Welcome to the North American Subaru Impreza Owners Club Saturday April 20, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-10-2008, 06:23 PM   #1
pio!pio!
Member Sales Rating: (1)
Member#: 4190
2008 Impreza WRX STi
Default Socal : FS: 2002 Nissan Sentra SE-R Spec V Black, a lot of mods
PRICE REDUCED
For Sale
In So Cal
~133,500 miles
$4000 OBO
PM me if interested, I live in Downey, CA
The car dyno'd at 195 WHP when I had an S-AFC II installed. It only gained me 5 HP, I removed it so I now should have 190 WHP
I used Redline 10W30 for about 100,000 miles, then switched to Castrol Syntec 0W30 (aka German Castrol).
I use Redline MT90 for the transmission
I use Redline Water Wetter with a 70% water and 30% coolant mix in the radiator.
I use Motul RBF600 for the brake and clutch fluid
I have done an oil analysis from Blackstone Labs on almost every oil change and will provide you with the paperwork.
I also have the data from almost every gas fillup (miles, price, gallons, etc)
Some issues:
Dings and scratches typical of a 6 year old car
Front bumper and lip has lots of marks from bugs hitting it (lots of trips between San Jose and Los Angeles)
Front and Rear bumpers have the trademark "Sentra Sag" in the corners
Airbag light is in because I swapped to a Sparco steering wheel
Check Engine light is on showing a Misfire code becuase of the JWT flywheel, and camshafts. There is no misfire.
I had the headgasket leak at 65,000, but oil analysis caught it before any damage was done, I replaced it, and further oil analysis shows the engine in perfect shape
Sparco Pro 2000 seat has a large tear in it around the hip area.
You can see some pics on my Cardomain page from back in the day before all the scratches and dings and saggy bumpers here:
http://www.cardomain.com/ride/295844/2
Mods:
Engine:
AEM Intake
Hotshot Header
Mossy Performance Exhaust
UR Underdrive Pulley
JWT Camshafts
JWT Balance Shaft Removal
NGK Copper Spark Plugs
Odyssey Lightweight Battery
300ZX Radiator Cap
Place Racing Motor Mounts
Kartboy Exhaust Hangers
Gourmet Garage Grounding Wires
Hondata Phenolic Intake Manifold Spacer
Throttle Body Coolant Bypass Mod
Ported and Polished Throttle Body by Dan Paramore Racing
Ported and Polished Intake Manifold by Dan Paramore Racing
Ported and Polished Head by Dan Paramore Racing (Stage 1)
Ceramic Coated Valves and Stems
Microlon Treatment of Camshaft Bearings
Relocated O2 Sensor Behind Main Cat
Drivetrain and Wheels:
JWT Clutch
JWT Flywheel
Mossy Performance Short Shifter
Volk TE-37 15x7 +40 wheels
Falken Ziex 912 225/50/15 with less than 6000 miles (need to double check the size)
Crown Stainless Steel Brake Lines
Crown Stainless Steel Clutch Line
Carbotech Bobcat Brake Pads
Powerslot Rotors
Suspension
Nismo Dampers
Nismo Springs
Nismo Front Strut Tower Bar
Nismo Front Antisway Bar
Nismo Rear Antisway Bar
Nismo Front Lower Tie Bar
Nismo Bushing Kit
Motivational Engineering Upper Rear Suspension Mounts
Front 0.2 degree tow, -2.5 degree camber by West End Alignment
Rear Beam bent to 0 degree toe by West End Alignment
Exterior:
World Challenge sideskirts
Nismo Rear Wing
Carbon Fiber Hood with Hoodpins
McColloch 9007 HID Kit
Clear Turn Signal Bulbs
Nissan Altima OEM Gas Cap Holder
b15sentra.net sticker
Interior:
Sparco Pro2000 driver seat (black/grey)
Razo Pedal Covers
Infinity Kappa Perfect 6.1 (front components)
Infinity Kappa 65.2i (rear 2-ways)
US Acoustics USX-2100 Amplifier
Monster cables
Stubby Antenna
Nismo Key
Broadway Convex Rearview Mirror
pio!pio! is offline   Reply With Quote
Old 11-10-2008, 06:24 PM   #2
pio!pio!
