Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 06-15-2008, 09:26 PM   #1
schnellgti
Member#: 131406
1997 Legacy Outback
parts hauler
Default no spark after swap...help!
So i just finished putting a 2.2 (out of a 99' obs) into my 96' Impreza and I don't have any spark. There is gas getting to it and the starter works but are there some things that I should check? The plugs are good and the wires are new. I was thinking it might be a senor but I don't know where to start or know how to test them. Might it be because I didn't have the cooling system installed yet?
Thanks!
Anthony
schnellgti is offline   Reply With Quote
Old 06-15-2008, 09:29 PM   #2
silentt
Member#: 119995
2004 Outback XT
Peachy
Check your cam/crank sensors. Your cam sensor is on the front of the drivers side head, your crank sensor is behind your alternator.
silentt is offline   Reply With Quote
Old 06-15-2008, 09:37 PM   #3
schnellgti
Member#: 131406
1997 Legacy Outback
parts hauler
How do I test the senors?
thanks
Old 06-15-2008, 09:39 PM   #4
silentt
Member#: 119995
2004 Outback XT
Peachy
Make sure the connections are on all the way and the bolts holding them down aren't loose. If it still doesn't work, see if you know someone with a similar engine and swap sensors for 10 minutes.
10 codes after swap...Help me out.. cthor Service & Maintenance 3 05-10-2009 02:20 PM
Impreza no start after swap subienewb29 Newbies & FAQs 8 08-06-2008 04:50 PM
HELP - auto transmission no response after swap zrl Transmission (AT/MT) & Driveline 2 09-07-2007 10:13 PM
No start after upgrades HELP!!! cm1wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-01-2006 09:15 PM
NO SPARK after replacing harness & intake plenum aftermathWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-23-2005 11:02 PM
