Welcome to the North American Subaru Impreza Owners Club Sunday June 17, 2018
Old 07-08-2008, 01:57 PM   #1
parkes
Member#: 166898
1994 T leg SS
ABM
Default Ej22-ej25
It looks like the wiring on the 2.5 intake manifold wont work on my 94 legacy, ill have to move a couple things from my 2.2 intake but it should work.
Ive tested the connections and such, So My question is even though the plugs plug in and into the injectors will the fact that the legacy being sidefeed altar anything since the ej25 is topfeed, there the same plugs..
parkes is offline   Reply With Quote
Old 07-09-2008, 01:05 AM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
This is what im having a problem with...suggestions?
2 plugs
3plugs from main fuse box
Old 07-09-2008, 07:31 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Take the harness off the original motor (the one that matches your Legacy harness). Then go through the sensors and injectors to ensure the right plug shapes are there. IIRC, the top feed injectors need to have the little locating tab ground down to fit the sidefeed harness plugs, or you can cut and splice, or repin them to match.
Jay Storm
Old 07-09-2008, 07:31 AM   #4
armigerlives
Member#: 180958
2008 Homemade
Yellow
I used my old engine harness so it would plug into my wiring harness. I just spliced in the plugs from the new harness on to my old one. Most likely you will have to use your 2.2 throttle body, in doing so you will have to make an adaptor plate to go between the 2.2 throttle body and the 2.5 manifold. This is easily done. I used a piece of 20 guage sheet metal and made a template for the adaptor off of the 2.5 throttle body gasket. Just do not cut a hole for the port in the top of the gasket. When you are done you should have the 4 holes for your bolts to go through and the large center hole for the air flow. Use permatech to seal the 2.2 gasket on the throttle body side of the adaptor and the 2.5 gasket to the manifold side. Mount the throttle body onto the manifold an your good to go.
Here are some videos of the car I made from scratch and have done this to;
http://www.cardomain.com/ride/3088011
http://video.cardomain.com/armigerlives
armigerlives is offline   Reply With Quote
Old 07-09-2008, 01:33 PM   #5
parkes
Member#: 166898
1994 T leg SS
ABM
Ya ive seen that thing its awesome,
Okay i think im on the right path but im a little confused about the injectors and throttle body, What your saying is swap the harnesses, make a spacer for the throttle body and a ground for the injectors, Cacn somebody clarify a bit?
Old 07-09-2008, 01:37 PM   #6
parkes
Member#: 166898
1994 T leg SS
ABM
Once i get this done, i basically need a clutch and im good to go, thanks
Also i have to split a return fuel line from one to two, no biggy, and a coolant line
And make the piping for the FMIC but its coming along niicely, just finished cutting the bumber beam, that was fun....
Old 07-09-2008, 01:41 PM   #7
parkes
Member#: 166898
1994 T leg SS
ABM
Jay Storm
So easiest route is, Splice the injector wiring (Thats pretty EASY, two wires a piece, or is it three a ground)
Swap the throttle body and make a template than im good to go?
Old 07-09-2008, 02:37 PM   #8
armigerlives
Member#: 180958
2008 Homemade
Yellow
yep basically just change the injector plugs, 2 wires a piece. you may also need to change the plug on the water temp sensor. On the old style it was 2 plugs ( a 2 wire and a single wire). On the new style it is 1 plug with 3 wires. Wire the 2 wire into the top 2 wires iof the triangular plug and the single wire onto the bottom pin of the triangular plug. The bottom wire is your temp guage sensor. So;
1) Make the adaptor for the throttle body
2) splice the new fuel injector plugs onto the old harness (put a piece of tape on one of the plugs on each side so you know which plug goes to which cylinder-VERY IMPORTANT!)
3) Splice in the plug for the water sensor and temp guage.
4) You will need to use the 2.5 coil pack, (unless you want to have custom wires made- ugh!) The 2.5 coil pack has the ignitor integrated with the coil. This means you have to bypass the ignitor that existed in the wiring harness before since it is not needed anymore. Here are the directions for doing so;
Step 1. Cut off connector for ignition coil from 2.5rs harness. save some wiring to extend from 1.8 harness.
