Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 06-10-2008, 02:41 PM   #1
JJMINIMAN
Member#: 158347
Cool porsharu almost complete
here is the link to my pictures on webshots of the porsharu almost complete has a ej20h engine lem g3 stand alone ecu 19.5 psi boost not sure what the hp is yet as im still making the new intercooler as turbos were moved to front of the motor.
click on photo to go to all the pictures
JJMINIMAN is offline   Reply With Quote
Old 06-10-2008, 02:47 PM   #2
Bu11dogg2
Member#: 101474
2004 "Insert
Something Witty Here"
need more pics
Bu11dogg2 is offline   Reply With Quote
Old 06-10-2008, 02:48 PM   #3
JJMINIMAN
Member#: 158347
Default pictures
click on the picture itself for more
Old 06-10-2008, 03:28 PM   #4
Temp
Member#: 176760
2004 WRX 99 Vette
09 CBR600RR
Twin turbo?
Temp is offline   Reply With Quote
Old 06-10-2008, 03:37 PM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
It's awesome, but can you remove the giant spoiler? or is that needed for cooling somehow?
Bad Noodle is offline   Reply With Quote
Old 06-10-2008, 04:31 PM   #6
JJMINIMAN
Member#: 158347
Default spoiler
actually below the spolier there is the intercooler and that huge spoiler cost 1000 bucks the turbos and intercooler actually sit inside the spoiler section.
the twins were moved from the back of the motor to the front due to them banging on everything and i could not relocate the porsche tranny so i moved the turbos
Old 06-10-2008, 08:57 PM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
awesome
parkes is offline   Reply With Quote
Old 06-10-2008, 10:17 PM   #8
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
very cool... What two turbos are you using?
Dubstar112 is offline   Reply With Quote
Old 06-10-2008, 10:45 PM   #9
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
Wha!? Whale Tails FTMFW. A porsche without a whale tail, just isnt right...unless its a 959 or 935
JokerDMX is offline   Reply With Quote
Old 06-10-2008, 10:49 PM   #10
FromageTheDog
Member#: 81095
2005 WRX EJ205 weed-
whacker. OS self-tuned!
^ seconded! Every Porsche since the 80's era Turbo (913?) has been nothing but a weak approximation... (yeah, yeah, technical prowess, yadda yadda).
FromageTheDog is offline   Reply With Quote
Old 06-11-2008, 08:17 AM   #11
JJMINIMAN
Member#: 158347
Default thanks
thanks for the compliments guys i know there is alot of guys out there who want to do this swap if uyou have any questions i can answer just about all.
this swap will fit in any 911,964,993 porsche the biggest mod was moving the turbos
the turbos are stock ones
Old 06-11-2008, 09:50 AM   #12
I3izzy
Member#: 127809
how does the plumbing for the radiators work out?
and which porsche transmission are you using?
I3izzy is offline   Reply With Quote
Old 06-11-2008, 10:37 AM   #13
JJMINIMAN
Member#: 158347
Default tranny and rad
the tranny is a stock g64 tranny c4 awd
the rad is from a 1995 jeep cherokee sits at the back of the car between the rails angled so it grabs air and on the back of the rad 2 elec fans push air through cooling rad car runs at 195 degrees all the time
if you look in the photo you can see a vit of the rad behind the bumper
Old 06-11-2008, 10:42 AM   #14
Tbagger
Member#: 122680
2006 STi Rally Car
Must Have Video And Numbers
Super Work
Tbagger is offline   Reply With Quote
Old 06-11-2008, 11:02 AM   #15
JJMINIMAN
Member#: 158347
thanks im hoping to get it on the dyno at kvr here in ottawa, canada ive been on the oz liberty forum and these things lay down 202hp atw bone stock at 11.5psi ive bumped mine up to 19.5psi so i should see a difference at the wheels
Old 06-11-2008, 12:56 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
19.5 is alot for those injectors .. be careful.. if they are yellow they are only 475cc if brown then 440cc
Old 06-11-2008, 02:00 PM   #17
JJMINIMAN
Member#: 158347
Default injectors
not sure what injectors i have i have my master fuel set to 13ms ill have to check and see before i give it full boost.
i have installed an aftermarket knock disaply to tell me how much if any knock im getting
Old 06-12-2008, 02:38 PM   #18
08GRSTi
Member#: 179806
WOW
Bring it to a Porshe or Subaru dealer when you're done and get a picture of their reactions.
