Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 08-29-2008, 10:08 AM   #1
0225wrx
Member#: 142701
2002 bugeye/ 79 Brat
WRX=386hp/ Brat=alot less
2002 Bugeye
ENGINE:
USDM 2.5L Shortblock engine
OEM 2002 2.0L Heads
Cosworth headgaskets 1.0mm
Crower 272 cams (.406 lift)
Brian Crower titanium valve springs/retainers
Blouch Dominator 3.5R Stock location Turbo (W/G set @ 18psi)
Blouch Racing ported and polished turbine housing
Custom stainless braided turbo oil feed line
NGK BKR7E (#6097) Copper core V-power spark plugs (.028 gap)
Tumble Generator Valve Delete
1100cc Deatschwerks injectors
SPT timing belt
USDM STI oil pump
USDM STI water pump
SPT poly motor mounts
SPT pitchstop
SlowBoy Racing 3"- 4 ply Silicone intake hose
Max-Redline Front mount Intercooler (31"x12"x4")
Extreme PSI 4 ply Silicone couplers
Clampco Stainless steel T-clamps
HKS SSQ BOV (oem flange)
Snow Performance Water/Methanol Injection System (50/50 mix)
Walbro 255lph fuel pump w/harness
Megan Racing Coolant overflow tank
Mobil 1 10w30 synthetic motor oil
ENGINE MANAGEMENT:
AMS Tuned (by Chris)
AEM EMS w/UEGO #30-1810U
AEM Intake Air Temp sensor kit (IAT)
GM 3 Bar MAP sensor (MAP)
GM EBCS
Perrin 83mm BigMaf w/ filter
EXHAUST:
Tunabe Concept Blue Medallion G 3" turbo back exhaust (catless)
AMR 4-1 polished header and up-pipe
Heat wrap for header and up-pipe
Poly muffler hangers
TRANSMISSION:
PPG 1-4 gearset (1-2 straight cut / 3-4 helical cut)
SPT 2,340 lbf pressure plate
SPT 232mmx5mm triple plate ceramic disk
Indigo 9 lb flywheel
SPT poly transmission mount
Mobil 1 75W90 gear oil (transmission/front differential)
SUSPENSION:
Progressive Springs 1.5"f / 1.8"r
KYB AGX adjustable struts
Koesi 18" bronze w/polished lip 5 spoke rims (Summer)
BFG KDWII 225/40ZR18 (Summer)
Prodrive 17" gold 6 spoke rims (Winter)
Dunlop Wintersport M3 225/45-17 (Winter)
Mobil 80W90 hypoid gear oil (rear differential)
EXTERIOR:
OEM Aspen White exterior paint
Body color sideskirts
OEM RS fog lamp covers
All emblems removed
INTERIOR:
Autometer gauge bezel
Autometer Sport Comp boost gauge (vac30-0-30psi)
Autometer Sport Comp A/F gauge (narrow band...Yeah, I know)
LED for meth/water injection
NGK AFX wideband AFR Display (dash mount)
HKS Turbo Timer w/harness (recessed into dash)
Special Thanks to:
"08WRX" (general help and automotive know how)
AMS Performance
Don Miller Subaru
Blouch VF22 next to Blouch Dominator 3.5R
The pics are from a couple of months ago and the intercooler is a "little" bigger now
I finaly made it to the dyno at AMS two weeks ago and made decent power but I think something is still holding it back significantly.
I made:
386 awhp/ 358 awtq
93 oct
NO meth
21psi by 4300 rpm
When we tried to do a 110 sunoco map, power would climb hard but, as soon as it would pass 23-24 psi hp would drop. I think the IWG is pulling open and loosing boost? Also now I think I may have blown the seal into the compressor and now I am leaking oil into the intercooler piping. It looks like I am going to be putting a EWG and maybe a new header. Also I am going to be re-routing my pcv system into a catch can.
Not bad for now, and I am going to the track in a few weeks to see what it can do.
Matt
0225wrx is offline   Reply With Quote
Old 08-29-2008, 10:13 AM   #2
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Very Nice setup Matt. Ive been waiting a long time to see you get tuned.
Now get that EWG in and lets see the Q16 in her!!!
Let me know when your heading to the track. I need to get my engine mounts done then I 'll join you.
Dan
4ST-AIR is offline   Reply With Quote
Old 08-29-2008, 10:19 AM   #3
0225wrx
Member#: 142701
Dab
I am putting a new header in with a soilid uppipe (without the flex) in and adding the EWG. I have been throwing around the Idea of just going to a custom rotated setup and a "slightly" larger turbo (that is still in the works though). But, in the meantime Im just gonna try this and drive it.
Matt
Old 08-29-2008, 11:02 AM   #4
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Get some enjoyment out of all that work first . Once you have that ALKY tune it will be a beast.
Old 08-29-2008, 11:40 AM   #5
0225wrx
Member#: 142701
I think I am going to the track on Sept 20th??
I guess I will see what happens then.
Matt
Old 08-29-2008, 12:28 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
How did you get a .82 housing from blouch for that turbo? They use Mitsu style hotside housings and I thought the biggest they offered was 8cm^2
Old 08-29-2008, 01:01 PM   #7
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
He asked really nicely It was a one off custom request IIRC.
Old 08-29-2008, 01:44 PM   #8
Mycues1982
Member#: 86995
2005 Tacoma
Nice to see someone with this turbo finally. Maybe the horsepower drop is from the inlet hose collapsing?
Mycues1982 is offline   Reply With Quote
Old 08-29-2008, 01:47 PM   #9
0225wrx
Member#: 142701
Sorry for the confusion. It is a GT35R .82 CHRA center section on a mitsu frankenstein exhaust housing
Not really one off. At the time that I bought it I had never even seen the 3.5 available at all and even to this day you need to ask for it (since they still do not have it on the website).
