10-31-2008, 02:26 PM | #1 |
Member#: 173960
Vehicle:2005 Impreza RS Regal Blue Pearl |
Help! engine light on 05 impreza rs
Engine light came on today as well as the cruize control light flashes. Had code ran o2 sensor low volt too lean. I put a cold air on bot left the torque box plus 2.5" catback magnaflow exhaust on. Would this cause my car to run too lean or is something else going on. sensor is near $400.00. Any suggestions?
10-31-2008, 07:13 PM | #2 |
Member#: 165749
check subarugenuineparts.com or other online vendors, $400 sounds like about $250 too much for an O2 sensor... and a CAI will generally cause a slightly leaner AFR because the ECU doesnt automatically compensate for the larger diameter intake, so it thinks less air is being drawn in than actually is. good thing is that you can do something about that. go check out www.romraider.com and do some searches here on NASIOC, you will see whats up.
11-01-2008, 12:08 AM | #3 |
Member#: 167703
Vehicle:2005 '05 2.5RS 5MT '10 Forester X Limited |
What was the CEL code? Depending on the code you can isolate whether or not it's the upstream or downstream sensor and go from there (I think O2 is downstream as upstream is referred to as AFR sensor). Have you tried resetting ECU to see how quickly it reappears?
11-01-2008, 12:54 AM | #4 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
11-01-2008, 12:58 PM | #5 |
Member#: 173960
the codes
P0131- Low Voltage(Bank 1 Sensor 1)
p2097-Post catalyst fuel trim system too rich(Bank 1) Car is running a little rough. Has trouble starting after it warms up too. |
11-01-2008, 01:12 PM | #6 |
Member#: 187834
Vehicle:06 2.5i impreza Red |
from what I hear...if you reset your ecu before install the ecu adapts to what it needs..but from what I hear ram air and cold air make the car run rich not lean...cause ecu trys to level out the mixture.
11-01-2008, 01:52 PM | #7 |
Member#: 71092
1) Reset or not, the ECU will do the same learning to correct fueling
2) The CAI/SRI will make the car run wrong, whither it runs rich or lean is a crapshoot that depends on the car and intake. The only error that's certain is the huge resonance I wrote about in my hybrid intake thread. |
11-01-2008, 02:31 PM | #8 |
Member#: 173960
Well should i change the Bank 1 sensor 1. Does it read and adjust the fuel/air ratio. Would it cause the car to run like i said. And if i do change it will the setup i have now cause the new one to go bad. Should i have my car tuned.
11-01-2008, 10:13 PM | #9 |
Member#: 167703
Lots of questions but no question marks...
P0131 is caused by a sensor malfunction (most of the time), not a fueling issue related to your intake. Had the same code last year, replaced the upstream sensor and was good to go. Car ran like absolutely crap with this code, probably automatically trips limp mode. Replace the upstream sensor (AFR Sensor or Bank 1) and reset ECU. Your fueling is probably all over the map as a result of malfunctioning sensor and could be compounded by your intake, this could cause the second CEL code (2097). |
Please Help... Engine light on and PO 171 code | ChefAaron | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 04-27-2008 10:07 PM |
HELP! Check Engine light on & Cruise Control Light Blinking | STiURBO | Southern California Impreza Club Forum -- SCIC | 21 | 03-15-2007 01:54 AM |
Question about HID on 05 impreza RS | S2kVer02 | Electrical & Lighting | 1 | 05-07-2006 03:39 PM |
Ipod Hookup on 05 Impreza RS. | Apoll_13 | Car Audio, Video & Security | 5 | 12-22-2005 08:18 PM |
HELP! Engine Light on - Need Advice! | Fester | Normally Aspirated Powertrain | 4 | 10-19-2000 02:45 PM |
