08-30-2008, 11:25 PM | #1 |
Member#: 170439
Vehicle:I <3 Lamp |
In enginuity... intercooler tab?
I'm just curious if I hooked up a diy intercooler spray to a pump on the washer resorvoir is it possible to control the spray via the ecu if I have stock wiring for a second pump?
08-30-2008, 11:41 PM | #2 |
Member#: 147628
Vehicle:2019 Jeep Wrangler Firecracker Red |
I doubt that's something you'll see in RomRaider. That would be more of a code patch, similar to the launch control one.
It would probably be a lot easier and just as usefull to buy a boost switch, like used with methanol injection, that can be set to close a circuit when a certain pressure is reached. What condition or conditions did you want the IC to be sprayed under? |
09-02-2008, 12:32 AM | #3 | |
Member#: 170439
Vehicle:I <3 Lamp |
Well I was just curious about this because in the most recent version of rom raider there is a tab for this... I wasn't sure if it was usable with the second pump wiring or not... because I'd like to set it up on either a switch or on auto when a specific condition is met |
09-02-2008, 06:58 AM | #4 |
Member#: 103136
The intercooler tab is for non-USDM ECUs that come from the factory with IC spray AND where the ECU controls the IC spray. It is not present whatsoever for USDM.
09-02-2008, 11:17 AM | #5 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
09-02-2008, 11:44 AM | #6 |
Member#: 103136
09-02-2008, 05:12 PM | #7 |
Member#: 177100
NWIC
Vehicle:03 WRX PSM |
From what I've been told and as stated in previous posts:
JDM ecu's have about 4x the tabs that the USDM ECU's have. |
09-02-2008, 05:34 PM | #8 |
Member#: 103136
The "tabs" (i.e. categories) are arbitrary and don't have any signficance other than making it easier for the user to find the table they need in RomRaider or Ecuflash.
Exactly how much oil is supposed to be in the intercooler? | lo0pback | Normally Aspirated with bolt-on Forced Induction Powertrain | 16 | 10-26-2014 08:25 AM |
How to open links in a new tab using the scroll button in Firefox? | rice h8r | Off-Topic | 17 | 07-18-2008 10:32 AM |
3D button in Enginuity crashes program | vaccine | Open Source Reflashes | 3 | 01-12-2008 06:23 PM |
Oil in the Intercooler... | dug-e-fresh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 03-17-2002 03:08 PM |
Gauging interest in an intercooler waterspray kit... | mpaone | South East Region Forum | 29 | 02-21-2002 05:53 PM |
