Welcome to the North American Subaru Impreza Owners Club Thursday January 19, 2017
Old 07-04-2008, 06:42 PM   #1
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
Unhappy continuous smoking problem
It may be that I just have to burn up the oil within the pipes but my car has had this oil burning smoke blowing out of the exhaust ever since my turbo swap. the car has seen many turbos, but none of those could cause this.
here is the current issue. I just put a temporary td04 on the sti because my fp green is in the mail... I forgot to put a hoseclamp on the oil return line and that solves my oil leak problem but after test driving it for about a 1/4 mile, I had to stop because the cloud behind me got so think cars had to slow down and stop. At idle, with every thump of the motor, a small amount of blue smoke puffs out. when driving (no boost) the puff is now a cloud of smoke. I want to say it is the oil left over in the exhaust pipes but say it isnt. where within the engine block could it burn oil? head gasket? blow by? etc... anyone in the orange county area should come take a look as I will take the turbo off this weekend to prepare for the new turbo
mannyOlicious is offline   Reply With Quote
Old 07-05-2008, 12:32 PM   #2
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
This seems to me to be oil coming from the crankcase, past the rings, and into the combustion chamber.
How is your oil-level doing.
With this amount of blue smoke you are certainly burning engine oil, not some oil thats on/in the exhaust,as that would be gone in about 10 minutes.
Maybe a pistonring, or cracked ringland.
That would be my guess.
Dutch Scooby lover is offline   Reply With Quote
Old 07-05-2008, 12:54 PM   #3
mark19
Member#: 183558
06 wrx
white
im having the same problem but only happens when the car idles down i have only put exhaust cant figure what the problem is
mark19 is offline   Reply With Quote
Old 07-05-2008, 04:27 PM   #4
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
ok so I went to take the turbo off and there was oil in the compressor housing? It cant be a blown turbo... could it be leftover oil from the inlet pipe via breathers w/o a catch can? I am hoping that is the case. the fp green is coming in monday and Im going to slap it on then start the car and let it run in an empty parking lot because the last time I drove it, it was probably for 3-4 minutes.. just around the block. Im hoping its just residue from the oil turbo!! AHH!!
Old 07-10-2008, 04:09 AM   #5
gi2005
Member#: 150531
2002 VF39 WRX
MPB
My vf39 also do that, but it has a fat ass crack on the hot side. While idles, its smokes like a mad man, I was told could be a blown turbo seal, which we'll see after i put in my vf43
gi2005 is offline   Reply With Quote
So, due to continued tranny problems, I am no longer a suby owner BGPunk2001 Texas Impreza Club Forum -- TXIC 41 05-08-2006 01:10 PM
Continued boost problems redrex04 Engine Management & Tuning 4 02-23-2006 12:41 AM
Smoking Problems. Help Please ShaggyGT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 10-12-2005 08:13 PM
HELP! White Smoke Problem...Experts needed blkwag Normally Aspirated Powertrain 7 08-30-2002 03:57 AM
White smoke problem eaalto Normally Aspirated Powertrain 2 08-28-2002 12:11 PM
