Welcome to the North American Subaru Impreza Owners Club Wednesday August 15, 2018
Old 07-03-2008, 06:23 PM   #1
Auto0utcast
Member#: 127684
2004 WRX STi
Default 2004 sti embarrasses itself @ track...
ok before i list out the times im going to give u all a little backround. the car is a 2004 psm STi. full interior, 2 amps, one 12" sub in a slot ported box and i had a small charcoal grill in the trunk for the up comming holiday...
car has a built block (stock compression) 100mm cp pistons, carillo h-beam rods, acl bearings, arp head studs, stock heads/cams/valvetrain with a 3" inlet 8cm^2 exhaust housing FP GREEN! pushing 23psi on pump through the stock topmount intercooler... 3" catless downpipe (helix) to the stock sti catback. car is on stock clutch which is giving me fits... this car dyno'd 346hp/344tq uncorrected and 366hp/364tq SAE corrected at moon performance on these settings this past january...now on to the rundown... 5 runs... lebanon valley dragway last night... outside temp ranged from 83* at first run to 72* at last run.
1st run:
r/t..... .069
60'..... 2.203
330..... 6.103
1/8.....9.159
mph..... 81.79
1000.....11.741
1/4.....13.951
mph....102.84
run #2
r/t..... .224
60'..... 2.026
330..... 5.667
1/8..... 8.604
mph..... 84.42
1000..... 11.131
1/4..... 13.308
mph...... 104.16
run #3
r/t..... .002 <----f'n right doggy
60'..... 2.163
330.....5.963
1/8.....8.964
mph.....83.06
1000.....11.545
1/4.....14.031
mph.....86.16 (missed 5th)
run #4
r/t..... .344
60..... 2.044
330.....5.800
1/8..... 8.810
mph..... 82.75
1000..... 11.372
1/4..... 13.569
mph..... 103.28
run #5
r/t..... .324
60'..... 2.073
330..... 5.942
1/8..... 8.962
mph..... 82.77
1000.... 11.526
1/4..... 13.719
mph..... 103.59
F*** THIS CLUTCH!!! its either spin/bog, bog, grab then let go... or i miss a gear...im disappointed to say the least... from a roll i pull HARD on cars trapping faster.... i think the issue is bogging out of the hole but meh.. whatever.
Auto0utcast is offline   Reply With Quote
Old 07-03-2008, 06:27 PM   #2
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Do you have Launch Control? It makes things alot easier! I never bog anymore! But that shifting is all you SON!
tux121 is offline   Reply With Quote
Old 07-03-2008, 06:30 PM   #3
Auto0utcast
Member#: 127684
2004 WRX STi
no launch control... first time ever to the track with this car... tried launching from 4k, 4500, 5k, and 5500... it was either too low and would bog, or too high and would spin, then bog. tried different differential settings... best result was dccd rolled all the way to the rear?
Old 07-03-2008, 06:39 PM   #4
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Really? I've done a 4.5k rpm launch without Launch Control and I can make that baby spin the tires.
DO NOT SET THE DCCD 100% REAR!
Oh yeah what kind of turbocharger are you running?
Old 07-03-2008, 06:45 PM   #5
downsti
Member#: 63179
2006 Stock Turbo STi
[email protected] VF39
PRACTICE...........
as for spinning tires it all comes down to what kinda tires your using.
as for setting it on 100 percent rear. thats drivers preferance. when i had my 04 STi ussually used full rear depending on the surface (road)
i think its safe to say his using a stock turbo?
downsti is offline   Reply With Quote
Old 07-03-2008, 06:47 PM   #6
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Well someone already proved the rear axles can break with the stock turbo
I love youtube
Old 07-03-2008, 07:03 PM   #7
downsti
Member#: 63179
yes i broke one also.. im on Auto
i pulled my 1.63 on my 04 STi 100 percent rear
and 1.61 on 50,50 (Lock)
but putting the 100 percent rear doenst mean its all the power is gonna be on the rear..
i believe the torque split will always be 35 front and 65 rear for the 04 -05 STi setting on the 100 percent rear on the DCCD,
as for auto i think the center diff fluctuate so much looking for the best traction and gives 1 wheel more torque than the other 3 which in my theory what cuased my rear axle to break.
i launch at 50 50, it comes down to how you set your alignment up, tires, clutch controll, suspension, and you dont need launch control
you can break anything, if you really want to
plus the stock turbo has proven to be powerfull enough to take on some gt30r cars from a stand still
Old 07-03-2008, 07:22 PM   #8
Auto0utcast
Member#: 127684
2004 WRX STi
read the paragraph in first post.... 3" inlet 8cm^2 fp green
Old 07-03-2008, 07:29 PM   #9
pooster.online
Member#: 120461
2004 WRX STi JBP
damn you gotta cut the 60' to something under 2.. its killin yaa
pooster.online is offline   Reply With Quote
Old 07-03-2008, 08:27 PM   #10
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
The trap speeds indicate that the car is definitely not making the power it should. Did you do anything to cool off the stock tmic before any of the runs?
OppositeLock is offline   Reply With Quote
Old 07-03-2008, 08:35 PM   #11
Auto0utcast
Member#: 127684
2004 WRX STi
popped the hood and used stock intercooler sprayer with windshield washer fluid in that reservoir.... thats all.
