Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Old 07-07-2008, 10:12 AM   #1
AMR
Member#: 171509
Default 2005 Legacy GT - AVO 450 / TMIC / TBE / INJECTORS - DYNO PLOT!!!!
Numbers
Dyno: Dyno Dynamics
Tuner: Auto Master AMR
Wheel HP: 309whp (stock 130-140whp)
Wheel TQ: 310wtq (stock 150wtq)
Car Info:
Year: 2005
Engine Management: AMR PROTune (COBB APv2.0)
Turbo: AVO 450 Turbocharger
Intercooler: PERRIN Top Mount Intercooler
Meth Kit: NONE
Injectors: Deatch Works 740cc Injectors
Intake/Inlet: PERRIN Cold Air Intake System
Headers: STOCK
Uppipe: Aftermarket Up-Pipe
Downpipe: Aftermarket Catless 3" Downpipe
CBE: Catless Catback Exhaust
Other Power Mods:
- STOCK Boost Solenoid
- PERRIN Turbo Inlet Hose
- STOCK Fuel Rails
- Walbro 255 Fuel Pump
DYNO SHEET:
Notes:
We were having issues wastegate actuator. From having 5psi and alot of lag, we starting making adjustments to the actuator. After finally getting the vehicle to hold some boost we left it at 19psi. Customer did not want a dyno queen. Just something nice and healthy due to him changing the actuator and adding some meth injection. I believe with the higher boost levels with the meth injection we will see some really good numbers. But again none the less, a good increase over stock with alot left on the table. Nice and smooth RPM band and again, a really smooth AFR.
Power Increase: +170-180whp over stock (safe & conservative)
Tuning Note:
- AFR: 11.2-10.7
- BOOST: 19.5psi
- TIMING: Conservative
- FUEL: 93 Octane
-Rob
AMR is offline   Reply With Quote
Old 07-07-2008, 03:43 PM   #2
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
I have NEVER seen a stock LGT baseline at 130whp-140whp. The lowest was an auto trans at about 170whp, most dyno around 200whp on all types of dynos. You've got some kind of heartbreaker there. What do WRX's dyno, 100whp?
Infamous1 is offline   Reply With Quote
Old 07-07-2008, 03:48 PM   #3
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
Seems inline with their 08 STi. I put down 200whp on a DD too when i was stock.
paikman is offline   Reply With Quote
Old 07-07-2008, 03:57 PM   #4
6star
Member#: 176139
07 LGT LTD
that dyno is a kick in the nutz . better off posting track times. nice increase though. he needs tgv deletes and header to let that turbo breathe
6star is offline   Reply With Quote
Old 07-07-2008, 04:56 PM   #5
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
the 420 has been documented as a laggy turbo, it performs well but spool up is not great.
j255c is offline   Reply With Quote
Old 07-07-2008, 05:17 PM   #6
jim1969
Member#: 34877
2005 Legacy GT sedan
is it a 420 or 450?
jim1969 is offline   Reply With Quote
Old 07-07-2008, 05:19 PM   #7
6star
Member#: 176139
07 LGT LTD
^ the 450 has a larger CHRA than the 420
Old 07-07-2008, 05:21 PM   #8
6star
Member#: 176139
07 LGT LTD
this build is not planned well. running a top mount(w/o meth) with this turbo is not a good choice. AVO recommends a fmic. it needs tgv deletes as well.
Old 07-07-2008, 05:24 PM   #9
Swine
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
yup, alot of lag for not alot of power.
Swine is offline   Reply With Quote
Old 07-07-2008, 06:05 PM   #10
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
if a stock one is going 130hp and the car is making 300 now, thats a pretty damn good increase if you ask me...
my stock sti would do 240whp on the local dyno... thats adding 170 more whp... thats 410...
All4bSpinnin is offline   Reply With Quote
Old 07-07-2008, 06:46 PM   #11
socalLGT
Member#: 89752
08 STI
+1. I can see 160-170whp for a 5MT car on a low reading heartbreaker, but there is no way a healthy 5MT LGT makes 130-140whp bone stock. I've had one factory freak put down 225whp on my Dynojet and while it does read higher than most DD's (depending on user calibration) that is a HUGE delta. Most normal 5MT LGT do about 200-205 whp here. I'd love to see 1/4 times and traps for the car in the original post to see what's really going on.
What were the IDC's? If the dyno is as low reading as the claimed stock baseline numbers suggest that it could be, then 740's would be maxed out right around the power level that car is at right now.
socalLGT is offline   Reply With Quote
Old 07-07-2008, 08:21 PM   #12
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
its true, at there big dyno day. I saw a couple stock sti's lay down 190whp. BONE stock.
