Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Old 10-07-2008, 10:24 PM   #1
willyp
Member#: 146561
many 3 legacy turbos
white/black/silver
Default 4eat tranny specialists please HELP! no 3rd or 4th gears please help!!!
I have been trying to get info on this for months. I have a 91 leggy turbo with the 4eat auto. I got in it and let it warm up for 10 mins or so backed out of the drive way put it in drive and slowly took off wasnt beating on it just driving normal it shifted out of first into second and i was going down hill so i wasnt on the throttle i was just coasting got to the stop sign and took off again it shifted out of first into second and it just stays in second if i step on it and get going about 40 and let off of it it just free wheels it doesnt even try to go into 4rth either. If i lock it in 2nd it will slow down on decompression and stay in second but if i shift to 3rd it just goes into neutral until i slow down enough for second to take over again. Any help will be greatly appreciated Thank you for your time and wisdom BILL
willyp is offline   Reply With Quote
Old 10-08-2008, 12:09 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
a6n6d6y is offline   Reply With Quote
Old 10-08-2008, 01:54 AM   #3
willyp
Member#: 146561
white/black/silver
Default serious this is a 91 not my 93
there is no way that this can happen to two cars with the same drive train with out there being some kind of a reason the 93 i bought it that way this car i was driving i have 4 of these turbo autos and 4 5mts all years there is somthing else happening here. does the front band control 3rd and 4rth it makes no sence that it wouldnt have 4rth i could see 1 gear but not two at the same time they must have two different valves in the body if third doesnt work why wont fourth? I also have a pm from a xt6 owner that is having the same problem so what can it be? Thanks for any help out there. BILL
Old 10-08-2008, 10:22 AM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Failed duty solenoid?
AJ711 is offline   Reply With Quote
Old 10-08-2008, 03:01 PM   #5
willyp
Member#: 146561
white/black/silver
Default duty solinoid?
where is that? Is it in the valve body? I took off the valve body to see if there was any thing amiss but i dont know really what to look for other than broken wires or somthing loose i did remeber seeing a couple of solinoids in there does one of them control the 3-4 shift? Thanks for any help BILL
Old 10-08-2008, 07:29 PM   #6
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Solenoids are located in the valve body, yes.
Head to the link below.
http://www.endwrench.com/archive/sysdrive.html
The duty solenoid receives voltage from the TCU and helps to control the transmission gears. Read up on the Phase I transmission and find out about any recalls or issues with whatever solenoid (C, I think) controls gears 3 and 4 (overdrive).
I can't help much else other than that. I don't know enough about the inner workings of the 4EAT to go any further than that.
Old 10-09-2008, 01:35 AM   #7
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
I have a 93 legacy I'm driving temorarally and it is having trouble going into third (feels like I'm hitting the brakes when it goes to engage third)....after I fix my forester I'm going to rebuild the transmission...I'll let you know what I find
btw..the high clutch is needed for both third and fourth gear
low cluth + high clutch = third gear
high clutch + front band aka 2-4 brake(band) = fouth gear
Old 10-11-2008, 08:57 PM   #8
willyp
Member#: 146561
white/black/silver
Default shift into third is like hitting the brakes.
read up on the link your shift into third say the front band is to tight if it feels like it is braking when shifting into third. It dosnt say how the solinoids ground to fault i am asumeing that it is to chasis ground through the tranny housing? If i have someone manually run it through the gears in manual mode the solinoids 1st and second are actuating but nothing in 3rd or 4rth but i dont think it works in manual mode it start off in third unless it is in limp mode. know i really am lost i guess i will have to take one apart and see how it works and put a 727 valve body in it. unless any body else has any idears? BILL
Old 10-11-2008, 09:13 PM   #9
saab-on-the-cobb
Member#: 116330
1985 Dinan M635csi
Turbo. Black.
Punctuation: Use it.
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 10-12-2008, 08:59 PM   #10
willyp
Member#: 146561
white/black/silver
Default Nice answer
nasioc supporter huh? why not worry about finding answers not this BS #$%^&&*)+_)(+(*&^
Old 11-02-2013, 04:18 PM   #11
Subaruman5
Member#: 58218
GL GC8
Loyale
I was wondering if you were able to figure out why your legacy was not shifting into third? My 93' legacy is also having same issues and was thinking it could be the shift solenoid 2 or 1 or maybe the 2-4 brake duty solenoid? Any information would be helpful on what you figured on this.