Old 08-29-2008, 01:58 PM   #10
0225wrx
Member#: 142701
I already thought about that as an option but, I dont really think that is the case. That intake tube is pretty sturdy 4ply and would take a lot of negitive pressure to collapse it. I am thinking that the IGW starts to pull open when the boost pressure goes over 23-24 psi? Thanks for the suggestion though. Any other ideas??
Matt
Old 08-29-2008, 02:24 PM   #11
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
The CHRA doesn't have an A/R, that's determined by the exhaust housing you put on it so a GT35R CHRA is a GT35R CHRA. The compressor and turbine A/Rs are determined by the hotside and the compressor covers you put on.
Old 08-29-2008, 02:55 PM   #12
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Good numbers. No offense, but I think you're leaving a lot on the table by running those cams on (what I presume are) stock 2.0 heads. They flow better than 2.5 heads, but I still think that's more cam than the heads can flow. Headwork would probably open it up quite a bit. Just my $.02
Numbers look great, so does the car.
zeropsi is offline   Reply With Quote
Old 08-29-2008, 03:01 PM   #13
0225wrx
Member#: 142701
Good point. From what I understand it is based on the GT3082 hotside with mitsu flanges, a GT35r center cartrige and a gt40 compressor (AKA GT3040r but with a mitsu housing). Please correct me if I am wrong. That is just what I was understanding it was?
Matt
Old 08-29-2008, 03:04 PM   #14
0225wrx
Member#: 142701
Thanks,
You are correct on the stock 2.0L heads and I agree headwork will be one of the next things to come.
Matt
Old 08-29-2008, 03:29 PM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
That's cool. It's already a monster and only going to improve from here!
How's the idle?
Old 08-29-2008, 03:46 PM   #16
0225wrx
Member#: 142701
How's the idle?
Idle is a little rough but not that bad (idle is set a little higher 1000-1100rpm). I do get a slight stumble when cruising with very light throttle but that is to be expected. I can tell that there is something holding it back though. As soon as I figure that out, it will really come alive.
Matt
Old 08-29-2008, 04:42 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
The silicone inlet may be collapsing at the higher boost on race gas. If you get it on the dyno again try to watch the hose.
If you cant do that, try logging it on the street without the filter on to see if that helps.
I'd suggest just switching to the APS hard pipe, then the collapsing is just never a potential issue.....or trying a different air filter.
Here is a thead from DynoFlash about it. The conclusion most people come to is that the inlet collapses due to a poor air filter.
http://forums.nasioc.com/forums/show...ghlight=perrin
Old 08-29-2008, 04:57 PM   #18
0225wrx
Member#: 142701
WOW!! I retract my previous statement. Ill def check that out. I didnt think that could happen quite like that. Sorry, Mycues1982
Matt
Old 08-29-2008, 05:23 PM   #19
Mycues1982
Member#: 86995
2005 Tacoma
haha np, I think alot of the silicone inlets now available are 5 ply so there is less of a chance for collapsing. I'm running a hard inlet so there is no chance of it.
Old 08-29-2008, 05:24 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ People have also put hose clamps around the inlets to make them not able to collapse.....but you have to put them on after the hose is already under the intake manifold so i cant imagine its a pleasant experience.
Much like APS puts the steel band around the silicone elbow on their turbo inlet pipe
http://www.rallysportdirect.com/shop...ba8d00cc670dfa
Old 08-29-2008, 05:43 PM   #21
kyleblix
Member#: 73495
Audi Q5, Ford Raptor
very nice set up
kyleblix is offline   Reply With Quote
Old 08-29-2008, 10:33 PM   #22
0225wrx
Member#: 142701
Originally Posted by kyleblix View Post
very nice set up
Thank you
I checked it out tonight and the inlet hose is very rigid but I cant rule it out until I do some more testing. Ill see what I can find over the weekend. Thanks again.
Matt
Old 09-16-2008, 09:38 AM   #23
Rick539
Member#: 35997
Question, I just put the Dom 3 on my new hybrid. Still breaking in. Are you using a restrictor pill in the feedback line to the WG? I am using a utec at this time (hydra going in soon) and have the txs bleed valve for boost contol. Thanks for any info
Rick539 is offline   Reply With Quote
Old 09-16-2008, 02:07 PM   #24
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
Subaru Stars
^word
howfast? is offline   Reply With Quote
Old 09-16-2008, 02:33 PM   #25
0225wrx
Member#: 142701
I am not using a restrictor anymore and I have a GM boost solenoid.
On another note, I did find a huge problem with my breather system (I just wasn't thinking when I was putting it together I guess) And now I am no longer having oil in my intercooler pipes and it runs and idles stronger and better than it has in a while. We are going to the track on Saturday so we will see what she does.
Matt
My hybrid build on a budget... Drink Built Motor Discussion 179 12-23-2015 04:05 PM
'02 PPG 5spd, AEM EMS, Dom 3.5r etc.(Madison, WI) 0225wrx MWSOC Private Classifieds 9 07-30-2009 11:21 PM
Finally after 3 years, car is on the road, Jdm V7 Sti engine and Fp Green dyno video! AprilArchambeau Proven Power Bragging 39 06-14-2008 12:00 PM
Finally got the EJ18T on the dyno... scoobyimprza Mid Atlantic Impreza Club -- MAIC 4 08-02-2004 12:51 PM
AMG V8 first miles are on the dyno, what about the STI? nicktckhoo STi Forum Archive 12 06-10-2003 07:56 PM