Great work though
08GRSTi is offline   Reply With Quote
Old 06-12-2008, 02:44 PM   #19
M8
Member#: 949
06 F2000
Speed Triple
You reckon? So a 993 GT2 or RS is an "approximation" of a Porsche?
M8 is offline   Reply With Quote
Old 06-12-2008, 03:22 PM   #20
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
more info...
Old 06-12-2008, 03:41 PM   #21
JJMINIMAN
Member#: 158347
Default more info
1996 ej20h motor 280hp stock @11.5psi approx
19" rims with 300/30/19 rubber in rear
1990 carrera c4 cabrilolet smashed and repaired (bought on enay $3999 u.s)
custom intercooler to come
link stand alone ecu (p.s i have a link plus ecu for a ej0 or 25 for sale)
greddy bov
removed the maf and installed a map sensor
increased boost considerably ( not yet tested)
3 auto meter gauges boost, air/flow, coolant temp as it was air cooles before. and a knock display to display engine knock if any.
wide band oxy sensor.
2.5" exhaust to 3" collector to 2.5" muffler and out 2.5"
rad ios from a 1995 jeep cherokee was like it was meant to be there fit perfect.
added a wide body renspeed body kit bumpers, rockers, 1/4 panels , fenders,
custom kennedy adpter and aluminum flywheel
custom fabed a engine cradle along with an engine dampenig shock absorber to reduce vibration on chassis.
if you need any more info please feel free to ask
oh total cost to date and im just about finish 15k not bad
Old 06-12-2008, 05:26 PM   #22
FromageTheDog
Member#: 81095
Obviously not in how fast it'll get around the Nürburgring, silly. The older turbos were just as likely to kill you as let you go fast.
I'm referring to the aesthetics -- the 80's era Porsche turbos with their ultra-wide flared fenders and outrageous whale tail spoilers look like they would maul any modern-day equivalent and pick their teeth with the remaining scraps.
I'd hazard that you'd have a better idea what I was talking about if you were an adolescent boy in the mid-80s!
Old 06-12-2008, 10:04 PM   #23
steve_d
Member#: 315
that, sir, is rediculous....
...I love it.
BTW...what it DOES have going for it is 2 less cylinders. the balance will be WAY better without that extra 250 lbs in the rear end.
sjd
1967 912 with EJ18...trust me, it's plenty in a 40 year old car.
steve_d is offline   Reply With Quote
Old 06-13-2008, 01:39 AM   #24
97longroof
Member#: 182275
Nice work. Lots and lots of it.
97longroof is offline   Reply With Quote
Old 06-13-2008, 08:22 AM   #25
JJMINIMAN
Member#: 158347
Default thanks for comments
this is waht i figured the flat 6 was heavy and to be honest a motor that needed lots of care from what i read oil leaks after oil leaks etc...
so at 247 stock porsche horse power i wasnt prepared to put a nother porsche engine in intead the twin 280hp stock one but with remaoping and mods hope to be over 300hp it should be pretty quick
steve_d do you have pictures of your swap
oh by the way i added more photos to the first link
FS: Almost complete stock WRX turbo system DonkeyPunch New England Impreza Club Forum -- NESIC 9 10-01-2003 10:58 PM
My dream car almost complete HomeGrownXC Member's Car Gallery 41 09-12-2002 08:26 PM
My System....Almost Complete!!! GuerillaRacing Car Audio, Video & Security 2 07-23-2002 02:32 PM
Project Frankensubie almost complete - RE: SOHC swap 2.5GT Legacy Forum 15 12-15-2001 01:28 AM
GimpFlow V3.1 is almost complete! Texas25RS Texas Impreza Club Forum -- TXIC 4 03-02-2001 03:49 PM
