Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 09-14-2008, 03:07 PM   #1
nethngbtstk
Member#: 184748
2008 STi
Default Difference from Cobb stage 2 and Protune stage 2... 2006 WRX
nethngbtstk is offline   Reply With Quote
Old 09-14-2008, 03:40 PM   #2
socalLGT
Member#: 89752
08 STI
Are you sure you had the Cobb Stage 2 map loaded on the car before you were tuned? The AFR's as well as the power curve look a lot more like a stock map. Also, please tell me you weren't running meth injection on a Cobb STG 2 map, because you were almost certainly loosing power if you were.
Regardless the tune looks reasonably solid, although I have gotten similar numbers out of 06-07 WRX's on just 91 octane.
socalLGT is offline   Reply With Quote
Old 09-14-2008, 03:46 PM   #3
nethngbtstk
Member#: 184748
2008 STi
Yep I'm sure i had the Cobb AP installed correctly. I wasn't running the meth on the Cobb tune. I installed the kit the night before my tune and the base run we did we made sure the meth was not on. Ray said theres more power to be gained but this is my DD and i wanted a super reliable tune.
Old 09-14-2008, 05:31 PM   #4
BaNaNaS
Member#: 171902
2004 WRX Sport Wagon
PSM - Stg 2
stage 2 cobb should have more torque than that, way more. something was up?
BaNaNaS is offline   Reply With Quote
Old 09-14-2008, 05:49 PM   #5
nethngbtstk
Member#: 184748
2008 STi
^^ Yeah I think there was to. I contacted Cobb and I downloaded the most current tune. The AP worked perfect so it must have been something with my car. Either way the results are great and it feels like a new car.
Old 09-14-2008, 06:15 PM   #6
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
You should know by now that all Subbies are creatures of their own nature and not any 2 make the same #'s. Looks pretty average on both tunes.
Although I will agree everything except the protune WTQ are lower than expected.
4ST-AIR is offline   Reply With Quote
Old 09-14-2008, 06:18 PM   #7
evoeater8
Member#: 68212
2004 hellaFUNCTIONAL
WRB WRXSTI
nice good numbers on the stock turbo too... i'd be happy with that. i'd say sti turbo would be the cats ass on that car fo sho!
evoeater8 is offline   Reply With Quote
Old 09-14-2008, 07:03 PM   #8
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Scott Seigel made my car gain 67awhp and 89awtq just by playing with his computer
STiBottom is offline   Reply With Quote
Old 09-14-2008, 07:10 PM   #9
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
the cobb stage 2 maps are just base maps. they arent maps that fully tunes the car.
bhhamblin is offline   Reply With Quote
Old 09-14-2008, 08:04 PM   #10
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
What????
Playing with his computer?? You mean running the Dyno through SAE?
That's correct they are made to accommodate all STI's/WRX/FXT blah blah. At best they will limp you along on the very rich side until you can gat a custom protune.
You need to lay off Urban Dictionary>
Those numbers are actually low except the WTQ is pretty spot on.
Old 09-14-2008, 09:22 PM   #11
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Oh you doubt the power of the seigel
Old 09-14-2008, 09:40 PM   #12
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Sorry Newb but where did you actually get that idea from my post??
I don't doubt anything that has the correct statistics behind it. Im not even sure where or what your talking bout.
Old 09-14-2008, 09:52 PM   #13
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
If you disconnected the battery while you were hooking up the meth kit, then you deleted any real time maps that the AP was running.
Old 09-14-2008, 11:10 PM   #14
nethngbtstk
Member#: 184748
2008 STi
Correct and before the first pull we reset the reset the ECU and re-flashed the stage Cobb stage 2 file.
Old 09-14-2008, 11:19 PM   #15
nethngbtstk
Member#: 184748
2008 STi
Originally Posted by 4ST-AIR View Post
What????
I am curious to know what number you would think would more on par? I know there are other 06 WRX's making more HP but from what I've seen they have more mods then my set up.