If I am able to figure this out, I will also let this thread know.
Subaruman5 is offline   Reply With Quote
Old 11-02-2013, 04:25 PM   #12
Subaruman5
Member#: 58218
GL GC8
Loyale
I am looking in the maintenance manual on the 4EAT Legacy up to 1999 and it gives A-B sensors which are behind the oil pan and some resistance to measure if a solenoid is faulty. Which would be the high clutch solenoid?
Old 11-03-2013, 10:36 AM   #13
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
The above post is for a 99+ valve body...totally different if yours is earlier
Sounds like you are in default mode...limp mode..whatever you want to call it you can confirm this by disconnecting the harness to the valve body from the vehicle wiring on top center of the trans front case.
if it drives the same then you know. If thats the case, start at the tcu
borrow a good one work your way down..could even be a bad connection at the 2 connections top center trans case one goes inside trans other to switch..but it sounds electrical.cheers
04stigeorge is offline   Reply With Quote
Old 11-04-2013, 01:18 AM   #14
Subaruman5
Member#: 58218
GL GC8
Loyale
Thank you for info. I will find the correct manual and try some troubleshooting.
Old 03-12-2014, 02:33 AM   #15
erixpc
Member#: 384306
1992 Legacy L
Default So what did you do to fix the "won't go into 3rd gear" problem?
I'm working on a 92 Subaru Legacy AWD 4EAT and it also will not shift into 3rd gear, it does go 1st gear to 2nd gear okay. I found that the shift solenoid with the blue wires ohm tested over the normal 18 to 33 ohm specs at 47 ohms. But I'm also getting TCU error codes 32 and 33. What should I do next to fix this? What parts do I need? Where do you recommend that I get the parts?
erixpc is offline   Reply With Quote
Old 03-12-2014, 04:19 AM   #16
Subaruman5
Member#: 58218
GL GC8
Loyale
I ended up selling the vehicle as is to someone who was going to have a transmission shop fix the issue. I pulled a full set of solenoids from a valvebody on a 93' legacy at a wrecking yard. If anyone is interested I can ship. I wish I knew more on automatic transmissions and to what is causing it to not shift into 3rd. Wish I could be more help.
Old 03-12-2014, 05:43 AM   #17
ToneWrx02
Member#: 239095
2002 Wrx
You know sometimes just getting a used transmission from a junkyard is easiest and cheaper. Why rebuild a 4 eat when there is plenty for sale working.
ToneWrx02 is offline   Reply With Quote
Old 03-12-2014, 05:49 AM   #18
Subaruman5
Member#: 58218
GL GC8
Loyale
If they were easily available I would. Most wrecking yards in this area want 600usd+. If everyone continues to do this and throw away the faulty transmissions with only a solenoid to be replaced, in 50 years there will be none available.
Old 03-13-2014, 09:38 AM   #19
ToneWrx02
Member#: 239095
2002 Wrx
In 50 years i would hope you would already upgrade to a better car.
Old 03-13-2014, 10:57 PM   #20
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
His kid's kid's will need some 4eat too, unless the Prii have finished invading the earth for Chrissake.
Hoon Goon is offline   Reply With Quote
Old 08-21-2019, 07:32 PM   #21
MrMike46
Member#: 505534
1999 Legacy
My problem is opposite. Car running in neutral it will coast on a incline.
Move the gear selector to D or 3 car moves under its own power.
Move the gear selector to 1 or 2 car stops if coasting.
Move the gear selector to R same thing.
If I attempt to drive the trans will lock on upshift and throw a P0731 code.
I'm guessing a solenoid is stuck open or a wire pinched. Problem started 7 days after fluid and filter service.
No other fault codes show.
MrMike46 is offline   Reply With Quote
4eat tranny shifting problem no 3rd or 4th gears willyp Transmission (AT/MT) & Driveline 9 08-22-2019 12:04 PM
No 3rd or 5th Gear After New Clutch Install boostaddict Transmission (AT/MT) & Driveline 14 09-02-2009 05:58 PM
WTB: gear set or just 3rd and 4th gear of 02 wrx AFBeefcake Private 'Wanted' Classifieds 12 10-16-2006 10:20 PM
Tranny balks 3rd to 4th gear shift semabe Transmission (AT/MT) & Driveline 28 04-02-2004 03:48 AM
Tire chirp while off the gas rolling in 3rd or 4th gear? Cujo31 Service & Maintenance 4 09-17-2002 10:57 AM