Old 07-03-2008, 09:04 PM   #12
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
I'm willing to bet you're slipping the clutch too fast. To hit a 2.2 60ft that is a pretty bad launch (no offense )
I'm a little confused with your build. You have the parts to make a very very fast car, such as the forged internals and a nice turbo but you skimped out on the intercooler and stock cat-back? You are leaving a huge amount of power on the table with those two parts! Especially sitting in a staging lane waiting to drag race, that stock sti top mount must be hating you! I'm willing to bet you'd pick up at least 30whp by going with something more efficent such as a fmic. And with a fmic you can run more boost safely and take advantage of those forged internals a bit more. Anyway, my mind is wondering so I'll finish with saying why the hell did you leave the grill in the back?
Steve.804 is offline   Reply With Quote
Old 07-03-2008, 09:10 PM   #13
REX8
Member#: 24038
Ding ding ding. Forget the E.T. for now.
Where in the world is all the power? It should at least show somewhat in the trap
Old 07-03-2008, 09:11 PM   #14
n2oiroc
Member#: 141952
18 golf arrrr!
unless he is consistantly shifting really early or really slow.
n2oiroc is offline   Reply With Quote
Old 07-03-2008, 09:28 PM   #15
JoseanWRX
Member#: 126892
Turn down the boost 1-2psi and try again. We have the same problem with my friend's STI @ the track untill we logge it and saw the ECU pulling some timing in the lower gears.
JoseanWRX is offline   Reply With Quote
Old 07-03-2008, 09:29 PM   #16
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Wow your traps are really low. You should get your car checked out.
k04sti is offline   Reply With Quote
Old 07-03-2008, 10:02 PM   #17
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
What do normal Stage 2 STi's trap then? I can only trap 102mph and that was just being lucky?
Oh yeah my cars missing 30wtq lmao
Old 07-03-2008, 10:19 PM   #18
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
Mine traps 103, 104 with a stock turbo and the usual stage 2 stuff. My ET fluctuates depending on my skill (luck) on any given night, but the traps tend to stay the same on any given night.
I recommend icing the intercooler (yeah, place, not throw, a bag of ice on it between runs.) Here in Florida, runnning on 85 degree night, it's pretty much needed. The sprayer is a lot more effective when the car is moving.
reddoak is offline   Reply With Quote
Old 07-03-2008, 10:36 PM   #19
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
i agree
even it you come off the line like its a stop light you should be trapping way more then that
kevinh211 is offline   Reply With Quote
Old 07-03-2008, 10:48 PM   #20
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Even with a crappy launch you should be running MUCH better than that. With my little pansy 16g on a stock 2.0, I run better times and traps when I screw up my launch. Your shifting could use some practice .
Good luck though, with some practice you could see low 12s, high 11s
Audiosavvy is offline   Reply With Quote
Old 07-03-2008, 11:37 PM   #21
Auto0utcast
Member#: 127684
2004 WRX STi
i actually just found out there was a vid of my best run... heres the link to the youtube...
red c4 vette next to me... intake manifold, ported throttle body, headers, exhaust, intake, cammed... he redlit by .022 and i drove around him...
http://www.youtube.com/watch?v=QBRsK79YYy4
Old 07-04-2008, 12:00 AM   #22
n2oiroc
Member#: 141952
18 golf arrrr!
what rpm are you shifting at?
Old 07-04-2008, 01:33 AM   #23
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Something is definitely up, you should be trapping at least 110.
Also, you're only making 20mph on the back half, which somewhat rules out bad driving effecting the trap.
Likely culprit: 23psi + stock topmount.
As far as the ET goes... your driving needs work, and you need to get the tire pressure dialed to get some consistent launches.
fujiillin is offline   Reply With Quote
Old 07-04-2008, 01:44 AM   #24
impreza_GC8
Member#: 123295
2001 2.5RS w/ EJ257,
6-speed, Brembos
I'm going to say the problem is in the launch. You should be pulling sub 2 second 60 ft times all night long. I can't tell you how to do it as I need to work on my launches as well, but I think that is the issue. Oh, don't miss any gears either!
impreza_GC8 is offline   Reply With Quote
Old 07-04-2008, 02:37 AM   #25
STimo
Member#: 110273
450 whp 30R STI
[email protected]
you have multiple problems, and the first and most important is that ur driving sucks.. If ur clutch was the problem u wouldnt be able to spin ur tires so its not the clutch its the way u drive.. Second even with ur bad driving, u should still be trapping alot faster than 102.. Like others have said u should at least be around 110 even with not good driving, but 102 IMO somethings wrong with the car, weather its because ur running such high boost on pump gas n ur pulling timing or u have a leak of some sort..
So there's a couple things ur going to have to address.. U can practice ur driving and get better but right now I'd worry about why ur trapping so slow.. Datalog the car n see if its pulling timing, if u can't take it to a different shop that tuned it n have em check it out to get a second opinion..
N btw u are leaving a good ~30whp on the table running that tiny stock topmount and STOCK exhaust, most likely more than 30whp.. if u did it right n change it to a FMIC n real catless exhaust from the turbo back I bet ud gain at least 30whp, that crap is restrictive as hell, especialy when u have an upgraded turbo..
STimo is offline   Reply With Quote
