Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 05-27-2008, 10:46 PM   #1
salvator_rizzo
Member#: 112713
2005 LGT Wg, R6 Race
Unhappy WRX swap help
I am just trying to get some more ideas of what might be the problem with my car. Its a 98 rs with a complete 06 wrx swap, basically everything from the wrx into my car excluding seats and exterior parts (thats about all).
The problem now is the car cranks but doesnt start for some reason, that which we are trying to figure out right now. the car does not get ground to the injectors or the coil packs, so no fuel no spark = no start.
The guy who is helping me out with my project had a question about engine damage which got me thinking,
the car i got this all from crashed by flipping somehow (black ice fast sliding to dry road apparently) and then landing on the driver's side rear roof.
1. is there anything that could have happened to the engine that might prevent it to start?
2. if not, i checked all the things that connect to the immobilizer for continuity, and all were good, which leaves me with doubt as to whether the immobilizer might be my problem. (also the grounds are fine as well).
does anyone have any suggestions as to what might be causing no fuel or spark?
salvator_rizzo is offline   Reply With Quote
Old 05-28-2008, 11:56 AM   #2
Cambridge00RS
Member#: 164451
I did the same swap last week. Check your main relay(brown connector,mounted under left side of dash on pillar). The RS has one side of the coil tied to ground but the 06 ECU signal is a ground signal. Take the black wire on the coil and connect it to ignition +12V. The other side of the coil should be the signal from the ECU.
If you have any doubts, the fuel pump is also powered by this relay. Turn your ignition on and listen for the pump to turn on. It should turn on then shut off when it reaches fuel system pressure.
Your injectors should have 12V on one pin when the ignition is on. They only have ground from the ECU when the engine is cranking/running.
Cambridge00RS is offline   Reply With Quote
Old 05-28-2008, 01:43 PM   #3
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
check your cam position and crank position sensors as well. injectors and spark will not work unless those are working.
KAX is offline   Reply With Quote
Old 05-28-2008, 01:53 PM   #4
powerneedy
Member#: 161242
this is kinda off topic but what are you guys doing for ecus in these cars?
powerneedy is offline   Reply With Quote
Old 05-30-2008, 10:28 AM   #5
Cambridge00RS
Member#: 164451
I'm using a stock 07 ECU with Immobilizer.
'05 Wrx motor swap into '02 Wrx *Need Help Badly* ZRO Subaru Conversions 2 03-01-2010 03:22 PM
2003 wrx to 2004 wrx front end swap help nicerb Subaru Conversions 1 08-12-2009 03:19 PM
rs to wrx swap help LudeNsoL Subaru Conversions 13 01-05-2009 11:31 AM
04 sti motor into 02 wrx swap... help el tekk-O Subaru Conversions 6 01-20-2008 02:55 PM
WRX swap help!!!! ImprezGC8 Subaru Conversions 2 02-11-2007 07:08 PM
