Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 06-10-2008, 08:40 PM   #1
AWDrifterz
Member#: 154048
Default JDM EJ25 vs USDM EJ25 (Both MY98)
hey guys, I wounder if there is any diffrence between the JDM EJ25 and the USDM EJ25?? I know that both have DOHC, but what about the internals? I mean can I use USDM EJ25 parts to rebuild a JDM EJ25??
I'm getting one for dirty cheap, and I wounder if it's possible to rebuild it?
AWDrifterz is offline   Reply With Quote
Old 06-10-2008, 08:54 PM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
The parts should interchange, if im correct, the JDM moter was tuned for more power and didnt have any major diffrences, other than of course the ECU
parkes is offline   Reply With Quote
Old 10-30-2008, 02:57 PM   #3
Odyknuck
Member#: 192866
2006 Impreza
The JDM motor will not have the EGR provision
Odyknuck is offline   Reply With Quote
Old 10-30-2008, 08:55 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
do you mean a non-turbo (NA) JDM EJ25? '98 didnt have any turbo in the usa... or maybe im reading too far into his question. you dont see many JDM EJ25 NA motors around the usa...
elislider is offline   Reply With Quote
Old 10-30-2008, 11:06 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You're new around here aren't you? I can think of half a dozen importers off the top of my head that stock DOHC JDM EJ25 NA motors. With the head gasket issues of the DOHC's the JDM engines are a very popular cheap plug and play replacement engine for people. There's thousands, maybe even tens of thousands, of cars running around this country with those engines in them. I've got one sitting in my garage.
Old 10-31-2008, 04:48 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Odyknuck is right. The only important difference between the long blocks would be a missing EGR port that can be tapped if needed.
Old 11-02-2008, 01:35 PM   #7
elislider
Member#: 133923
03 Legacy GT wagon
well ive only been on here for about a year, but thats not related. im only saying personally i havent seen hardly any discussion of JDM NA engines... but maybe i just havent been looking in the same places as you or others. *shrug*
Old 11-04-2008, 12:00 AM   #8
Drakien
Member#: 191131
06 LGT
My engine seized up so I ordered a used JDM motor from Attarco. All you have to do is swap the intake manifold out and it takes care of the EGR valve. I would not recommend buying a motor from Attarco though. I got 2 bad engines from them. http://www.youtube.com/watch?v=VUFweRCMPzQ That is what they were doing. And they will either replace the engine if its bad or refund your money, but be out shipping and labor costs.
But from what I have seen in person, there is no difference.
Drakien is offline   Reply With Quote
Old 11-04-2008, 11:04 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
A good rule of thumb is that if you don't know for sure just don't say anything. Over in the NA forum we've discussed them a lot over the years and anyone in the industry knows about them. Until very recently putting a direct replacement JDM engine into a US car never got discussed as a "conversion" because technically it is not.
Old 11-05-2008, 08:24 PM   #10
elislider
Member#: 133923
03 Legacy GT wagon
i dont think i was out of place in saying what i said at first. ive seen way more swapped NA->turbo subarus than i have JDM NA engines. thats simply what ive seen. i know a lot of subaru guys and ive been to meets and shows and i think ive seen maybe 1 NA JDM engine. i dont hear much talk about them. not to say they dont exist or something. i just hadnt heard much about them, thats all. i will agree i havent read in the NA section much, and only recently started browsing the conversions section because im doing a conversion myself. dont appreciate being flamed. im not propagating misinformation or something. i didnt say the OP asked a stupid question, and i didnt call the OP a stupid n00b or something.
what i do know had already been said (so i didnt feel like reiterating), that generally the blocks have very few differences and differences between similar engines in similar years (when talking about mid to late 90's engines) tends to be with the intake manifold and the fuel system, partly because of the tuning differences between JDM and USDM and partly because of OBD/OBD2 requirements in the USA
Old 11-08-2008, 12:25 PM   #11
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Matt, are these the EJ25 running 10.7:1 compression with AVCS?
west_minist is offline   Reply With Quote
Old 11-08-2008, 01:12 PM   #12
996Cabby
Member#: 17008
'12 AUDI A6
Miss my subey :(
I took one of these JDM NA EJ25 motors apart for it's shortblock and noticed that the pistons on the 97 JDM model I got had different pistons than the EJ25 engine in my 98 LGT....the USDM ones were dished , and the JDM ones were flat with the 4 machined spots in them for valve clearance....so I am assuming slightly higher compression although I can't find anything on paper stating it did.........this engine is the version with the coil-pack sitting on the passenger backside of the plenum... JFYI
996Cabby is offline   Reply With Quote
Old 11-08-2008, 01:17 PM   #13
west_minist
Member#: 53451
w/ AVCS Silver
Ok. That seems to be the 98 into the 99 version, but for sure the 99-00 model. The rev limit on those motors were 7000+rpm.
Did that model came with variable intake runnings?
Where can you get those short blocks from. WOuld love to upgrade my EJ20R
Old 11-08-2008, 06:18 PM   #14
996Cabby
Member#: 17008
'12 AUDI A6
Miss my subey :(
really? I though it was older as it had the older timing belt tensioner design,.....that's good news at least...but no it did not come with variable intake runners.......
ps...most JDM parts importers have them...
Old 11-08-2008, 10:34 PM   #15
west_minist
Member#: 53451
w/ AVCS Silver
Ok,You have the older model then. Well I emailed the imported stated here.
Did the exhaust came with individual runners?
From a littler research, it does not seems to much difference between the Pre/post 2000 versions, except head difference. I wonder if the heads would bolt up. I guess it ends back up like the EJ20 heads on the EJ25 short block. I guess I have to sell my cosworth head gasket.
http://english.auto.vl.ru/catalog/su.../1997_9/28315/
http://english.auto.vl.ru/catalog/su.../2001_5/28458/
Old 11-14-2008, 02:02 PM   #16
kerberos824
Member#: 193279
This will probably be considered in the wrong area of the forums, but since this is what I'm considering doing I thought I'd start here. I just picked up a Forester (I know, not an Impreza) with the phase I ej25 and I believe it has the dreaded head gasket issue. Not really sure yet, doesn't have any of the tell tale signs, other than a wandering heat gauge, and I haven't done the chemical test for exhaust in the radiator, although I can't smell any. Picked the car up for 2000 under value, and knew that it was too good to be true. What I'm really curious about is if anyone here knows anyone in the North East (I live in the lower Hudson Valley of NY) who will do a swap between either a JDM or a USDM engine. Any help or points in the right direction would be greatly appreciated. Thanks.
kerberos824 is offline   Reply With Quote
JDM EJ25 vs USDM EJ25, pros & cons ? qtr_wrx Subaru Conversions 9 05-25-2009 12:10 AM
EJ25 in JDM Legacy VS US EJ25 WRX tkw24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-13-2007 02:53 PM
what is the diff btw a jdm and a usdm ej25? boomsticks Normally Aspirated Powertrain 11 06-04-2007 01:04 AM
FPGreen, JDM v7 heads, USDM EJ25 block, CP Pistons, Perrin Rails, Injectors, Headers Rizzo314 Engine/Power/Exhaust 13 04-08-2007 03:30 PM
JDM EJ25 vr USDM EJ25 trinistyles Newbies & FAQs 8 02-16-2007 05:26 AM
