Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 06-11-2008, 11:18 PM   #1
Pierrot
Member#: 180417
Default atmospheric pressure sensor???
so my gc8 with a v2 sti swap is cutting off fuel threw obd1 code 45 of atmospheric pressure sensor fault and so... I need to find the part number for it and was hoping someone could help me out. I'm guessing I have to replace it :/
Pierrot is offline   Reply With Quote
Old 06-12-2008, 10:35 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Code 45 for the turbo cars is the pressure sensor & pressure exchange solenoid. I'm pretty sure the pressure sensor and associated exchange solenoid will also be on the passenger strut tower. If so, it should be black and rectangular. You can kind of see it in this picture
http://www.main.experiencetherave.co...2/DCP_6012.JPG
If you can find it, see if there's a part # on it.
Josh
Legacy777 is offline   Reply With Quote
Old 06-12-2008, 12:13 PM   #3
Pierrot
Member#: 180417
oh so your talking about the black one? #1 on picture? i hope so because i cant read part numbers on the other two they are too faded :/. I hope its not number 1 though lol i looked up the part number and it was like 320 dollars! ugh
Old 06-12-2008, 01:24 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
*i think*
1 map sensor
2 purge solenoid
3 is bcs
Old 06-12-2008, 02:20 PM   #5
Pierrot
Member#: 180417
bcs? whats that stand for?
Old 06-12-2008, 02:32 PM   #6
Pierrot
Member#: 180417
On the very bottom of number 3 there is a hose attachment. Do i plug that into the air intake? because If i plug it closed my boost stays at 10 psi and no fuel cut. but if i attach it to the air intake my car falls on its face. as soon as it passes 10 psi. This is my problem and this is why i checked the CEL and found out its code 45.
Old 06-12-2008, 10:42 PM   #7
Pierrot
Member#: 180417
1 is 22012AA020 ''turbo pressure sensor'' by the part number and if I replace this part I should be ok? or should I also get #2- 14774AA340 ''pressure exchange solenoid''? still don't know what number 3 is though the tag is gone
Old 06-13-2008, 10:44 AM   #8
Legacy777
Member#: 4800
Jaxx is correct on the sensors.
BCS - Boost Control Solenoid
The hose at the bottom of number 3 needs to be put back into the air intake. If you plug that line, you're essentually running boost pressure directly to the wastegate diaphragm.
You need to double check the wiring and make sure everything is good before you replace the pressure sensor. That pressure sensor is the same one that is on the first gen turbo legacies. So after you check the wiring, and confirm it's good, I'd recommend getting a used pressure sensor. You may want to post in the parts shed on www.bbs.legacycentral.org and you only should have to replace the pressure sensor, and not the exchange solenoid.
Do you have a steady Check engine light, or does code 45 just show up when you check the codes? Have you tried clearing the codes? You can do the battery method or I have another procedure on my site
http://www.surrealmirage.com/subaru/....html#resetecu
Josh
Old 06-13-2008, 12:01 PM   #9
Pierrot
Member#: 180417
Thanks for all the help!
Yeah thats what i thought about the hose...
I will recheck and see if the wiring to the sensor is still good today.
The thing is its a gc with a swapped ej20g which is obd1. the wiring was done by ECS and i kinda talked to them through emails (tried calling but no answer, guess they were busy) and they said to hook back in the green connector under the dash(the one that throws program codes?) and see what code its throwing via the slow blinking to fast blinking and thats how i got code 45 constantly no other change. but with it unhooked it just stays on for a period of time and when speeding up occasionally turns off.
also did the battery thing and no change
Old 06-17-2008, 11:52 AM   #10
Legacy777
Member#: 4800
If the light just stays on, the code is an "active" code meaning the fault is currently occuring vs. having occured in the past.
However based on your description of how the CEL comes on and off intermittantly, I'd almost suspect a wiring problem, so make sure to check the wiring very thoroughly.