The dyno just reads low. not a big deal. my car stock layed down 200whp.
nice gains, not my fav turbo option
SuperSTI is offline   Reply With Quote
Old 07-07-2008, 09:14 PM   #13
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Could be, but an STi doesn't make 70whp more than a LGT. You would of been in the 160-170whp range.
Old 07-07-2008, 09:52 PM   #14
SuperSTI
Member#: 67182
2004 Subaru STi
true but then you have to add in temperature, etc..
doesnt really matter arguing over 10whp lol
Old 07-08-2008, 03:49 PM   #15
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Well it does matter when there is no baseline chart then there is a claim of xxxwhp gain. With the mods listed above, there is no way a 180whp increase would be possible.
Old 07-08-2008, 04:01 PM   #16
AMR
Member#: 171509
Infamous1,
On our dyno with ZERO correction and with the SAE "ON". Stock Legacy's put down what I stated above. In cold weather, i.e. winter, I do see a bump to 150whp but that is the highest I have seen. In this weather, we only see 130-140whp out of the legacy's.
If you would like, no charge, you can have a STOCK legacy come down to our facility and I will dyno it.
Besides, stock is stock. The basline is the baseline. Every dyno is different and every dyno reads different. I post up what ever the vehicle makes. Besides, all of our WHP numbers = our TRAP SPEEDS. Thats all that matters to us. Just do a search.
Lets not ruin this thread by causing drama.
-Rob
Old 07-08-2008, 04:31 PM   #17
wuuusaa
Member#: 92894
2015 Wrx
Great job as always Rob. What were the idc's at?
Old 07-09-2008, 02:41 AM   #18
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
why does HP fall off..on top of that falls off too soon? with that turbo power should keep going.
does the 05LGT have AVCS?
anyways..this car should look similar to this:
same turbo on MY07 STI
http://forums.nasioc.com/forums/show...24&postcount=1
swift2fly is offline   Reply With Quote
Old 07-09-2008, 08:42 AM   #19
AMR
Member#: 171509
Swift2fly,
The HP fall off is from the boost taper. We were having trouble with the IWG actuator. I had mentioned it in the first post.
Nice curve. Numbers look almost similiar.
-Rob
Old 07-09-2008, 09:57 AM   #20
AMR
Member#: 171509
In-case you guys do not already know:
Time: 10am-2pm
Address/Directions: GPNY.com
-Rob
Old 07-09-2008, 11:15 AM   #21
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
^ def will be there for that.
Old 07-09-2008, 12:33 PM   #22
swift2fly
Member#: 70810
07 impreza STi
Originally Posted by [email protected] View Post
Swift2fly,
-Rob
thanks. so does the 05LGT come with AVCS? because the AVO spools quicker on my STi vs. the LGT..according to the graph that is.
sorry i missed that but does this avo450 come with the 15psi wastegate actuator? or am i reading that it came with a 5psi one?
FYI my boost peeks at 23psi but then tapers down to 18psi. on low boost it's a consistant 18psi.
Old 07-09-2008, 02:28 PM   #23
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
^ yes the 05 lgt shortblock is identical to the 05 sti shortblock.
Old 07-09-2008, 02:58 PM   #24
swift2fly
Member#: 70810
07 impreza STi
^???? i never asked about the comparison of the 05 LGT and 05 sti shortblock
Old 07-09-2008, 09:42 PM   #25
IIdiceII
Member#: 90438
why is that SO laggy?
i just got tuned last night on my 02 2.0 wrx with an avo450 and the lag isnt all that bad. its def laggy but i dont think its that bad lol
IIdiceII is offline   Reply With Quote
2004 WRX 2.0L - VF39 / TMIC / TBE / Injectors / Up-pipe - DYNO PLOT!!!! AMR Proven Power Bragging 21 09-26-2008 02:47 PM
COMPLETE PART OUT: 20g, tmic, tbe, injectors, [email protected]@K! VladiWrX Engine/Power/Exhaust 16 06-03-2008 01:46 PM
Legacy GT AVO 20mm Rear Sway Bar Sale Rallitek.com Suspension/Brakes/Handling 0 09-13-2006 02:20 PM
PDXTuning Results: Legacy GT Stage 1, TMIC, and More PDXTuning Proven Power Bragging 30 05-03-2005 10:52 AM
2005 Legacy GT Lawndart North West Impreza Club Forum -- NWIC 4 01-13-2004 03:33 PM
