Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 05-17-2010, 08:33 PM   #1
Pinned
Member#: 152707
Default 2008 STi 6 speed into RS?
I'm looking at a 2008 STi 6 speed locally. Is there any reason that it wouldn't mate up to my swapped RS (2000 RS with a 2004 WRX swap) the same way a 2007 or earlier STi transmission would? I have the opportunity to buy the entire driveline (transmission, rear diff, driveshaft, mounts, axles, hubs, brakes, etc). Also, would I need to get an aftermarket DCCD controller, or could I use the stock 2008 setup?
Are there any complications I'm overlooking (that are different from a 2007 or earlier swap)? Also, if I wanted to keep all my 5x100 hubs/suspension/wheels/etc, would I just use different axles?
Thanks for any help!
Pinned is offline   Reply With Quote
Old 05-17-2010, 08:40 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
VSS. The 2008 has none.
Old 05-17-2010, 10:16 PM   #3
Pinned
Member#: 152707
Hmm, so is there any way to overcome that and have a working speedometer? If so, will the transmission physically fit up fine?
Old 05-18-2010, 01:22 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Physically, they fit fine. No different than 2004-2007 boxes. The VSS issue is being worked on by a few people. I think DCCDPro may be working on something.
Old 05-18-2010, 02:00 AM   #5
Pinned
Member#: 152707
I may be able to get the whole dash, or at least the cluster and harness if that makes any difference. How does the speed sensor on the 08+ cars work? Thanks for the help so far.
Old 05-18-2010, 03:27 AM   #6
kpluiten
Member#: 120273
06 WRBWRXWGN
They pull the signal from the ABS/traction control setup in those cars as far as I understand.
Old 05-18-2010, 05:58 PM   #7
Pinned
Member#: 152707
I emailed Jeff at DCCDPro, seems like he's working on the controllers but they aren't quite ready yet. I think I'm going to continue looking into this, are there any potential issues other than my speedometer not working?
Old 05-18-2010, 06:58 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
I don't know. Does your ECU use the speed sensor for anything else?
Old 06-15-2010, 02:14 AM   #9
Ducati593
Member#: 249442
2006 wrx limited
black
is there any updates on the speedometer problem with the 08 tranny swap to older models?
Ducati593 is offline   Reply With Quote
Old 06-15-2010, 08:08 AM   #10
DCCDPro
Member#: 227549
Shipping the VSSPro prototype out tomorrow to the first beta tester.
I had to build a second one so that we would have parallel systems in case I need to make changes and send firmware updates.
It looks so good on the the oscilloscope though....I'm very very close to having a viable solution to this!
One extra bonus with it....you can adjust your speedo to make it more accurate or for for different tires.
DCCDPro is offline   Reply With Quote
Old 06-17-2010, 09:18 PM   #11
Pinned
Member#: 152707
Awesome. I hope all the testing goes smoothly.
Old 06-17-2010, 10:38 PM   #12
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Pulled this from an old post that I made...
I was curious so I started looking to see if it would take a speedo gear.
'07 sti
08'sti
Maybe there is a plug there, just needs a gear installed...
#11 is the speedo drive gear on the '05-'07
Don't see it on the '08 plus but one may be able to be installed. Looks like it is installed on the lsd itself, hopefully its still keyed for the gear, part # appears to be the same.
It appears that you could put a speedo gear into an 08 but you'd have to use an 07 diff or get the speedo drive gear and install it on your 08 diff...
Hope it helps...
theotherguy is offline   Reply With Quote
Old 06-20-2010, 09:10 AM   #13
DCCDPro
Member#: 227549
I think there was a lot of chatter about this here when the 08's were first seen in '07.
The bellhousing had to be machined or replaced, and the speedo drive gear added as well as the speedo pickup.
There is no plug in the new bellhousings....it would have to be machined into the case.
(And the gear added p/n #11 in your picture.)
The gear can be added, but for the case machining it is a bit difficult to get the hole location and size accurate enough.
On the other side of the problem....
VSSPro "Prototype #1" has been delivered the customer in Michigan who is trying it out. (!)
He is putting his car back together in the next week or two. It is an 08 tranny as well, I'm anxious to see how the testing goes. Hopefully very well and we can move forward with these 08+ tranny's without modification. It would be nice to be able to use the new tranny's. Unfortunately I have a feeling their price will jump up a bit one they are usable, right now good deals can be had on the 08+ tranny because they are a pita and few people who need them can use them.
