Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 08-12-2008, 10:07 AM   #1
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Smile 06STI, FP HTA Green, APS FMIC, Meth - 395WHP/400WTQ @ 27PSI (Mustang Dyno)
Year: 2006
Vehicle: Subaru
Model: STi
Digits: 378 WHP / 425WTQ @ 26 PSI
Updated Digits as of 11-23-2009 395 WHP / 400WTQ @ 27 PSI
Note that new numbers are produced on a Mustang Dyno (SAE corrected).
Under the hood:
EFI Logics short block with Forged Pistons
FP HTA green w IWG (replaced lost in the mail Blouch Dominator 2.5 Jet coated with IWG)
Cosworth Intake Manifiold
GrimmSpeed coated up-pipe
APS DR525 FMIC (replaced Stock TMIC)
APS 70MM CAI
APS 3" Hard Pipe Turbo Inlet
AP Fuel Rails and Regulator
TGV Delete
Cobb AP 2 / Protune
Cobb TBE (Hi-flow Catted)
DW 740cc Injectors
Walbro 255CC pump
Aquamist HFS-1 75/25% Meth/Water
Grimmspeed Phenolic spacers
Suspension:
Crucial Springs
Whiteline Adj Swaybars F/R
Ebay Front Strutbar
Ebay Rear Strutbar
Megan racing front Brace
Brakes:
OEM Rotors
HPS Plus brakepads
SS brake lines
DOT4 fluid
Comments:
Upgrading from stage 2 required more holistic approach. I wanted to stay away from FMIC for many reasons and my goal was to have similar or better than stock spool for my daily driver.
Having said this my stock STI TMIC stll became a bottleneck after correcting things with the air inflow. By this i mean that with Dom 2.5 you would find stock inlet and intake to be restrictive. Also I could have improved airflow further and squeeze anoth 15hp or so by removing TGVs. Most critically with this setup I am pushing so much hot air that to keep detonation away and eliminate knock I had to consider either 1) better than stock Intercooler or 2) Chemical intercooling (i.e Meth injection). I went 100% Meth route initialy
Here is the graph from old ICS Performance Tune:
Update as of 11-23-09: Installed EFI Logics EJ shortblock with forged pistons, APS DR525 FMIC, FP HTA Green (56lbs wheel) turbo, Cosworth Intake Manifold, AP Fuel rails and Regulator, Grimmspeed Up-pipe and Phenolic spacers. Retuned for 75/25 % Meth/Water ratio.
I have specificaly asked Tuner (Chris from EFI FTW) to dial power back (like10%) from peak levels to leave some margin of reliability for this Daily Driver
New Mustang Dyno Graph as of 11-23-09:
More Tune Details:
AKOUTIN is offline   Reply With Quote
Old 08-12-2008, 11:07 AM   #2
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
This sounds like a sweet set up. Is there an upgraded tmic in your future?
cellgeek101 is offline   Reply With Quote
Old 08-12-2008, 11:07 AM   #3
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
get an account with www.photobucket.com it is easy to upload pics or scans and then just copy the IMG code and paste it and it will show up on the screen.
nice #'s BTW, if you decide to get a bigger TMIC get the Spearco/ESX. It is PHENOMINAL!!!!
Stames_wiltz is offline   Reply With Quote
Old 08-12-2008, 01:54 PM   #4
AKOUTIN
Member#: 183675
2006 EFI HTA Green
I am contemplating APS TMIC, but there is no immediate need per se with Meth running....I will wait for my stock TMIC to crack up first
My real next upgrade is clutchmasters stage 4 clutch
Thanks
Old 08-12-2008, 04:18 PM   #5
Boxer112
Member#: 78751
2017 Sti
ISM
nice numbers but that is scary as hell with that much boost.. where is your peak torque at? also is this with stock headers and up pipe?
Boxer112 is offline   Reply With Quote
Old 08-12-2008, 04:26 PM   #6
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Post
stock uppie indeed
Al from dynoflash did the tune and i was reassured that 26psi is not that scary with 100% meth injection.
I am using HFS-1 and failsafe is very reliable, limiting boost to 15psi with no Meth running...
The car drives like stock in terms of reliability....
Alex
Old 08-12-2008, 04:28 PM   #7
AKOUTIN
Member#: 183675
2006 EFI HTA Green
..looking at the graph peak TQ is around 4400 RPMs
Old 08-12-2008, 05:22 PM   #8
Stames_wiltz
Member#: 143264
2006 WRX TR
Alex
that is yet to be determined. when pushing 400 whp or near it people tend to throttle the car more. it is only a matter of time at those power levels when a piston or ringland goes bye bye. go 75,000 miles plus and then you can talk about reliability.
As for Spearco vs APS... there really is no comparison. Spearco wins on Flow, fin design, Psi Drop and overall build quality. I spent $960 with tax on my APS TMIC with the Cast ducting. You can find Spearco units for the same price. I originally had the Spearco, but the 07 has some stupid part that makes it so the Spearco doesn't fit. Spearco FTW. There are guys on here (4ST-AIR, Suparoo, etc...) that are running the Spearco with GT3076R and 35R's. They are making every bit as much power as the FMIC and spooling faster.
Old 08-12-2008, 05:36 PM   #9
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
I understand your concerns with a front mount.
Your mod list certainly suggests the need for a larger IC, be it FMIC or TMIC.
You really won't lose too much of the spool on a 2.5L with a FMIC/dom setup.
A good tuner is going to manipulate your AVCS timing to make up for the split second of "delay" you are so worried about.
Installing an FMIC is kind of a b*tch, but it's not that hard, overall.
You can squeeze a Spearco in your car if you really want to stay TMIC.