Member#: 4190
Oil Analysis
Code:
Mi/Hr on Oil	3500	5162	5138	1949	6225	5405	6016	3980	3900	6275	6448	7185	8090	8370
Mi/Hr on Unit	30500	35662	40800	42749	48974	54379	60395	64375	70914	90275	96723	103908	111998	120368
Sample Date	8/13/2003	10/21/2003	1/18/2004	2/23/2004	6/15/2004	9/27/2004	12/24/2004	3/1/2005	7/2/2005	3/3/2006	1/1/2007	4/28/2007	9/15/2007	2/19/2008
Aluminum	2	2	3	6	4	6	6	3	3	1	3	1	2	8
Chromium	1	1	1	1	1	1	1	1	0	1	1	1	0	1
Iron 		6	10	6	12	13	6	9	6	10	7	9	11	15	20
Copper 		4	6	4	3	6	5	3	2	4	3	3	5	7	6
Lead		3	2	0	2	8	4	4	0	2	0	0	0	0	0
Tin 		0	0	0	1	0	0	0	2	2	0	0	2	5	4
Molybdenum	623	594	430	588	627	368	528	222	96	595	541	608	778	703
Nickel		0	1	0	0	0	0	1	0	0	1	1	1	4	7
Manganese	0	0	0	0	0	0	0	0	0	0	0	0	1	0
Silver		0	0	0	0	0	0	0	0	0	0	0	0	0	0
Titanium	0	0	0	0	0	0	0	0	0	0	0	0	0	0
Potassium	20	17	13	5	4	1	13	114	4	1	1	0	4	4
Boron		20	5	59	14	9	5	15	51	42	9	14	12	24	21
Silicon 	13	13	12	21	20	16	15	9	9	25	16	16	17	18
Sodium 		16	15	13	25	30	17	25	87	8	18	20	20	26	29
Calcium		3072	3113	2893	3045	3103	2872	3124	1953	2565	1945	2859	2723	3268	2929
Magnesium	7	8	9	6	7	7	0	7	11	18	19	14	14	11
Phophorus	1275	1160	990	1197	1172	1103	1275	736	724	1190	1181	1140	1073	1040
Zinc 		1405	1261	1193	1312	1326	1248	1507	774	893	1351	1308	1340	1309	1227
Barium 		1	1	1	1	1	1	1	0	0	0	0	0	0	1
[email protected]	68.6	69.4	65.5	66.3	68.2	68.7	67	64	59.6	63.8	66.5	66	63.7	67
Flashpoint	445	400	430	460	440	445	430	440	425	415	425	425	395	435
Fuel %	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5	0.5
Antifreeze %	0	0	0	0	0	0	0	POS	0	0	0	0	0	0
Water %	0	0	0	0	0	0	0	0	0	0	0	0	0	0
Insolubules %	0.2	0.2	0.3	0.3	0.4	0.3	0.4	0.3	0.1	0.3	0.4	0.3	0.3	0.3
TBN 		5.2	3.7	4.6	6.3	3.5	3.9	2.8	1		4.3	3.9	2.6	4.6	2
Old 11-11-2008, 11:33 AM   #3
pio!pio!
Member#: 4190
bump price reduced!!
Old 11-12-2008, 03:03 AM   #4
pio!pio!
Member#: 4190
bump5
Old 11-12-2008, 12:16 PM   #5
pio!pio!
Member#: 4190
bump.
Old 11-13-2008, 04:04 AM   #6
pio!pio!
Member#: 4190
bump for price drop
Old 11-13-2008, 05:09 PM   #7
pio!pio!
Member#: 4190
bump for a good value
Old 11-13-2008, 07:25 PM   #8
spiralsmurf
Member Sales Rating: (35)
Member#: 16085
2005 STi
funny, i've been on the board so long I remember when you got this car!
spiralsmurf is offline   Reply With Quote
Old 11-13-2008, 07:49 PM   #9
pio!pio!
Member#: 4190
hehe nice
Old 11-14-2008, 12:52 PM   #10
pio!pio!
Member#: 4190
bump its cheap! no reasonable offer refused!
Old 11-17-2008, 12:04 PM   #11
pio!pio!
Member#: 4190
bumppp
Old 11-18-2008, 10:53 AM   #12
pio!pio!
Member#: 4190
buuuump
Old 11-19-2008, 10:53 AM   #13
pio!pio!
Member#: 4190
buuuump
Old 11-19-2008, 11:44 PM   #14
pio!pio!
Member#: 4190
b-b-b-bump
Old 11-22-2008, 12:19 PM   #15
pio!pio!
Member#: 4190
bump45
Old 12-04-2008, 01:25 AM   #16
pio!pio!
Member#: 4190
ttt bump
Old 12-06-2008, 03:42 PM   #17
pio!pio!
Member#: 4190
bump for lowered prices!
Old 01-14-2009, 06:50 PM   #18
specvx2002
Member#: 200194
heyyy have the lip??? please let me know email to me [email protected]
please man
specvx2002 is offline   Reply With Quote
2007 Nissan Sentra SE-R Spec V pio!pio! Non-Subaru News & Rumors 56 12-06-2006 09:23 AM
04' nissan sentra se-r spec-v justjoe Private Vehicle 'For Sale' Classifieds 8 05-06-2004 05:06 AM
Nissan Sentra SE-R Spec V slowme Private Vehicle 'For Sale' Classifieds 0 04-05-2004 08:02 AM
2002 white Nissan Sentra SE-R SPEC- V takumi Private Vehicle 'For Sale' Classifieds 0 09-13-2003 02:57 AM