2. cut off and throw away 1.8 coil connector (harness side)
3. Wiring. The RS coil uses a 4 pin dark grey connector. While looking at the connector end (female pin side) the pins go simply enough (left to right)- 1 2 3 4
4. At this point you can either de-pin the RS connector and supplement your own female pins with the wire colors of the 1.8 harness to make it easier to look at.
Pin #1 -- Blue/Red wire from 1.8 harness
Pin #2 -- Red wire from 1.8 harness
Pin #3 -- This is going to need to be a wire going to a body ground. Nothing more, nothing less. Just a ground wire.
Pin #4 -- Red/Green wire from 1.8 harness
Obviously soldering these wires together is your safest bet to ensure good wire integrity. Thats that for wiring up the coil. Now, onto bypassing the ignitor from the 1.8 liter.
Step 1. Unplug ignitor
Step 2. Looking at the connector the same way, (female pin side) the pins go 1 2 3 4 5 6 (left to right)
Step 3. Make 2 jumper wires, both sides with male ends that will fit into the pins on the ignitor connector.
Step 4. Jump pin 1 to pin 5
Step 5. Jump pin 2 to pin 6
Leave pins 3 and 4 empty.. There is no wire going to pin 4 anyways..
Thats all I can think of right now. 8)
Old 07-09-2008, 04:22 PM   #9
parkes
Member#: 166898
1994 T leg SS
ABM
Sounds like some great info, except the fact i dont have a 1.8, you mean 2.2 right?
Here are the pics of what i think your thinking of..
your talking about the fact that the coil pack sensor dont match up right?
So i use the wires from my stock ignitor with the 2.5rs coil pack connector correct, since on the 2.5 there integrated and on my 2.2 they are not correct? So all im doing is merging my ignitor wires with the coil pack wires since on my legacy there separate.
Also the Coolant sensor is on the main hardine right? when i looked for it on the 2.5 it wasent there, or is it in a diffrent location?
So this is the coil pack connector right? Also the connection on the intake is just a ground right?
This is my stock coil pack connector, So all i have to do is splice 2/4 wires?
What about this? this isnt on the 2.5 intake manifold?
This is the gorund Storm is talking about, correct?
Can i not just screw it into here on the 2.5 manifold?
Old 07-10-2008, 07:44 AM   #10
armigerlives
Member#: 180958
2008 Homemade
Yellow
k one battle at a time, thats the only way to win the war. 8)
1st does your car have a separate ignitor mounted at the back of the engine bay in the center? If it does then you need to follow the instructions posted above for bypassing the ignitor. You will then splice the 2.5 coil plug onto your old engine harness, there will be an xtra wire which will be the ground. You can ground that anywhere you want.
Yes, in the first picture the black wire mounted to the manifold is a ground.
I suggest taking the 2.5, removing the manifold, then removing the eniring harness from it. Then start routing the 2.2 harness onto the 2.5, you will find that both harnesses are very similar. This will give you a place to start and a visual guide to what still needs to be hooked up.
BTW is this a SOHC or a DOHC 2.5?
Storm was talking about an alternative to splicing in the injector plugs. You can gind down the little ears on the plugs so they will slide over the new injectors. The old plugs have the tabs/ears in a different place. Try to plug in one of the new injectors using one of the older 2.2 plugs and you will see what i'm talking about. I found it easier to just splice the newer plugs onto my older harness.
Lastly with grounds all you have to do is make sure they are grounded. So ground them where you want, just make sure they have a good connection to the metal.
Once you start laying out your 2.2 harness on the 2.5 block it makes good sense, you can see what goes where by the location. Just pay attention when you remove the harness from the 2.2 manifold as to what goes where. I think the injector plugs that have the white tape on the wires by the plugs go tward the front of the engine to cylinders 1&2. When you splice these plugs onto your harness make sure you mark which ones go in front on each side to you dont mix them up.
Lastly, The triangular plug you are looking for on the 2.5 is (looking at the engine from the back) just to the right of the throttle body below the manifold. Once you remove the manifold you will see it. Its the only triangular plug on the 2.5.
Hope this helps
Old 07-10-2008, 07:45 AM   #11
armigerlives
Member#: 180958
2008 Homemade
Yellow
LOL nvm, sry im a retard. I can see from the last pic that it is a SOHC 2.5
Old 07-10-2008, 12:58 PM   #12
parkes
Member#: 166898
1994 T leg SS
ABM
Thanks ALOOT GUYS! You ave no idea how much this means.