If you decide to go FMIC, I'd stick to APS, for certain.
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 08-12-2008, 06:26 PM   #10
Boxer112
Member#: 78751
2017 Sti
ISM
stock uppie indeed
Alex
how about you get some headers and up-pipe and open up flow to get more power throughout the power band and reduce boost to make the same, if not tons more power.
I'm just a concerned enthusiasts. you wont have to worry about detonation because of meth but all that pressure on a stock build is scary bro.
Old 08-13-2008, 09:28 AM   #11
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Guys thanks for words of wizdom!
Now few clarifictions are pending...
Old 08-13-2008, 09:36 AM   #12
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Post
I agree that reliability is a long-term oriented concept....Meantime, is the concern about raw HP numbers or boost pressure per se?
Different Dynos do pan differnt pictures so I am sure my dynojet 378WHP digits would be lower...say on a Mustang Dyno.
In terms of boost pressure of 26psi....it gets there only on WOT or near it. Sadly...being a "mature" driver ...who is aware of his slipping stock clucth I do not go near WOT in 5th and 6th gear on Meth. Anyway I drive most of the time with AM HFS-1 disabled and push only ~15 psi.
I am thinking of 26psi avaialble to me as a safety net in rare cases of a quick speed fix.
However I do fully realize that lower PSIs ultimetly will contribute to engine longevity...
Old 08-13-2008, 09:44 AM   #13
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Post
SOTC
My main concerns with FMICs are cosmetical and insurance driven. I really want to keep my car looking stock. I also do not want to cut out anything stock form the bumpwer supports...etc. Meantime I am battling heatsock quite well with Meth, heatshiled, ceramic coatings..etc.
I only wanted to go APS TMIC route coz I have other APS products installed and they all perform very very well.
This being said I have also realized by now that Spearco TMIC would be an equal or better product to invest into down the road...
Old 08-13-2008, 09:52 AM   #14
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Post
I know that OEM STI uppie is catless ...but the inside of the factory uppipe is corrugated...So in your mind an aftermarket uppipe is still a good modification that will yield sizable improvement on my particular setup?
Is GT Spec Gen II 02-07 WRX & STi Header & Uppipe combo a good product to get? How much improvement I will find with unequal length headers ( i do like to keep signiture boxer sound)?
Thanks
Old 08-13-2008, 02:06 PM   #15
wuuusaa
Member#: 92894
2015 Wrx
Couple of good links inregards to headers
http://forums.nasioc.com/forums/show...&postcount=725
http://forums.nasioc.com/forums/show...62&postcount=1
What made you choose the 2.5 over the 3.0?
Old 08-13-2008, 03:48 PM   #16
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
26psi with meth is not that bad. VIREurorally runs 26lbs with meth in the 485 tq range and has been doing it for a whil enow with no issues at all. Nice numbers!
robbieshonda is offline   Reply With Quote
Old 08-13-2008, 05:29 PM   #17
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Lightbulb
thanks thats what my tuner stated and he is reputable....Al from Dynoflash
Old 08-14-2008, 01:20 AM   #18
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
Stock clutch?
crand002 is offline   Reply With Quote
Old 08-14-2008, 09:47 AM   #19
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Unhappy
Originally Posted by crand002 View Post
Stock clutch?
Yest still on stock clutch..it is already slipping at WOT in 6th...
Old 08-14-2008, 09:51 AM   #20
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Lightbulb
Thanks for the links..very informative indeed.
to me ....2.5 has a slightly better spool than 3.0, better matched the rest of supporting mods that I had already invested into (like 740 CC injectors) and overal seemed to be a better fit for a daily driver...I also like tons of torgue early on as I seldom take it above 5000 rpm on a street. In other words i definetly wanted better than stock top end, but lower end and midrange took precedence in my decision....
Old 08-14-2008, 12:21 PM   #21
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Didn't you say you are a mature driver and don't do WOT in 6th or are you saying the clutch is slipping with the HFS off in 6th???
When you disable the HFS you have to switch maps as well so its not as easy as hitting a button and your ready. Correct me if I am wrong.
Nice power out of a 2.5" but 26psi on the OEM TMIC is pure insanity. That things made to flow like ~440CFM it was made to flow just a little more than the stock turbo.
Still would like to see the Dyno sheet. I'm willing to bet that the WTQ falls as fast as it was made and drops anywhere from 150-175WTQ by rev limit.
Still very nice power Al's a machine when it comes to tuning.
4ST-AIR is offline   Reply With Quote
Old 08-14-2008, 01:30 PM   #22
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
wow really liking the #'s
IMPORTIMAGE is offline   Reply With Quote
Old 08-14-2008, 05:45 PM   #23
Boxer112
Member#: 78751
2017 Sti
ISM
Thanks
i can not really speak for any other headers, i have Automaster Equal Length headers. MY power band has shifted to the right a lot. It pulls smooth all the way to redline for a stock turbo. Pretty good price but you WILL LOSE the boxer rumble. on AMR's dyno, I made 275WHP, 320Ftlbs at 17Psi on Sunoco 91 octane. that was with just a downpipe and their headers.
Old 08-14-2008, 07:23 PM   #24
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Crazy
tux121 is offline   Reply With Quote
Old 08-15-2008, 09:22 AM   #25
AKOUTIN
Member#: 183675
2006 EFI HTA Green
Cool
Thanks for compliments
I am a mature driver indeed who does not hit WOT in 6th because:
1) There r no public roads in Tri-state conductive to such kind of driving
2) I personaly dont feel the need to push the car so hard on a regular basis
3) Stock clutch is slipping at WOT in 6th after 5-10 mins of hard running in 4th / 5th.
