Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 07-28-2008, 08:32 PM   #1
youngbear2272
Member#: 163749
2002 Wrx
Subaru Blue
Default STI engine into Bugeye...
Okay, So im thinking I may drop and STI engine into my bugeye- BUT I know it can be as easy as just dropping it in and hooking everything up. Does anyone know of any problems Id face when doing this swap? Im sure this post is up all over the place, but I figured Id ask real quick... I know the AVCS does propose a problem, but If I don't install the solenoids and plug the holes I think I'll be fine.
Although I've heard that you have to swap out the cams and crap like that... Does anyone have any info on this?
Thanks!
youngbear2272 is offline   Reply With Quote
Old 07-28-2008, 09:06 PM   #2
ajshades
Member#: 160255
06 STI OBP
05 WRX WRB
wrong place to ask this...
ajshades is offline   Reply With Quote
Old 07-28-2008, 09:17 PM   #3
rollingindiana
Member#: 179102
02 wrxOpensource'd
If you dont want to use AVCS with your sti swap then your better off not swapping. Look into a ej207 swap.
rollingindiana is offline   Reply With Quote
Old 07-28-2008, 09:20 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
There's a lot more to a full swap than just dropping it in. This is a build, not a plug-n-play setup.
Audiosavvy is offline   Reply With Quote
Old 07-29-2008, 01:06 AM   #5
mannac
Member#: 161038
2014 FiST
well you can plug and play after you play with wires for days or weeks on end
mannac is offline   Reply With Quote
Old 07-29-2008, 02:12 AM   #6
Audiosavvy
Member#: 150794
Qcab dakota 4x4
So you're saying play, play, play, play some more, and then plug? Sounds about right
Old 07-29-2008, 03:38 AM   #7
youngbear2272
Member#: 163749
2002 Wrx
Subaru Blue
Im having a custom wiring harness made. At first im just going to swap the manifold and the throttle body so its drive by cable, and then temp. plug the AVCS holes until the harness is done. I think other then those two complications, it should drop in... But im not sure... haha
Old 07-29-2008, 04:02 AM   #8
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
It's never that easy....if you're gonna do a swap, might as well do the WHOLE thing all at once. Your wallet will thank you if you do it all at once....
STimedic is offline   Reply With Quote
STI Swap into bugeye TS - Checklist SilverJS Subaru Conversions 0 10-12-2009 11:33 PM
04-07 sti motor into bugeye? hard2kill Newbies & FAQs 4 03-13-2009 10:18 PM
Blobeye STi/Hanwkeye STi engine into Bugeye WRX Rice Devil Subaru Conversions 2 02-01-2009 03:48 PM
Swaping an MY05 STi engine into an MY06 or MY07 STi and vice versa. boostinscooby Subaru Conversions 11 03-16-2008 01:18 PM
Sti engine into a 2.5 rs Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-09-2002 11:42 PM
