Welcome to the North American Subaru Impreza Owners Club Tuesday August 21, 2018
Old 06-12-2008, 05:33 PM   #1
Tirpitz56
Member#: 77728
2001 Impreza RS
Default 2004 STi Wiring with 2006 WRX Engine??
I have an 01 RS which I swapped an 04 STI motor into with wiring and ecu. That motor blew but the wiring is still good. I have been researching buying another STI motor but have read thet the 2006-up WRX engines are basically the same as the STI with the exception of turbo, intercooler and ecu.
Is it possible to swap an 06 WRX motor into my current setup without rewiring anything? I still have my STI manifold with complete wiring. Do I need to swap that onto the WRX motor or can I just leave it as is? Are the wiring harnesses the same? Both motors have the same stuff with the exception of the air pump stuff. Will STI ecu's work with the WRX motor?
Thanks for whatever help you guys can give.
Tirpitz56 is offline   Reply With Quote
Old 06-12-2008, 06:00 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
curious to know as well.
Old 06-13-2008, 11:44 AM   #3
Tirpitz56
Member#: 77728
2001 Impreza RS
anyone?
Old 06-15-2008, 01:00 PM   #4
corky97
Member#: 180825
No,the 04 STI wiring is different if you use the o6 engine with the 04 ecu you need to take the harness off the 04 engine,& put it onto the 06 engine.The ecu connectors are the same,but the terminals are in different positions.You have to change about 150 wires around,plus the 06 has an imobilizer,& you have to have a cluster to match the ecu,& the body intigrated unit.
corky97 is offline   Reply With Quote
Old 06-15-2008, 10:44 PM   #5
Tirpitz56
Member#: 77728
2001 Impreza RS
So just swap over my 04 sti manifold with harness and I'm good?
NY 2004 STI WRB Partout Drivetrain, Running Engine, Wiring Harness, Interior Royal Motors Complete Car Part-Out 421 01-02-2010 03:53 PM
2006 WRX Engine with a tranny wrxgeneration Engine/Power/Exhaust 7 06-04-2009 08:25 PM
NY 2004 STI WRB Partout Drivetrain, Running Engine, Wiring Harness, Interior and more Royal Motors Complete Car Part-Out 40 07-10-2008 04:43 PM
2004 STi with 2006 WRX brakes? Fred Brakes, Steering & Suspension 13 02-16-2006 08:51 AM
will 2004 sti rims fit 2006 wrx? subie freak Newbies & FAQs 10 02-09-2006 10:35 PM
