Welcome to the North American Subaru Impreza Owners Club Tuesday May 22, 2018
Old 08-18-2008, 02:43 PM   #1
andrewp724
Member#: 73361
'03 PSM Wagon
V9 EJ207/6MT, Dom 3.0XT-R
Default Ver8 EJ207 with Dom3 and 93 octane
Tuned by Scott at TopSpeed with EcuTek. 21 psi on Shell 93 octane. High 80's to low 90's ambient temp, 40-45% humidity.
2005 Version 8.5 JDM STI motor, ecu, engine wiring
IA Performance AVCS wiring kit
APS hard turbo inlet pipe
Short Ram intake
Blouch Dom3 turbo
NGK-2668 spark plugs
GM boost solenoid
CSS FMIC kit
TurboXS RFL BOV
TurboXS uppipe
Helix downpipe
HKS Hi-Power catback
ACT streetlite flywheel
ACT sprung 6-puck clutch kit
Modded WRX blue injectors [plug]modded by Aspen_2.5RS[/plug]
Walbro 255 pump
andrewp724 is offline   Reply With Quote
Old 08-18-2008, 02:53 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
seems really low for a dynojet? and wheres the tq? get meth, more boost and wake that sucker up!
godforbid67 is offline   Reply With Quote
Old 08-18-2008, 02:56 PM   #3
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
something is wrong there...........
JMK508 is offline   Reply With Quote
Old 08-18-2008, 03:06 PM   #4
wrxhard
Member#: 108091
Originally Posted by godforbid67 View Post
and wheres the tq?!
Huh? Def only makes 320 on 93 here with a MUCH larger turbo.
You guys gotta remember he's only got 2.0 liters.
wrxhard is offline   Reply With Quote
Old 08-18-2008, 03:11 PM   #5
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
I can understand the TQ figures being a bit off but that 2.0 with that turbo size should hold better towards redline, no?
Numbers do seem low for a dynojet, what do base STi's dyno there?
paikman is offline   Reply With Quote
Old 08-18-2008, 05:51 PM   #6
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
Yeah I was expecting to see some numbers to make me want to get retuned with my JDM 2.0 but I'm hitting 380whp on 93 pump with a Green and it came in a bit sooner to from what I can remember? A bit higher to my 8500 redline and done on a Dynojet.
2002WRXSTi is offline   Reply With Quote
Old 08-18-2008, 05:58 PM   #7
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
The 320 whp I made was on 18 psi (16 psi @ peak power actually) and on a little VF36. I loved that sucker... spooled quick... decent topend. It ran 12.0 @ 115 pretty easily.
The link you put up was my old pump gas tune, about 4 years after the 320 whp tune. I made 433 whp on pump in the link with a built 2 liter and a GT3582R. I have since had things cleaned up and made 461 whp on 93 and made a crappy pass that still managed 11.9 @ 120.
That said, I don't honestly know much about these Blouch turbo's, regardless though, 350+ whp is nothing to sneeze at. Seems like 18G/20G power.
def
dug-e-fresh is offline   Reply With Quote
Old 08-18-2008, 07:14 PM   #8
paikman
Member#: 43002
1990 BNR32 GTR &
def
Dom 3 is a GT30R stuffed into a mitsu housing basically..thats why it would be a big problem to be compared to 18g power levels haha
Old 08-18-2008, 07:26 PM   #9
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Meh, forget the others - 350whp is a great result. That's 265kw over here, and that is a decent effort for a 2L.
Now take the car to the strip and see what she can run
wrxsti.l is offline   Reply With Quote
Old 08-18-2008, 07:29 PM   #10
wuuusaa
Member#: 92894
2015 Wrx
You do have a point there.
Impressions on the CSS performance fmic
Old 08-18-2008, 07:30 PM   #11
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
In my experience whenever you stuff anything into something it doesn't belong in, there are trade offs. To expect 30R power from well... something thats really not a 30R... well...
I should have been a little more careful with my words. An 18G on race would get those numbers and a little more. A 20G would come damn close on pump gas...
Anyway... He may just need to turn the boost up abit. 21 psi on a 2 liter is like 16 psi on 2.5... roughly.
That said, to approach the same flow of our 2.5 liter brothers, we 2 liter guys have to run more boost at any given power level. I'd venture to say he'd pick up a good bit of power turning the boost up and tuning it for, say 24-26 psi. Me for example, I am running 27 psi on pump gas... pretty much as a daily driver.