Old 09-14-2008, 11:38 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
the gains seem fine to me.
people are probably comparing it to sti's so they think the gains should be more.
the td04 is small and is dead on the 2.5L at higher rpm....the vf39 is better but still small
if you put a 20g or a Green on there with that meth your power is gonna jump by 100-150whp depending on how much you want to push it
Old 09-14-2008, 11:54 PM   #17
nethngbtstk
Member#: 184748
2008 STi
^^^ Thats is exactly what Ray (tuner) said. After he was done and we were chatting he said a 20g would be perfect for my setup. If i wanted this car to be a high HP car i would make it one. I like that for a minimal amount of money I have more power then a stock STi and in some cases a stage 1 STi. I know that bc Ray tuned an STi with a catback and it made 280hp and 300TQ.
Old 09-15-2008, 12:19 AM   #18
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
thats a real high reading dyno, but good numbers none the less. 20g is nice, i wouldnt mind if my green spooled a little faster.
godforbid67 is offline   Reply With Quote
Old 09-15-2008, 02:43 AM   #19
socalLGT
Member#: 89752
08 STI
Well that explains. The Cobb staged maps start off with a Dynamic Advance Multiplier of .5, ie: you were only running HALF of the DA in the map. If you had driven the car for a few miles before the baseline pull the DAM would have incremented up to 1 and you would have run full DA and made a bunch more power on the Cobb map. That sure is an easy way to make a big delta between the Cobb map and the tuned map...
Old 09-15-2008, 03:25 AM   #20
Clark Turner
Member#: 178047
02 WRX STI Spec C
what a minute.. AEM meth injection... Was the cobb runs with or without the system on?
Clark
Clark Turner is offline   Reply With Quote
Old 09-15-2008, 03:46 AM   #21
Phatron
Member#: 36033
CEO PhatBottiTuning
wouldnt/shouldnt we be able to see the meth turn on via the AFR plot if it was run on the base map pull?
maybe thats whats on the second plot and was called "clutch slip"
Old 09-15-2008, 03:55 AM   #22
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yeah.. I dont know.. Thats why I asked man.. I do know that if a stock turbo 06 read that much WHP it must have been on meth or the dyno was Very high... Its a td04... I have tuned many many 06-07 WRXs over the cobb map. Many times peak power does not come up more then 10 to 20whp. But the area under the curve comes up 30whp and 60ft lbs of trq. I noticed he had AEM meth kit listed so I was curious if he ran the meth kit with the cobb map which would have lowered his power.
Clark
Old 09-15-2008, 05:03 AM   #23
socalLGT
Member#: 89752
08 STI
From earlier in this thread:
Old 09-15-2008, 02:26 PM   #24
[email protected]
Member#: 82064
2011 sti & evo ix
white
car was on the cobb map the base pull and the meth was turned off, i disconnected the vacum line going to the meth line before doing that pull.
i think over all the car is in par with all of the other meth injected td04's i have done, i would really love to see a 20g on this car.
Ray@revitup is offline   Reply With Quote
Old 09-15-2008, 02:43 PM   #25
REX8
Member#: 24038
At least as far as peak numbers go, what in the world were you expecting an OTS map to get you?
Looks just about what you should have expected on the stock turbo...
Stage 2 and other stuff wanted '04 WRX Jphipps1987 Private 'Wanted' Classifieds 2 02-08-2010 08:28 PM
2 step and no lift shift 2006 WRX subadupa Car Part Reviews 4 01-25-2009 11:45 PM
Multiple questions about stage 2 and protune ps99115 AccessPort 2 09-24-2007 10:36 PM
Difference in cobb ap v1 and v2 stoner Newbies & FAQs 23 08-26-2007 11:30 PM
Clutch Disks: Spec Stage 3, Spec Stage 2+ and ACT Stage 1 Take your pic powerlabs Drivetrain 11 03-21-2007 01:01 AM
