Welcome to the North American Subaru Impreza Owners Club Saturday April 21, 2018
Old 06-18-2008, 12:34 AM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Compression ratio advice for EJ25 shortblock swap, 11.5 or 10.3 or?
I'd like advice. I'm going to perform the ever popular EJ22 to EJ25 shortblock swap. I'm thinking I should go for the 10.3 CR unless a thicker gasket is available. Advice?
I used the specs from http://wac.addr.com/auto/obs/turbo/ejcalcs.html with the calculator http://www.bgsoflex.com/cr.html -
* Cylinder head Volume (CC) = 40.00
* Piston Top Volume (CC) = 14.50
* Cylinder Bore (Inches) = 3.9
* Cylinder Stroke (Inches) = 3.11
* Deck Height (Inches) = 0.000
* Head Gasket Thickness (Inches) = 0.060
# Computed Compression Ratio is 10.2 to 1
If I use the SOHC gasket thickness of 0.023 # Computed Compression Ratio is 11.3 to 1
For fun I entered the stock EJ22 specs -
* Cylinder Bore (Inches) = 3.8
* Cylinder Stroke (Inches) = 2.95
Computation Results:
# Computed Compression Ratio is 9.4 to 1
Background - This is in my beater Legacy. I've driven it like I stole it every day for the last 130k miles. It runs perfectly, good compression, passes smog great but cylinder #3 is consuming oil at the rate of 1qt per 350 miles. I got the EJ25 for free since the spark plug broke and put a few dents in the piston top (easily removed with the dremel).
Thanks for your ideas.
Old 06-18-2008, 02:19 AM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
I found a Subaru compression ratio calculator which verifies the above info -
http://www.jonesboy.com/Media/Matts_CR_calc_v1_01.xls
Using it I get 10.33 for DOHC gasket and 11:5 for SOHC gasket
Old 06-18-2008, 07:25 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
I guess it depends on what kind of goals you have, gas you have available and are willing to buy.
I'd go for broke and get as much CR as possible......but I'm not a smart guy......
Jay
Old 06-18-2008, 10:59 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
what em are you gonna use ...
you need it to take advantage of the change ...
Old 06-18-2008, 01:43 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
The goal is a daily driver that uses 87 octane fuel. The horsepower outcome doesn't matter much to me as long as its equal to or greater than its current amount.
The increase in displacement is still within the injector sizing and learning curve for the stock computer which I was planning to use.
Old 06-18-2008, 04:21 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
hmmm
it will learn in closed loop but not open loop and a 98ecu won't adjust timing like it will need
its not a b16 ... 11.5 is allot for a ej series engine ..
Old 06-18-2008, 05:15 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
The ECU is a 91. I agree that 11.5 is way high. I even feel 10.33 is high but I don't have enough experience with NA Subaru tuning.
A well respected VW builder made a suggestion today that may or may not be applicable. If I use one DOHC gasket and one SOHC gasket together I get 9.6:1 compression or three SOHC gaskets to get 10:1 (assuming the resulting thickness is .083 and .069). The stock CR of the 90-96 2.2 is 9.4 where the 97+ 2.2 is 9.7
The SOHC/DOHC combo is only .023 more than the regular gasket so would my manifolds fit properly?
I know the newest design of EJ25D gasket from Subaru is MLS, Do you know if the SOHC gasket is of similar material and could mate properly in this configuration?
Thanks
Old 06-19-2008, 07:29 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cometic will make you whatever thickness you want. The SOHC gaskets I have taken off were MLS.
Jay Storm
Old 06-19-2008, 04:38 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
I hope custom cometic parts are better priced than custom ARP parts (good stuff but damn they charge alot).
What do you think about stacking multiple MLS gaskets?
Old 06-20-2008, 01:49 AM   #10
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
You shouldn't use multiple hg's. Just use the stock replacement HG's for EJ25's, the dohc gasket is MLS, and you can get them cheap on Ebay.
You might be able to get away with 89 octane if you go 10.3 CR, but you better not try that with the 11.5 CR, as soon as you start pinging, the ecu retards timing, there goes all the power that would have gained from doing this.
I've had the high CR motor in my car for a while, its alot more powerful than the stock ej22 was. You will definately enjoy it. Make sure to get cams, at least, the EJ22 heads run out of steam up top. Not to mention you'll be trying to stuff another 300cc's of displacement through those heads.
But you still havent told us what phase EJ25 this is.
I use this CR calc. alot, along with a couple others to verify accuracy.
~Josh~
Old 06-20-2008, 02:25 AM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
Thanks for the help. Does the data I posted originally look accurate? I've learned not to trust specs from the internet...
I didn't think the cams from a SOHC EJ25 fit on the EJ22 SOHC heads,,, or did you mean aftermarket?
Old 06-24-2008, 04:19 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
double
Old 06-25-2008, 07:22 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yup....very little, if any upcharge for custom thicknesses. They're pretty much made to order anyway. The have various gauge stock to work from, so getting your desired thickness shouldn't be an issue. I don't think I would stack MLS gaskets to achieve a certain thickness. If I had to....I'd only stack center layers, leaving the outer layers where they are supposed to be.
