Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 07-16-2008, 03:51 PM   #1
matty50racer
Member#: 166668
Default [email protected] TD04 bugeye
This was my second time at the track with this car, I'm still getting used to launching an AWD car verses my mustangs with slicks. The car is self tuned by me using ecuflash/romraider on 93 octane gas. The car has TGV deletes, Tial 38mm EWG, catless downpipe/up-pipe, Home-made CAI, and LGT 1-2 gears. I think the stock intercooler and cat-back are realy holding this car back. DA was about 1,500 feet during this run. Is this a good time for my mods?
R/T - .121
60' - 1.85
330 - 5.376
1/8 - 8.358
mph - 81.8
1000 - 10.952
1/4 - 13.168
mph - 101.65
matty50racer is offline   Reply With Quote
Old 07-16-2008, 04:46 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Not bad at all for second time at the track. Near sea level we have several folks that have gotten into the high 12's on the stock turbo, so there is a little more to be had there if you want to go for it, but that is a very respectable run.
See my sig for my best time on the stock turbo at 5800 ft altitude DA about 7800 ft.
Larry
hotrod is offline   Reply With Quote
Old 07-16-2008, 04:47 PM   #3
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Very impressive from the 2 liter with that baby turbo!
Infamous1 is offline   Reply With Quote
Old 07-16-2008, 05:23 PM   #4
jason miller
Member#: 158313
2003 WRX
Your 60' time isn't bad, but with a 1.7ish 60' you might be looking at 12's- especially if you upgraded the intercooler and catback and then retuned for them. Running 12's on the stock 2.0 and TD04 is a pretty good benchmark.
jason miller is offline   Reply With Quote
Old 07-16-2008, 05:32 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
td04s rule..def are capable of high 12's
oppositelock has a mid 12 second td04..insanee.
mxpunk is offline   Reply With Quote
Old 07-16-2008, 05:45 PM   #6
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I keep telling people EWG's rock on stock turbos. No one believes me, haha.
zeropsi is offline   Reply With Quote
Old 07-16-2008, 06:04 PM   #7
mattminer
Member#: 90642
WKD Everything
i do. IWG ftl
[email protected]
mattminer is offline   Reply With Quote
Old 07-16-2008, 06:06 PM   #8
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
not bad man! i have gone 13.3 with just an intake /tbe / and a rom raider tune. i bet with good cold air and a prep. track you'll see 12's.
boostdog is offline   Reply With Quote
Old 07-16-2008, 07:02 PM   #9
matty50racer
Member#: 166668
Yea it's kinda harder to launch the car with the LGT's 3.18 first gear but it keeps me in the powerband after the 1-2 shift. I want to try 205/45-16 tires to give some more torque on launch and a cutout for faster spool and a little more top-end. I should easily be in the 12's with just some better air and those small mods.
Old 07-16-2008, 07:05 PM   #10
wrxroberts
Member#: 150399
05 CGM Sti
BeyondReflections.com
nice run. my buddy(wrxdrivr04) went [email protected] and 12.9 with a .001 red light(though it didnt count against his time since it was time trials) on a stage 2 tune. props tuning your own car
wrxroberts is offline   Reply With Quote
Old 07-16-2008, 07:22 PM   #11
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
It's hard for my STi to run 12's in Minnesota lol
tux121 is offline   Reply With Quote
Old 07-16-2008, 07:42 PM   #12
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Yeah tell me about it, I dream of 1.7 60fts....
Old 07-16-2008, 07:52 PM   #13
rsw0124
Member#: 173013
..08 AwwGrr FTW!
[email protected]+ft ^sea level
[email protected] is great run. Open up your exhaust and change the intercooler, and you def. got 12's, and your trap speed shouold go up too. What are your afr, timing, and boost set at?
rsw0124 is offline   Reply With Quote
Old 07-16-2008, 08:03 PM   #14
matty50racer
Member#: 166668
I had a 1.82 60' earlier that same day but tried short shifting at 6,500 and the car didn't like it running [email protected]. I never have any luck trying to watch the tack while launching, it always ends up with a boggy 1.9-2.0 60'. I just stab the throttle fast to get the turbo spooling and slip the clutch out between the 2nd and 3rd yellow light. Rpm's drop to about 5,000 and I shift into 2nd at 7,000 and make the 2-3 and 3-4 shifts at 6,800.
My calculations show the smaller tires would give me the same effective 1st gear ratio as stock but make the rest of the gears slightly shorter. Hopefuly it doesn't just spin and I rocket off to a 12 second run.
Old 07-16-2008, 08:09 PM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
It's ironic as I'm running IWG, but that's mainly because my car's a test mule for some new Tomei parts, and what do you know, the uppipe doesn't support EWG in stock form.
Old 07-16-2008, 09:21 PM   #16
matty50racer
Member#: 166668
I noticed the motor was pulling ~10 more G/S with 1psi less boost in logs after I installed the EWG. Plus I love the sound
Old 07-16-2008, 09:45 PM   #17
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
congrats on the nice runs,.. keep at it 12's are just around the corner!
My best td04 run so far is [email protected] 107mph
Did you say stock catback?!? WTF! Ditch that thing quick super restrictive....
My runs were on stock intercooler so I think it is up to the task,... I actually think it hurt me when I upgraded intercoolers due to the larger volume the small turbo has to fill.
jmlaser is offline   Reply With Quote
Old 07-16-2008, 11:56 PM   #18
zeropsi
Member#: 175453
AE86 GT-S coupe
I hope after Tomei is done collecting all the data/logs from my car, I can go EWG. My setup's too stealthy as it is.
Old 07-17-2008, 01:02 AM   #19
matty50racer
Member#: 166668
Yea stock cat-back. I'm not sure if I want to get 3" cat-back or just weld a cutout into the downpipe for track use. 107 is flying on stock turbo! I think I could pull more out of it flat-foot shifting but I don't want to shatter my trans again.
Old 07-17-2008, 02:13 AM   #20
matty50racer
Member#: 166668
Sorry I missed this the first time I read your post. AFR are in the mid 11's. Timing is conservative at ~15 at max load going up to 30 at 7000 rpm showing no sign of knock. Boost peaks at 18psi and tapers to 12.5.
