Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 07-21-2008, 10:31 PM   #1
soccerdommer
Member#: 144826
2004 WRX
Default How much is too much?
So i am swapping my auto out and putting in a 5 spd manual transmission in my 1999 2.5RS. I found a deal with a guy that has all the parts that I need for $600 and it has 148k miles on everything...I was talking to my dad and he thinks that is way too much mileage on parts to put into the car. If I was to buy all of this what kind of things should I ask the seller about the parts? If I buy it, would I want to get the tranny checked by a tranny specialist?
This is the list of the parts:
Manual Transmission
Manual Transmission Mounts
Shifter Assembly (shifter, plate, gasket bushings)
Shifter Linkage
Manual Drive shaft
Manual Rear Differential
Clutch Cylinder(s)
Manual Clutch/Brake Pedals/Box
Manual Transmission Starter
Clutch Cable if not hydrolic
Manual Transmission ABS Module
soccerdommer is offline   Reply With Quote
Old 07-21-2008, 10:42 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
i wouldnt think 148k miles would be bad for a tranny, just check the input shaft bearing. If the input shaft moves alot, might not want to buy it.
You could get the tranny checked out, hopefully it wouldnt be too expensive, never had that done, so I dont know about the cost.
~Josh~
Old 07-22-2008, 12:18 AM   #3
parkes
Member#: 166898
1994 T leg SS
ABM
i got a tranny from a 98RS with 80,000km, along with a diff, rear crossmember, clutch asemmbly for 400$ so ya its a little high, try to get down 100$ to 200$
parkes is offline   Reply With Quote
1. Can you drink too much green tea? 2. If so, how much is too much? crowbar Off-Topic 32 10-19-2006 11:24 AM
What is the biggest pro/con of more caster? How much is too much on a WRX suspension? rex n effect Motorsports 6 06-20-2004 10:05 AM
Clutch rollover/tickover- how much is too much? beachbum Normally Aspirated Powertrain 0 05-16-2001 09:41 AM
How much is too much? (Remote lead) BJamerican Car Audio, Video & Security 3 04-19-2001 10:50 PM
How much is too much? LeadFoot Canada Region Forum 4 04-24-2000 02:28 PM
