Welcome to the North American Subaru Impreza Owners Club Tuesday June 19, 2018
Old 07-10-2008, 02:04 PM   #1
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
Default Way to much Lag
So I went to get the car tuned Monday at xxtuning. 05 STi stock long block with a rotated gt35r .82. We stopped at 411 whp on 93 oct. because the lag is so bad. I don't see full spool until like 5300 or maybe even higher, which sucks . It has a stock header on it. Anyone have any thoughts on this? I realy don't want to buy another turbo right now, but something has to be done
JTPerryR1 is offline   Reply With Quote
Old 07-10-2008, 02:07 PM   #2
fobiawrx
Member#: 91074
04 sti
white
you got a leak. go over your exhaust and make sure its all tight and sealed.
fobiawrx is offline   Reply With Quote
Old 07-10-2008, 02:15 PM   #3
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
+1 So you have stock headers, I would think its one of the 2 gaskets from either Header to Up-Pipe or Up-Pipe to turbo.
tux121 is offline   Reply With Quote
Old 07-10-2008, 02:47 PM   #4
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
All brand new. No leaks. Its the first thing we checked
Old 07-10-2008, 03:00 PM   #5
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
^ Stock motor is your answer. I got cams and 8500rpms of room and lag isnt in my vocab!!!!
drewwrxrogers is offline   Reply With Quote
Old 07-10-2008, 03:04 PM   #6
Digmaster
Member#: 183951
04 WRX Ej205
Built & Rotated 50trim
What are you using for boost control?... Also did you guys try and lean it out in the lower rpm's to try and raise exhaust temp to try and spool it quicker..... Also is this only in the lower gears?....It does sound like a exhaust leak however.
Digmaster is offline   Reply With Quote
Old 07-10-2008, 03:05 PM   #7
fobiawrx
Member#: 91074
04 sti
white
what exhaust is on the car? have you pressure tested the whole system? intake too?
Old 07-10-2008, 03:09 PM   #8
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
I'm comparing to other similar setups. We overlayed my dyno chart with others and mine looks horrible. Most gt35rs have full spool at 4700-4800 and I'd be happy with that.Hardly any boost in 1st gear. I have a haliman manual boost control. we got up to 22 psi. Chris did try to lean it out some and give it some timing, but didn't go crazy.
Old 07-10-2008, 03:11 PM   #9
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Please list all modifications:
Old 07-10-2008, 03:13 PM   #10
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
3" all the way back. when its on boost it holds it to the rev limiter, so I don't think there are any boost leaks.
Old 07-10-2008, 03:17 PM   #11
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
05 sti stock longblock,cams and header. gt35r .82,txs front mount,ultimate racing 1000s and rails,aeromotive fpr, tgv deletes,all 2.5" intercooler piping, tial bov,perrin big maf, slowboy up and down pipe, tial 44, halliman mbc. tuned w/ cobb ap v1
Old 07-10-2008, 03:22 PM   #12
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Timing should be retarded to increase spool along AVCS timing advanced.
Infamous1 is offline   Reply With Quote
Old 07-10-2008, 03:27 PM   #13
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
He did retard the timing, maybe I worded that wrong. He didn't want to go to far, because It was getting worse off boost. He did spend about 4 hours on it.
Old 07-10-2008, 03:30 PM   #14
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Check compression, do a leakdown, check to makesure the BOV isn't leaking. Go back to a EBC. Check turbo, make sure its spinning freely and isn't eating oil.
DoctorNick is offline   Reply With Quote
Old 07-10-2008, 03:34 PM   #15
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
We put a brand new tial bov on it while I was there, because mine was leaking.I checked the turbo yesterday, spins free and no oil. Haven't checked compression yet, but the car sounds good.
Old 07-10-2008, 03:36 PM   #16
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
Will the boost control have that much effect on spool?
Old 07-10-2008, 03:39 PM   #17
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Boost control will help you get to your target boost as fast as possible and help bleed boost to keep you at the target. I never cared for MBCs, i know a lot of guys run them with no issues though.
Just because a motor sounds fine doesn't mean you don't have a leaky valve. Also, are you EWG? Might wanna check that too. I have seen those tials go bad. Especially the 38mm ones.
Old 07-10-2008, 03:39 PM   #18
wrxwhat
Member#: 87653
97 Supra / 17 GTR
16 Z06 / 07 STI / 05 Evo
my car seemed to lose quite a bit of 'spool time' (laggier) when I went from a Hallman MBC to the Greddy Profec B.. even adjusting the gain perfectly.
wrxwhat is offline   Reply With Quote
Old 07-10-2008, 03:47 PM   #19
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
At 4700-4800rpm what are your afr's???? You could add fuel with the retarded timing and that might help a little. What intake set-up are you using, is it a 3" inlet on the turbo???
icslowmo is offline   Reply With Quote
Old 07-10-2008, 03:59 PM   #20
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
If u dont have any mechanical issues with the car then you need to find someone else to tune it.
Token-Negro is offline   Reply With Quote
Old 07-10-2008, 03:59 PM   #21
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
Perrin big maf,turbo is a 4" inlet. I think Chis did what he could with fuel and timing .I'd say like mid 11's at 4700-4800 and about 10.6 at full boost.At the downpipe.
Old 07-10-2008, 04:10 PM   #22
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
By the way is anyoneelse running ultimate racing injectors with a stock ecu.Tuner says they are for stand alones only, and I still have some stalling problems with them.
Old 07-10-2008, 04:15 PM   #23
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
That is a ludicrous statement your tuner made. Sounds like you need to find a new tuner.
I know guys that have near perfect idles with UR1kcc injectors.
Old 07-10-2008, 04:19 PM   #24
JTPerryR1
Member#: 163361
05 STI 9.24 @ 150
15 silver STI
Thanks for that doctor Nick. He said my injectors were the worst thing I did to the car,a huge mistake. Also the funny thing was, after the first pull on low boost, I could have sworn he said I had full boost by 4800,which I expected.Then all of a sudden it was mid 5000s.It just seemed like he was so negative about everything I had.
Old 07-10-2008, 04:33 PM   #25
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Did you get your parts from or have them installed by your tuner?
kharris4 is offline   Reply With Quote
WAY to much boost. Help with GMBCS Beeya Engine Management & Tuning 10 03-10-2007 08:33 PM
This is way to much for a filter. evilnissan Off-Topic 16 11-09-2006 08:04 PM
Way To Much Boost!!! subwrx03 UTEC 6 06-25-2006 10:17 PM
Best Ways To Reduce Lag? kharris4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-12-2004 05:15 PM
