Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 06-23-2008, 02:53 PM   #1
notdisturbed
Member#: 104793
2001 V8 JDM STi
Silverthorne
Default Front axles for JDM STi swap?
I have a swapped GC. Its a ver8 JDM STi, full drivetrain and all. I've recently torn the outer boots on both front axles, and need to replace them. Im opting for full axle replacement, as i have a feeling the clunking noises from my passenger side axle means bad things. The issue is, i have no idea what to get! Do i get axles from a USDM WRX? 04 USDM STi? And, where do i find these things? I checked napa, but they seem to only carry the WRX axles.
Thanks in advance!
notdisturbed is offline   Reply With Quote
Old 06-23-2008, 04:08 PM   #2
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
I may not give you a complete answer but, I have put in a complete JDM V7 drivetrain in MY99 RS and I used the stock RS front axles. They fit and I have had the car for over 2 years with no problems. So I am guessing front axles are the same in dimensions, although there could be some difference in strength, maybe.
You could try this website
http://www.mazda-parts.com/partscat.html
or http://www.subarugenuineparts.com/
Just call them or email them, to ask about the specific part.
Osgood30 is offline   Reply With Quote
Old 06-23-2008, 04:09 PM   #3
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
Oh and the clunking noise may be wheel bearing. If the wheel bearing is from your original car and has a lot of miles on, I would check that too.
Old 06-23-2008, 04:41 PM   #4
notdisturbed
Member#: 104793
2001 V8 JDM STi
Silverthorne
The wheel bearing is from the swap car, so its low mileage.
Old 06-24-2008, 09:37 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
any GC/GF axles will fit from 93-01. the rear end is a different story(93-97ish is diff. from 98+ iirc).
i used my L axles in my STi swap fwiw. held all 350WHP. R160 has identical driveshafts from 93-01 no matter if its an impreza or forester.
--keith
kheff46 is offline   Reply With Quote
Old 06-24-2008, 12:43 PM   #6
notdisturbed
Member#: 104793
2001 V8 JDM STi
Silverthorne
Ok, so, even though i have the STi 6-speed, along with the STi hubs, i can grab a set of axles from any 93-01 impreza and have em fit? I was worried that the wide-track stance of the new drivetrain meant that the axles would need to be a bit longer than the stock RS pieces. That being said, should i get 02 WRX axles? Would they fit? Are they a bit stronger than RS stuff?
Old 06-24-2008, 04:37 PM   #7
kheff46
Member#: 66739
2002 WRX wagon
R180 is what you need. and is only compatible with STi(usdm 04+). nothing else will work. im sorry i read wrong or misunderstood. older STi had R160 rear diff and small axle shafts like the L's etc. R180(180mm ring and pinion vs 160mm=R160) is the only thing useable. people have been using R160 shafts and getting R180 outer ends welded on. bad idea imho.
again, sorry. you can't use anything but R180 compatible(or custom bits)
even WRX uses the smaller/weaker R160 drivetrain bits.
--keith
AVCS wiring harness for JDM STI swap langsbr Engine/Power/Exhaust 8 06-18-2015 09:08 PM
WTB: Front axles for 04 STi brandonl Private 'Wanted' Classifieds 15 08-04-2009 06:16 PM
I need a part number for JDM sti axle boots Capt Crunch Transmission (AT/MT) & Driveline 4 07-25-2007 07:48 PM
WTB: 04 STI front axle for my JDM 6spd chudlo TXIC Private Classifieds 5 11-29-2006 09:37 AM
What EM is everyone using for JDM STI swap? xS2k Subaru Conversions 9 10-14-2005 04:24 PM
