Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 06-12-2008, 06:59 PM   #1
AJS
Member#: 5000
Default ej20K Crank Sensor Replacement
Will any USDM WRX crank sensor work? They appear to look the same.
Andrew
AJS is offline   Reply With Quote
Old 06-13-2008, 02:01 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
i would guess a ej25d (dohc) should be close if not exact
Old 06-16-2008, 02:39 PM   #3
AJS
Member#: 5000
thanks...I ordered a usdm wrx one...we'll see if it's the same.
another question - my ej20k oil filter it longer and wider than the USDM WRX/STI ones....any idea if using the smaller filter is going to harm anything?
Andrew
Old 06-17-2008, 01:49 AM   #4
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Sti oil filters work fine. Though for a higher capacity i would recommend a fram extra guard wrx filter because the canister size is much bigger and has more filtration media.
trxdam is offline   Reply With Quote
EJ20K Oxygen Sensor kwan_1104 Pre-2002 Factory Turbo Powertrain 32 07-08-2014 11:39 AM
03 WRX All 4 Coil Packs, Intake Manifold, Crank Sensor, Knock Sensor 45k Miles on All mrtrex Engine/Power/Exhaust 46 05-02-2010 10:12 AM
Can someone link me to a crank sensor replacement how to Jus Blaze Service & Maintenance 7 03-04-2008 10:43 PM
FS: Crank sensor, Cam Sensor, FPR gren737 Engine/Power/Exhaust 1 07-14-2007 10:39 PM
cam sensor vs. crank sensor vs WTF TyranosaurusWRX Built Motor Discussion 31 08-19-2006 03:42 PM