Then with the race gas tune shoot for 32-35 psi, if the turbo will push that... and assuming the tune would be safe.
21 psi on a 2 liter EJ running a GT30 sized turbo is not a lot of boost. Now 21 psi on a 2 liter running a VF turbo... thats a different story.
def
Old 08-18-2008, 07:40 PM   #12
paikman
Member#: 43002
1990 BNR32 GTR &
def
True. It is true I haven't seen a lot of Dom III's on 2.0's..usually they hit 400whp on dynojets with those kind of supporting mods no problem on similar (give or take ~2 psi) boost on pump on the 2.5's
Old 08-19-2008, 11:16 AM   #13
Special
Member#: 145585
2002 S202 [email protected]
Yellow
Yeah, turn the boost up and see what you get.
Special is offline   Reply With Quote
Old 08-19-2008, 11:41 AM   #14
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
I'd be interested to see how agressive scott got with the cam timing.
Old 08-19-2008, 09:17 PM   #15
andrewp724
Member#: 73361
'03 PSM Wagon
I'm not sure what a stock STi dynos on their dynojet, but I think it's comparable to the other dynojets. The numbers are a little low for what I was expecting after looking at the 257 numbers, and from watching dug's progress on his past sz49 tunes. I think the main thing holding it back was the fmic, with a core that was cooling better we could have ran some more boost. Meth would definitely wake it up, I wish we could have made some race gas runs just to see what it would do.
Micah, I know he had said the cam timing was about at it's limit, but I don't know for sure what those numbers were. 45 degrees comes to mind, but I don't know if that's correct or not.
-Drew
Old 08-19-2008, 10:16 PM   #16
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
If you just want a dyno figure that makes you happy, go to one of the million happy dynos that reads high and get the opperator to "make some adjustments" like they have for numerous other NASIOC members
Old 08-19-2008, 10:29 PM   #17
[email protected]
Member#: 111556
2006 STI
Did i miss you mention if this a 2.4 or 3 inlet?
xerox445@yahoo.com is offline   Reply With Quote
Old 08-19-2008, 11:59 PM   #18
andrewp724
Member#: 73361
'03 PSM Wagon
It is a 2.4" inlet. I'm completely happy with the car, with the quick response and broad power higher in the rpms it makes the car a blast to drive. I was just expecting to see higher dyno numbers. But if I just wanted high dyno numbers, I would have kept my supra.
Old 08-20-2008, 12:49 AM   #19
[email protected]
Member#: 111556
2006 STI
Yeah, to me that seems about right, on a 2L ej20 with a 2.4 inlet with no meth on 93. Seems like a fun car, enjoy it!
Old 08-20-2008, 10:09 AM   #20
dmross
Member#: 2818
2000 2.5RS
The only thing I am curious about is the tq drop at 6500rpm. If it didn't drop off as much, the car would be making close to 400whp. I would guess the tuner left some on the table for safety & reliability. Does the boost taper off? What AVCS advance is it running in that range (if any)?
Otherwise, you could probably get some more power the 6500+ range with a more aggressive cam.
Either way, nice setup!
dmross is offline   Reply With Quote
Old 08-20-2008, 07:15 PM   #21
andrewp724
Member#: 73361
'03 PSM Wagon
I know it is a safe tune, but there probably wasn't a whole lot left in it as far as that goes. The boost does taper, but I can't remember what to, maybe in the 17-18 range. As far as the cam timing up top, I don't know.
Old 08-20-2008, 07:47 PM   #22
Remnex
Member#: 83790
Wow, I really take torque for granted. I admire 2.0 liters. Haven't driven one in forever.
Remnex is offline   Reply With Quote
Old 08-20-2008, 09:41 PM   #23
Homemade WRX
Member#: 33782
96 3MI Racing LLC
I'm not picking at the tune...just curious what its at...just wanted to clarify
Looking for 91 or 93 octane ver8 EJ207 timing map jblaine Engine Management & Tuning 13 03-10-2011 06:49 PM
07 STI Blouch Dom3 [email protected] 93 octane Paintballguy Proven Power Bragging 42 09-03-2010 01:34 PM
Having trouble with vf34 turbo 93 octane map...?? low boost sonicwrxpa AccessPort 2 05-15-2007 10:49 PM
91 AND 93 Octane Maps? black05STIguy AccessPort 4 01-31-2007 08:47 PM
Turbo XS + Superzilla + 21-22psi + EJ207 + 93 Octane = ~375 whp dug-e-fresh Proven Power Bragging 57 01-07-2005 09:47 PM
