Welcome to the North American Subaru Impreza Owners Club Tuesday August 22, 2017
Old 05-28-2008, 08:29 PM   #1
axo0481
Member#: 178020
2004 STI
psm
Default back up lights dont work!!!
i have looked and found out that it could be the reverse switch. but, i have no idea where it is (tranny?) or how to change it! and maybe a part number! please help
axo0481 is offline   Reply With Quote
Old 05-28-2008, 08:36 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
call a dealer for the part number or try to look it up on genuine subaru parts
it is mounted in the tranny, it looks like a bolt with wires coming out of it.
ProdriveDreams is offline   Reply With Quote
Old 05-29-2008, 05:29 PM   #3
axo0481
Member#: 178020
2004 STI
psm
i'll try that. thanks. but, does any one have even done this repair?
Old 05-30-2008, 12:43 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
yes... but not while it was in the car, ill try to remember to check the service manual for you before i leave today
Old 05-30-2008, 01:46 PM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
have you checked the fuses. iirc there is a different fuse for the reverse lights. i had the ones in my o1Rs go out once. it was a fuse.
ATX25RS is offline   Reply With Quote
Old 05-31-2008, 08:32 AM   #6
axo0481
Member#: 178020
2004 STI
psm
i did check the ones in the driver side but not the ones in the engine bay. i'll try that!
Old 05-31-2008, 08:34 AM   #7
axo0481
Member#: 178020
2004 STI
psm
also, my folding mirrors dont line up right. the driver side is not open far enough and the passanger side opens too much?? anyone has this problem?
Old 05-31-2008, 10:32 AM   #8
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
JDM power folding?
and what doesnt line up the mirror? the housing?
Old 05-31-2008, 12:51 PM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The reverse light is tied to fuse 18 in the panel mounted in the dash. The fuse ties to a number of areas. The keyless entry wouldn't work if the fuse is bad.
Old 05-31-2008, 03:53 PM   #10
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
E-mail sent
Old 05-31-2008, 04:25 PM   #11
axo0481
Member#: 178020
2004 STI
psm
the mirrors came with the car when i got it.
i think they are JDM b/c i tryed sitting on the pasanger side to see if i could see better and yep! i saw everything perfect i just moved the passanger mirror a little and now its good enough.
Old 05-31-2008, 04:47 PM   #12
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
you coudl always replace the mirror glass as the convex mirror is on the wrong side for you! its not terribly difficult just BE GENTLE and heat the plastic surround slowly adn evenly if you decide to do it.
Old 06-02-2008, 02:04 PM   #13
axo0481
Member#: 178020
2004 STI
psm
thanks a lot for all you help.
Old 06-02-2008, 02:08 PM   #14
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
no sweat, glad to have been helpful
Back up lights Do not work?? 03WRX83 Electrical & Lighting 2 01-15-2006 12:33 PM
Back-up lights not working.... seowitz Legacy Forum 7 12-18-2005 10:12 PM
so for some reason my rear parking lights dont work... spankaveli Electrical & Lighting 4 09-30-2003 07:52 AM
License plate lights dont work. Daven Electrical & Lighting 9 06-16-2003 07:20 PM
Tail lights dont work? ripGTS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2002 11:17 PM
