Welcome to the North American Subaru Impreza Owners Club Sunday May 20, 2018
Old 07-21-2008, 01:15 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default 07 STI Motor Swapped in an 05 WRX W/PPG Straight Cut Gears! 1/4 Mile Times & HP/TQ
Car 2005 WRX
STI Motor Swap including 07 STI ECU with working AVCS
5 speed PPG Straight Cut Transmission Set Up
Cobb AP
Perrin TMI
700cc Injectors
255lph Pump
TBE
Uppipe
K&N Intake
Stock VF43 Turbo
93 Pump Gas
Dyno numbers on a Dynopack
340 tq at 3850 rpm
322 whp at 5722 rpm
Time Slip
.0472 RT
1.8125 60ft
8.21 1/8
83.47 mph 1/8
12.8012 ET
106.94 mph 1/4
The car is tuned at 20psi
Also note that I am running -3deg of front camber and -2deg of rear camber. Tires were 35 psi front 37 psi rear. Tires were Dunlop 245 Star Specs. The car is used for time trials not drag racing just wanted to see what it would do.
mrtrex is offline   Reply With Quote
Old 07-21-2008, 01:26 PM   #2
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
240 lbs/ft? Sure it's not a typo?
60' has a bit of room to improve, but ET and trap look in line with each other,
zeropsi is offline   Reply With Quote
Old 07-21-2008, 01:37 PM   #3
mrtrex
Member#: 12223
2005 WRX
Fixed, it is 340 tq lol! I think the 60ft would improve if I did not have -3 degrees of camber in front and - 2 degrees in the rear. I would spin through most of 1st than spin on 1-2 shift.
04-05 WRX/STi Zerosports CF Grill nightcrawler60 Private 'Wanted' Classifieds 2 08-29-2010 08:29 AM
WTB: wrx/sti Radiator ASAP !! 02NWbugeye NWIC Private Classifieds 8 07-08-2010 07:42 PM
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