Josh
Old 06-18-2008, 11:04 AM   #11
Pierrot
Member#: 180417
If the green connector is plugged in for it to throw whatever codes the obd1 is. It throws the code 45 constantly non stop
Old 06-18-2008, 01:12 PM   #12
Legacy777
Member#: 4800
Yeah....that's normal.
Old 07-15-2008, 08:51 PM   #13
Pierrot
Member#: 180417
so I got my hands on the pressure sensor and the old one had really ugly bad ripped wires. replaced it and now I can step on it fine when the check engine light isn't on. but then the cel comes on randomly. but a lot less then before and bam, same problem
Old 07-16-2008, 07:30 AM   #14
Legacy777
Member#: 4800
Is it the same code? Pressure sensor?
Old 07-16-2008, 09:24 AM   #15
Pierrot
Member#: 180417
yes sir. it comes up a lot less but still does randomly. I connected the green connector and for a little while no codes were being thrown. then bam yet again. same code
Old 07-16-2008, 03:41 PM   #16
Legacy777
Member#: 4800
Hmm....that sounds more like a possible wiring issue, OR a flakey sensor.
Old 07-16-2008, 04:26 PM   #17
Pierrot
Member#: 180417
the sensor is new
ugh but the car is now ALOT stronger so i know the previous sensor was just ruined
And when that CEL comes on it will do it again. ugh... but when its not, im all normal. Where can i find the ecu pinout for my ver2 so i can hook up a a/f ratio gauge so i can atleast know if im leaning out.
Old 07-18-2008, 11:43 AM   #18
Legacy777
Member#: 4800
I'm not sure about the wiring diagram. You may want to ask in the electrical or engine management forum.
Where are you located?
Old 07-18-2008, 01:02 PM   #19
Pierrot
Member#: 180417
houston tx
Old 07-19-2008, 09:58 AM   #20
Legacy777
Member#: 4800
Well maybe I can help you troubleshoot it, if you can't get a hold of a wiring diagram.
Old 07-21-2008, 01:21 PM   #21
Pierrot
Member#: 180417
that would be awesome. what is stock boost for these cars? my car went to 16 psi and I dont think it should be that high lol
Old 07-22-2008, 12:28 PM   #22
Legacy777
Member#: 4800
I think some where around 14 psi.
Drop me a PM if you would like some help troubleshooting.
Josh
Old 08-05-2008, 03:57 PM   #23
Pierrot
Member#: 180417
Josh
sorry i havent gotten here often been busy,
But i was checking to see what boost i was putting and it went as high as 18 and it worries me. And i did more looking around and found 2 lines that were open.
I looked for pictures of other ver2's and found i didnt have this
the two little arrows are the lines that are now empty and the canister was never there. Do you happen to have a part number? So i can go get one
Old 08-05-2008, 04:49 PM   #24
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
thats the charcoal canister its the vent for the gas tank (the reason there are 3 fuel lines)
go to the junk yard most of the obd-1 subarus have them its an "emmissions device" so them may try to stick you
Old 08-10-2008, 06:39 PM   #25
suberboy
Member#: 1531
2008 GRB
Red
would you get that code from over boosting? sorry i don't know OBD 1 well enough to know if that is the code for over boost or not. with over boost you get fuel cut for a moment and then the car would drive normally again until you over boost again. just a thought
suberboy is offline   Reply With Quote
Atmospheric Pressure Sensor ElizRN Transmission (AT/MT) & Driveline 12 03-07-2016 07:47 PM
Atmospheric Pressure Sensor cthor Private 'Wanted' Classifieds 2 09-25-2009 12:35 AM
swapped GC atmospheric pressure sensor tscott915 Pre-2002 Factory Turbo Powertrain 4 03-20-2009 12:12 AM
Where is atmospheric pressure sensor located? IndyRacer Engine Management & Tuning 7 02-24-2006 12:38 PM
MAP & Atmospheric Pressure Sensor Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-01-2002 12:45 PM