Old 06-20-2010, 04:42 PM   #14
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Good info, wasn't sure if the pic was accurate or not for the '08 STI speedo plug on top of the bell housing.
Regardless, your product would save a lot of time and work. Hope it works out.
Old 06-20-2010, 06:58 PM   #15
Pinned
Member#: 152707
I'm very excited to hear how the initial testing goes. I've been seriously looking at a few wrecked 08+ cars (so I could buy the transmission).
Are you planning to incorporate the DCCD controller and VSS controller into one unit in the future?
Old 06-21-2010, 01:32 AM   #16
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
That would be kinda a cool idea kill two birds with one stone when getting an 08+ 6speed.
181stLeader is offline   Reply With Quote
Old 06-21-2010, 09:24 PM   #17
DCCDPro
Member#: 227549
I actually don't think I'll incorporate them in one unit due to the amount of processing going on in the VSSPro and the processing load on the microchip when it is doing digital signal processing.
You'd be surprised how much processing power it takes to analyze the ABS signal and then convert it to a different signal entirely that the ecu and speedo to work with. (All accurately and over a widely varied input frequency.)
I think it's better to have a dedicated processor to do each job.
That's ok though, I'm thinking about a package deal for customers that need both products.
I got a call this afternoon from the beta tester, he's got the prototype unit and the car is going back together in the next few days. Looks like we will have some feedback soon (good or bad).
Old 07-05-2010, 11:56 PM   #18
Pinned
Member#: 152707
Any updates on the testing? I hope it's going well!
Old 07-06-2010, 01:59 AM   #19
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
So much trouble.
a simple '04-'07 6spd would be much more simple and still work.
Old 07-06-2010, 07:17 AM   #20
DCCDPro
Member#: 227549
The problem is that the 06/07 tranny's aren't as available as they were.
The wrecked ones are harder to find, and new ones form Subaru are dwindling in numbers. I've been told Subaru is shipping reman's already. Maybe someone with access can let us know what the real stock is like as it is today but I've heard single digits of stock for brand new 07 tranny's.(?) (Don't forget that is a 4 year old tranny now.)
You are right it is/was a lot of work. Developing something like this takes a lot of time and effort to do on your own.
The end result for the customer will be a few wires clipped in at the ecu and a box the size of an Altoids case that does all the work. As well it will be able to adjust for different tire sizes / speedo recal as well if you need it to.
It is just about there, I will likely get a call from the beta tester this week if he has been able to get the car back together. I need that feedback to clean up the finished product and make any last minute program changes.
It isn't easy to find anyone with an 08 tranny that is swapped in to an earlier chassis...
If this works out, the '11 tranny's are then compatible with everything back to the early 90's!
Old 07-06-2010, 07:59 AM   #21
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
That. Is. Awesome.
OrbitalEllipses is offline   Reply With Quote
Old 07-07-2010, 05:48 PM   #22
Pinned
Member#: 152707
Originally Posted by FuJi K View Post
So much trouble.
It's worth the trouble like DCCDPro noted. I personally don't want to spend a lot of money on an older transmission with high mileage.
Thanks for the update DCCDPro! Best of luck getting it all finished up though.
Old 07-07-2010, 10:22 PM   #23
DCCDPro
Member#: 227549
I spoke with our tester today, no it's not the STIG...for those who are guessing.
He's getting there, we just have to be patient....he got his short block back today so we will get some info soon. I already have some feedback that it will have to be wired in slightly differently than I was hoping for. All is good though so far. I'm just thankful to have someone willing to test it all out!
In the meantime I have some time to work feverishly on other projects that have taken way too long to get done. I been up past midnight and back at it with only a few hours sleep for a several nights in a row now.
DCCDPro -> USB "Tuning" is pretty much done! I have to iron out some of the final product details but it is fast and really solid. I've written an app for doing everything adjustment wise, but I'm going to also release the communications specs so people can program their own app and or run it on a carpc.
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 811 12-02-2016 08:36 AM
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 03:02 PM
How to put a 2007 usdm sti 6 speed into my 2003 WRX InfamousDX Transmission (AT/MT) & Driveline 11 10-27-2007 01:54 AM
Sti 6-speed into a GC questions??? handyRS Transmission (AT/MT) & Driveline 0 06-13-2007 03:43 PM
USDM STI 6-speed into USDM WRX? hobbzz Transmission (AT/MT) & Driveline 12 01-12-2003 04:26 AM