The only thing im confused about is this injector thing, The plugs from the sidefeed harness are the same from the 2.5 and the topfeed injectors fit nicely into the 2.2 harness.
Old 07-10-2008, 01:08 PM   #13
parkes
Member#: 166898
1994 T leg SS
ABM
Wow, Nevermind Sorry, i see what you guys mean now, can i just cut that tab out of the way to avoid having to splice any wires
Old 07-10-2008, 01:12 PM   #14
armigerlives
Member#: 180958
2008 Homemade
Yellow
yes you can just cut the tab.
Old 07-10-2008, 01:13 PM   #15
parkes
Member#: 166898
1994 T leg SS
ABM
Sorry im such a noob at wiring, But could somebody clear this up a little for me
Old 07-10-2008, 01:17 PM   #16
armigerlives
Member#: 180958
2008 Homemade
Yellow
ok the first part is the plug that goes to the coil pack, look at the plug with the clip thingy pointing up, splice the plug onto your harness by attaching the wires from left to right. I believe your colors should be the same. The 3rd pin from the left will be the ground so no wire is spliced onto it, just ground that one to a bolt on the manifold.
Old 07-10-2008, 01:22 PM   #17
armigerlives
Member#: 180958
2008 Homemade
Yellow
when I get home from work at about 3:30..... Its 12:20 here now I will take a Video of what you need to do and post it. This will help.
Old 07-10-2008, 03:15 PM   #18
parkes
Member#: 166898
1994 T leg SS
ABM
Thanks, ill do as much as possible up to this point and finish, throttle body and coil pack after they are easy to access witht he maifold bolted up anyways, looking forward to that VIDEO!
Old 07-10-2008, 04:44 PM   #19
armigerlives
Member#: 180958
2008 Homemade
Yellow
Alright then, I uploaded a video that might help. (I hope) Sorry but I'm not the most articulate of people on video, as a matter of fact I am quite bad at the whole filming thing.
Old 07-10-2008, 09:40 PM   #20
parkes
Member#: 166898
1994 T leg SS
ABM
hahaha, i appreciate that man
So where do those three wires from the 2.5 coil pack harness go?, spliced into my old coil pack connector?
Than the ignitor had two wires that are jumped just to send the signal back to the ECU to avoid CEL?
Old 07-10-2008, 11:11 PM   #21
armigerlives
Member#: 180958
2008 Homemade
Yellow
you splice the 4 wire plug for the 2.5 coil onto your 2.2 harness. The 2.2 is 3 wire so you follow the instructions above for them;
The 4th pin is just a ground like I showed on the vid. You just ground it somewhere. Look at the coil plug on the video and you will see the plug wires.
Old 07-11-2008, 01:14 PM   #22
parkes
Member#: 166898
1994 T leg SS
ABM
So i couldnt find this plug on the 2.5 manifold..
Old 07-11-2008, 01:44 PM   #23
armigerlives
Member#: 180958
2008 Homemade
Yellow
Hmm, I'm not sure. Looks like some sort of pump. Oil maybe? Take a picture from away so I can see the placement on the engine and what is around it. That would help me see what is different.
Old 07-11-2008, 04:26 PM   #24
parkes
Member#: 166898
1994 T leg SS
ABM
Its Actually for coolant, instead of coolant coming/ going from the main hardline it would be going through this with an air inlet from the intake
Old 07-11-2008, 04:26 PM   #25
parkes
Member#: 166898
1994 T leg SS
ABM
im going to go take it off quickly...
Dual port EJ22 heads VS single port EJ22 heads FuJi K Normally Aspirated Powertrain 23 05-06-2004 12:39 AM
USDM EJ22 vs. JDM EJ22 kgeil Subaru Conversions 0 02-22-2004 12:28 AM
will a 96 EJ22 fit in a 97 EJ22 impreza?? mybluesubi Subaru Conversions 20 02-20-2004 03:47 AM
Why does older EJ22 have less power than new ej22? d4d4d4d4 Legacy Forum 16 12-25-2003 09:18 PM
Why does newer ej22 have more power than older ej22? d4d4d4d4 Engine Management & Tuning 7 10-09-2003 11:21 PM
