Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 07-20-2008, 03:54 PM   #1
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
Default Precision tuned Donmiator 2.5r (retune)
Well let me just start off the Team at Precision is hands down the best all around. Big thanks to everyone. My car is self wrenched and i couldnt be happier with the outcome. The day went very well besides the awful heat, i believe it was 98 outside. The cars computer kept pulling timing that we added up top due to the high intake temps so we needed to let the intake cool off a couple times before we could make pulls. The car made 399awhp/394awtq on 23psi on pump 93. Holds 21psi to redline and just pulls forever. I am extremely happy with the 2.5r even tho it spools later then the 3.0r. Once again big props to melo and the whole precision Crew Next mod 6spd swap and more boost .
Heres the dyno chart, mod list ect.
Mods
Blouch Domiator 2.5r
Tial 44 ewg
Ur EWG Up pipe
Perrin Header
Aquamist HFS-5
PE 800cc injectors
255 Fuel pump
Perrin SRI
Gimmick inlet w/ maf hose
Perrin Fmic
Stock BOV
Invidia Catless DP
Hks Hi power exhaust
Cobb AP V2 Tuned
I might be forgetting something
07stg2Wrx is offline   Reply With Quote
Old 07-20-2008, 04:00 PM   #2
sjs0433
Member#: 86061
Why does this one spool slower than the 3.0r? I thought the 2.5r was a smaller turbo but still had the same ball bearing center section?
Awesome numbers nonetheless. That thing has got to roll out.
sjs0433 is offline   Reply With Quote
Old 07-20-2008, 04:55 PM   #3
jazmak24
Member#: 171920
06 sti
aspen white
very nice #s,congrats!
jazmak24 is offline   Reply With Quote
Old 07-20-2008, 05:13 PM   #4
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
thanks guys
Old 07-20-2008, 06:47 PM   #5
iTSTi
Member#: 88096
Nice car with good #s!! You are looked a lot better in person @ Precision. I was the guy with the black 06 STI there that day.
Precision is just awesome!
iTSTi is offline   Reply With Quote
Old 07-20-2008, 06:48 PM   #6
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
how did ur sti make out on the dyno did the wg spring work for you
Old 07-20-2008, 07:29 PM   #7
iTSTi
Member#: 88096
Yea. The spring works! The dip in AF is gone. The car made a little more than 400. I am very happy~ Have fun with your car.
Old 07-20-2008, 07:38 PM   #8
wRxbeater11
Member#: 12682
What up man good seeing you guys down at the shop again. Car looks great as it always does.
Melo
wRxbeater11 is offline   Reply With Quote
Old 07-20-2008, 07:58 PM   #9
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
thanks for the compliments im sure it wont be my last trip down there
Old 07-20-2008, 10:19 PM   #10
sutter2k
Member#: 92467
08 STI
+1 I have this same turbo and its spooling a lot sooner.
Though, I have IWG, Top mount, and running 19 psi(pump), 22(meth--currently being serviced my aquamist).
You are making more power than me though.
sutter2k is offline   Reply With Quote
Old 07-20-2008, 10:45 PM   #11
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Your car looks awesome... Keep in mind I have the orange piping waiting for you~!! LOL
WRX4eva is offline   Reply With Quote
Old 07-21-2008, 12:22 AM   #12
Auto0utcast
Member#: 127684
2004 WRX STi
that is EXTREMELY late spool. good peak numbers but i would have expected spool earlier than 4k.. not 4500+... check for pre-turbo exhaust leaks... and the fire-ring in the EWG. something just doesnt seem right.
Auto0utcast is offline   Reply With Quote
Old 07-21-2008, 12:46 AM   #13
STINOMORMONEY
Member#: 183029
2007 STI- 402whp/436
OBP- uncorr./SAE-Mustang
keep in mind everyone peak torque (which the graph shows) is not peak boost, peak boost usually occurs around 500 rpm before peak torque
that said it looks like it is still late for that turbo- so checking the exh gaskets ^^^^ might be a good idea
STINOMORMONEY is offline   Reply With Quote
Old 07-21-2008, 12:47 AM   #14
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
i have checked no exhaust leaks what so ever im a lexus tech and im always looking over my car nothing noticeable. What cars are you compairing spool to, are the mod list similar to mine?
Old 07-21-2008, 12:50 AM   #15
STINOMORMONEY
Member#: 183029
in what gear
Old 07-21-2008, 12:51 AM   #16
STINOMORMONEY
Member#: 183029
the graph doesnt support full spool at 3900???
more like 42-4400
Old 07-21-2008, 12:56 AM   #17
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
What gear 3rd or 4th?
rexworx is offline   Reply With Quote
Old 07-21-2008, 12:58 AM   #18
Auto0utcast
Member#: 127684
2004 WRX STi
the 44mm ewg is a v-band flange is it not? there is a "fire-ring" or o-ring seal that seals this flange. if its not in there you could be leaking and not even know it.
Old 07-21-2008, 12:59 AM   #19
STINOMORMONEY
Member#: 183029
^^^ true
Old 07-21-2008, 10:25 AM   #20
07stg2Wrx
Member#: 154901
2007 Dom 2.5rrrrr
Slow> 400awhp
3rd gear pull, but im more or less wondering about this o ring i bought this wastegate new and installed it any more information on it? Im using a turbosmart mbc to the bottom port and the top port of the wastegate is vented
Old 07-21-2008, 02:48 PM   #21
import111
Member#: 24447
2016 Mustang GT w/PP
Red
Power is definitely coming on way late for that sized turbo. Hits 200whp after 4K rpm which is GT30R or bigger lag. I would guess something is wrong.
Edit: Actually I just noticed they started the pull at 3K rpm. Start a pull earlier in the rpm range and see if boost comes on earlier.
import111 is offline   Reply With Quote
Old 07-21-2008, 05:09 PM   #22
benw
Member#: 103320
1998 swapped
Forester L
that definitely isn't spooling as quickly as my friend's 2.5R that he installed on his Legacy GT. He initially had problems with the first version which had excessive porting on the internal wastegate passage, causing it to blow open too early, but the second version turbo fixed it, and it performs well.
benw is offline   Reply With Quote
Old 07-21-2008, 07:32 PM   #23
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
How are you guys commenting on spool? The dyno readout only has power and torque plots?
wrxsti.l is offline   Reply With Quote
Old 07-21-2008, 07:37 PM   #24
protein
Member#: 86500
Nice #s. Precision does nice work.
protein is offline   Reply With Quote
Old 07-21-2008, 09:00 PM   #25
STINOMORMONEY
Member#: 183029
we are assuming full spool comes on around 500 rpm before peak torque
07 WRX Blouch 2.5r EFI tuned jryan87 Proven Power Bragging 26 04-14-2009 09:39 AM
Precision Tuned 07 wrx Dom 2.5r 07stg2Wrx Proven Power Bragging 70 07-09-2008 12:15 AM
Precision Tuned 2.0LWRX VF43 293hp/275 JMS77 Proven Power Bragging 13 05-11-2008 12:24 PM
Cobb Stage 2 + Precision Tuning (shop) kevin2.5rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-01-2005 03:35 PM
precision tuning today 2/26/05 crazyboardr8806 Tri-State Area Forum 0 02-27-2005 01:26 AM
