11-01-2008, 06:55 PM | #1 |
Member#: 172470
Socal FS 95 s14 w/Spec R s15,work,hks,tomei,blitz,apexi,greddy************* ****11,500
The car was only use on the weekends and i never drifted or tracked it...i would like to sell this car to someone that is gonna take care and appriciate its beauty.
The car is clean inside and out except from minor scuffs here and there...the engine has about 40k miles, perfect running condition, i just replace both front wheel bearings using OEM nissan parts, New Tires,also installed a new fan contol unit. BODY and INFO: 1995 Nissan 240sx SE (Orig.Rare Dark Purple) No Sunroof Custom rear fender flares -- $600 CLEAN TITLE! No Accidents ~150K miles on body Always starts and runs awesome. Power steering A/C is there, needs to be hooked up and recharged ENGINE: (Built by Gary N. from SYKO Performance) 2001 S15 SpecR SR20DET --- $4,500 installed+labor (Less than 35K miles on motor/ strong and reliable) APEXi 1.1mm metal headgasket -- $1100 installed+Labor ARP head studs -- $200 installed HKS GT2871R turbo -- $1250+installation $200 HKS Wastegate Actuator -- $110 Blitz Super blow-off valve -- $200 GREDDY Front Mount IC -- $450 Professional Custom Black IC Piping -- $800 Silicone sleeves and T-bolt clamps very clean, very sleeper look. Wanted it to make the engine bay look stock. Greddy Valve Rocker stoppers -- $100 Nismo 555 Injectors -- $600 Walbro Fuel Pump 255 LPH -- $120 S15 N/A throttle body 70mm -- $100 Z32 Maf -- $200 K&N Intake -- $100 3" HKS Hi-Power exhaust system -- $500 3" Greddy Down pipe -- $200 Tomei Turbo Dump pipe -- $220 Nismo thermostat -- $80 Koyo Aluminum Racing radiator -- $320 Dual Radiator E-fans -- $120 Fan Controller -- $180 DRIVETRAIN and SUSPENSION: (All Drive train is from the S15 SpecR) S15 6 speed Transmission. Dual Diaphram racing clutch -- $500 Custom drive shaft - $200 S15 Helical Differential – came with Eng. But made custom housing to fit on S14 frame Rucas rear camber kit -- $250 installed Apexi full coilovers with front camber kit -- $1600 installed Rims, Tires and brakes: Work Meister S1 Rims 18x9.5 (+5 offset) and 18x10.5 (-10 offset) -- $2500 (6” lip!) Tires Nitto Extreme Performance n555 (235/45/18 & 245/35/18) -- $1200 Z32 Brake upgrade -- $400 installed Nismo extended wheel studs -- $100 Oem Hub Assy -- $300 Electronics and ECU and other stuff: S15 Tomei Ecu, Tuned for turbo and injectors -- $800 straight from Japan. Apexi S-AFC 2 -- $250 – installed but needs to be retuned Greddy Boost controller (set to 18psi safe) -- $250 HKS Turbo timer -- $120 installed NRG short Steering Wheel release kit -- $170 JDM Hood Spacers -- $20 Autometer Boost gauge -- $30 Stereo is an Eclipse -- $100 nothing big. Infinity Ref. Speakers -- $150 Hood locks -- $20 Pager Alarm from Viper -- $250 installed Autolock -- $30 asking price $12,000 [email protected]
Socal FS 95 s14 w/Spec R s15,work,hks,tomei,blitz,apexi,greddy************* ***12,000 | erick.ilano | Private Vehicle 'For Sale' Classifieds | 17 | 10-30-2008 06:17 PM |
Socal FS 95 s14 w/Spec R s15,work,hks,tomei,blitz,apexi,greddy************* ***12,000 | erick.ilano | Private Vehicle 'For Sale' Classifieds | 20 | 10-16-2008 03:47 PM |
FS SOCAL S14.5 w/2001 Spec R s15..............................................$ 12,500 | erick.ilano | Private Vehicle 'For Sale' Classifieds | 9 | 09-29-2008 03:13 AM |
Socal 95 240sx Spec R s15 sr20,6speed,lsd...$14,000 obo | erick.ilano | Private Vehicle 'For Sale' Classifieds | 2 | 07-29-2008 10:31 PM |
