi and RS parts FS bryan2.5rs New England Impreza Club Forum -- NESIC 30 10-15-2004 05:02 PM
STi 6-speed installed into WRX- parts list needed Greenracer6 Transmission (AT/MT) & Driveline 15 08-15-2002 11:33 PM
