07-03-2008, 11:40 PM | #1 |
Member#: 177036
Vehicle:2003 WRX wagon White |
Will EJ22 and EJ25 Intake Manifolds Interchange???
Hey all. I'm swapping a 2.2 from a 2000 OBS into a 1999 Legacy Outback that had the dual cam 2.5 in it. Obviously, there are some major wiring issues, but I think I can remedy those. Here's my big question:
Can I use the 2.5's intake on the 2.2? I haven't removed the 2.2's yet, but so far they look like they would interchange. Will they?
07-04-2008, 01:55 AM | #2 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
I don't think it will fit. Do you know if the 2000 OBS is a phase 2 2.2 or a phase 1? I can't remember what they had off the top of my head. If it's a phase 1 2.2 it won't fit for sure, I don't think the phase 2 2.2 fits either not sure on that one.
07-04-2008, 11:25 AM | #3 |
Member#: 180958
TXIC
Vehicle:2008 Homemade Yellow |
Nope the 2.5 intake manifold is wider, there is even a difference in the bolt pattern between the SOHC and DOHC 2.5's. Still it is definatly wider than a 2.2 or 1.8
07-04-2008, 12:52 PM | #4 |
Member#: 177036
Yeah, looks like they won't swap. Not the end of the world, but it does create a couple of issues I'll have to address. I'll post a couple pics later with questions as I get into the wiring swap on the top of the engine. But one quick opinion/advice needed:
The end plugs that snap into the injectors is different on the 2.5. So, would I be better to simply swap the 2.5 injectors into the 2.2 manifold (to match the swapped wiring harness) or should I leave the 2.2 injectors and just splice the plugs from the 2.2 harness onto the 2.5 engine harness? (I assume the wiring going into the plugs is the same.) Whatever happens in the end, this is a fun experiment... |
07-04-2008, 01:24 PM | #5 |
Member#: 180958
TXIC
You can take care of the intake by just using your throttle body on the 2.5 manifold. On the injectors, just splice the 2.5 injectors onto your wiring harness. You will need to also splice the temp sensor/guage onto your harness as the 2.2 uses 2 different sensors and the 2.5 is a single sensor with 3 wires. you just wire your old temp sensor to the top 2 pins of the triangular plug, then wire the single guage wire on the bottom pin. Unless the DOHC 2.5 still is using the seperate sensors. then just make sure they plug into your harness, if they dont then splice them. any other questions?
I crammed a SOHC 2.5 into my car I built from scratch about a month ago, I am using a '93 wiring harness and ECU with it. Here are some videos of the car, as well as some pics; http://www.cardomain.com/ride/3088011 http://video.cardomain.com/armigerlives |
07-04-2008, 01:27 PM | #6 |
Member#: 159682
NESIC
It think either way would work on the injectors, but it may be best to keep the same injectors with the same computer. I'm not sure if they are the same cc's and latency. I think they are but not sure.
One other thing here. Count the teeth on the crank sensor wheel/timing belt crank pulley and look at the cam pulleys on both engines. It may be different. |
07-04-2008, 01:33 PM | #7 |
Member#: 180958
TXIC
The injectors may be different, i was looking for a spare and found that the DOHC engines are all shorter than the SOHC, they are unswapable. Also the 2000 SOHC injectors are different AUTO-Manual. I don't know why they just are. That was confirmed by subaru when I called to check.
FREE (sea): ej22 n/a intake manifold | beaconhillkilla | NWIC Private Classifieds | 0 | 05-03-2010 12:16 AM |
04 STI Intake Manifold Interchangable? | jayfressh | Subaru Conversions | 2 | 04-02-2006 10:11 PM |
FS: ej22 and ej22t intake manifolds, $75 each | blackbart | Private 'For Sale' Classifieds | 0 | 12-23-2005 09:43 PM |
Will EJ22 and EJ25 Phase II Cams Swap? | GuyLR | Normally Aspirated Powertrain | 0 | 04-13-2005 12:43 PM |
Need an EJ25 Intake Manifold | gaylemd | Mid Atlantic Impreza Club -- MAIC | 2 | 04-17-2001 07:50 PM |
