Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 07-08-2008, 11:56 AM   #1
Bkennedy017
Member#: 71590
Default 6spd into 2002 WRX, Need brake master cyl.?
I'm getting ready to do a 6spd swap to my 02 WRX. The trans and everything is from a 04 STI. Do I need to swap the STI brake master cyl. or will the stock WRX be ok with the STI Brembo calipers?
Thanks for the help,
Brandon
Bkennedy017 is offline   Reply With Quote
Old 08-03-2008, 10:46 PM   #2
jimbo228
Member#: 71600
2010 STI
I have been looking for this answer for a while. I have all 4 brembos on my bugeye and I experence a small "shudder" under light low speed braking. I have had no problems at all at max braking force. I have had three mechanics look at my brakes and no one can figure it out. I was thinking ABS but now i question the master cylinder.
jimbo228 is offline   Reply With Quote
Old 08-04-2008, 01:23 AM   #3
ddd555
Member#: 183405
I was looking for brembos for my GC and they recommended using the sti master so im can only assume the same.
ddd555 is offline   Reply With Quote
Old 08-07-2008, 12:33 AM   #4
gmimprezars
Member#: 183628
00 RS
STM
the sti has a bigger piston
gmimprezars is offline   Reply With Quote
Old 08-07-2008, 07:49 AM   #5
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
Brandon
02-04 WRX MT has the 26.99mm MC
05-07 WRX MT has the 25.4mm MC
04-07 STi has the 26.99mm MC
ownnij is offline   Reply With Quote
Old 08-08-2008, 05:00 AM   #6
SubDubRX
Member#: 155194
2016 WRX Limited
CWP
I have an 02 wrx with complete sti drivetrain swap off of an 05 sti. I didnt change the master brake cylinder everything works fine.
SubDubRX is offline   Reply With Quote
Old 08-08-2008, 03:36 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
A 6 speed swap does not require any changes to the brakes whatsoever.
Old 08-10-2008, 11:24 PM   #8
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
^^ yep why would it ??
sense of nature is offline   Reply With Quote
Old 08-11-2008, 12:15 AM   #9
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
Have a Nice Day? wtf
if you just swapped the tranny and not the rear diff and hubs/knucle, then your right you dont need to change the brakes. but since he did change the rear diff and hubs his old axles will not fit into the sti diff, and sti axles dont fit into the 02 rear hubs. if they did swap that easy then all of the wrx owners would swapp to the sti axles, but life isnt that easy.
so please dont post a comment if you dont know what your talking about.
mikeis300 is offline   Reply With Quote
Old 08-14-2008, 12:18 AM   #10
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
If you will please notice, he said no changes to the brakes, nothing about axles in his post you quoted, as I'm sure we are all in agreeance that when you do a 6MT swap, the brakes/hubs/rear diff go with it, as was stated above.
STimedic is offline   Reply With Quote
Old 08-15-2008, 01:31 AM   #11
mikeis300
Member#: 149526
next time read the whole thread, not just one post. after you have completed such a simple task, you can speak.
Brandon
so let take a look at some key points
1.
im thinking everything means the brakes as well, but let make sure
2.
yep there it is, brembos'. 02Rexboy does the 02 wrx come with brembos, nope didn't think so. im going to make an educated guess and say that he's asking about the brembos he going to put on his car with the swapp.
now its your turn to do something educated.
Old 08-15-2008, 08:27 PM   #12
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
the stock wrx will be ok with the brembo calipers. I had them on my car long before I threw in the 6 speed. if you are swapping the rear end as well you will need the axels and rear brakes too. search a little and you will find a master swap guide.
domestic_abuser is offline   Reply With Quote
Old 08-25-2008, 07:05 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
You can't assume any extra parts were swapped if he didn't include them. A six speed transmission swap DOES NOT require changing any of the following -
front axles*
rear differential
rear axles
hubs
brakes
flywheel/pressure plate/disc
clutch master cylinder
brake master cylinder
*depending on the recipient car he may need axle seals or stubs
His original comment was "The trans and everything is from a 04 STI." This in my mind means transmission + clutch + transmission crossmember + shift linkage. STI brembos could mean 5x100 rotors.
NOW if he said "I am converting my car to use 5x114 hubs with the STI brembos and do I need to change master cylinders" I'd still say no because the brake balance is still fairly close to stock. There is an excel spreadsheet that someone created to calculate this and its not that far off.
Old 08-31-2008, 05:19 PM   #14
mikeis300
Member#: 149526
you know at this point why sugar coat it, you're an idiot. you're giving miss guided advise when you don't know what your talking about. either it's intentional, or you think you know more than you actually do.
just look at what you write.
front axles*
rear differential
rear axles
hubs
brakes
so this guy said his car is a my02, so since he didn't mention swapping his 5 speed setup to a different year, he should still have the factory rear diff. with the 02 rear diff he COULD use a 06 sti trans, but he WILL HAVE TO change the front axels. if he wants to use a early 04(not a late model 04) then he can reuse his axles, BUT CAN'T use his factory rear diff! he will now need to change to a sti rear diff.
if the diff is changed now he can't use the factory axles, he'll need axles from a sti. with sti axles in the rear he cant use the spindle in the stock hubs, so he needs to change the hubs to those from a sti. and of course new hubs means new brakes as the 02 wrx brakes don't fit the sti rotors/hubs.
now lets look at the clutch/fly wheel. if he reuses the wrx clutch and fly wheel he is going to have a much shorter life span on that disk from the heavier gears, and the shorter ratio. also putting a sti tranny into the wrx clutch is a task in it self, you have to make sure that they are perfetly linned up(more so that with a sti clutch) because the threds can become inter locked(cross threding). the lower stature or the wrx clutch/fly wheel makes for less metal to guide in the trany. just do the job right the first time, get the sti clutch.
ok then what is this.
i think that means your assuming.
take your own advise.
RS vs STI Brake Master Cyl (brake probs) DScamp Brakes, Steering & Suspension 3 04-16-2008 06:03 PM
2005 STI motor into 2002 wrx 5spd. NEED WIRING anyone please help navyissuesuby Subaru Conversions 7 08-03-2007 09:35 AM
Currently swapping 04 sti 6spd into 02 wrx, some short notes on the swap mcu81 Transmission (AT/MT) & Driveline 7 02-02-2006 03:02 PM
FS: 2002 WRX Front Brakes, GC8 Stainless Steel brake lines paultg Private 'For Sale' Classifieds 5 11-08-2005 10:10 PM
04 USDM 6spd into 02 wrx, do i need any new crossmembers/tranny mounts? mcu81 Transmission (AT/MT) & Driveline 1 07-18-2005 12:23 PM