Jay
Old 06-25-2008, 03:24 PM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
I want to make damn sure I order the right size. I don't trust the numbers I posted originally. How can I be certain that a .080 gasket is the right thickness for 9.7:1 ratio?
Secondly give me your advice. Is a 9.7:1 ratio good if I plan to use 87 octane gas?
Response from cometic -
We can gladly make the gasket thickness what ever you like as long as it is a possibility for us. However, I cannot confirm nor deny if your calculations are correct or not. When it comes to volumes I can tell you it is never a safe bet to assume anything or trust information you find on the internet. In theory your numbers make sense but like I said I cannot do the math to verify.
Kevyn Kistner
Technical Sales
Cometic Gasket
Old 06-28-2008, 03:51 AM   #15
ballitch
Member#: 74907
98 cam'd EJ251
You do mean .80 mm right? Not .080''.....
And 9.7:1 is the stock CR btw...
The only true way to tell if you have a Phase II EJ25, is to split the block and look to see where the thrust bearing is. 1999 was a big gray year for Subaru.
~Josh~
Old 06-30-2008, 04:51 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
Cometic is unable to give suggestions or advice on thickness so I am relying on the input of the forum. What target CR should I shoot for (I'm still leaning towards 9.7).
Second can you help me to confirm that a .2cm gasket will give me 9.7:1?
I mean .080 inch because the stock "thick" gasket from Subaru is .060 inch.
In metric thats .152cm for the thick gasket, 0.058 for the thin one and about .2cm to get 9.7:1 if my calculations are correct.
9.7:1 is only stock for the 97 and later ej22 with single port exhaust and solid rockers. Mine is a phase 1 with dual port exhaust, hydraulic lash adjustment and a 9.4:1 ratio.
The 90-94 EJ22 was 130hp @ 5.2k and 144tq @ 4k
The 97-98 was 137 @ 5.4k and 145 at 4.4k
The 99+ got 142hp at 5.6k and 149tq at 3.6k
Old 07-01-2008, 06:14 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
Alright I plan to try for 9.7:1 ratio using a .215cm gasket unless anyone says otherwise.
Is an increase .152cm to .215cm going to cause an issue? Perhaps too much change in timing since the heads are father apart or maybe exhaust/intake manifold fitment.
Now my question is - should I get a 9.96 bore gasket that has coolant and oil passages like the EJ22 or a 9.96 bore gasket with coolant and oil passages like the EJ25
Old 07-01-2008, 07:57 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
Timing change will be unnoticable. Get the gaskets with a bore that matches the block.
Jay
Old 07-02-2008, 04:15 PM   #19
ciper
Member#: 15543
90BJ Legacy LS ABS
Storm: My question wasn't worded very well. I was trying to ask if I should get a 9.96 bore gasket that has coolant and oil passages like the EJ22 or a 9.96 bore gasket with coolant and oil passages like the EJ25?
Old 07-02-2008, 10:24 PM   #20
Storm
Member#: 5218
96L Most Over-
Developed Beater
Ahh.....Kevyn recently developed a hybrid headgasket just for this type of buildup. I had the PN in an email from him, posted it here somewhere and deleted it from my boxes. It's got the EJ25 bore and EJ22 coolant passages, just like you want....if I'm reading this correctly.
Jay
Old 07-03-2008, 02:01 AM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
Storm : Yes I think you are right -
.215cm should equate to 2.15mm or after converting will be about .085” of an inch. This seems like a pretty thick gasket for what you are trying to do but if this is what your math shows then the numbers don’t lie. I can make you a gasket at .086” compressed and I have already setup a gasket in our system that is for your EJ22/25 setup. Because of the thickness being so much greater than stock you will be looking at $107.88 per gasket plus shipping. Let me know if you would like to get these on order.
I'm seriously bummed. I did not expect to pay 230$ for headgaskets! I especially didn't expect such a price since I just payed 40$ for a pair of Subaru OEM MLS gaskets!
Any advice on a less expensive alternative to get my EJ25 shortblock working with my original intake manifold? I also have a complete phase one DOHC EJ25 with a spun bearing if any of its parts can help. (still runs decently too)
Old 07-05-2008, 10:22 PM   #22
ciper
Member#: 15543
90BJ Legacy LS ABS
I don't know how I missed this before but the Phase 2 EJ25 has significantly less piston volume than the phase 1. I picked the bock up and verified that it is in fact a phase 2 which means all of my above calculations are invalid.
I don't think I can increase the volume enough just using the gasket thickness to get a low CR with the stock heads. I may have to sell this shortblock and find another route.
Are there any other heads (with increased capacity) work with the first generation EJ22 SOHC intake and ecu?
Compression ratio matrix for EJ-series engines Marnix Built Motor Discussion 26 10-11-2016 05:21 PM
ej20 to usdm ej25 shortblock swap, need some help! xxxjuhstenxxx Subaru Conversions 1 01-21-2008 10:15 PM
Engine swap advice for an '05 saabaru 2.5? MrSaabaru Normally Aspirated with bolt-on Forced Induction Powertrain 13 05-30-2005 03:05 AM
EJ25 Shortblock swap RyansJDMgc8 Subaru Conversions 13 09-16-2004 06:30 PM
