Welcome to the North American Subaru Impreza Owners Club Monday December 18, 2017
Old 11-19-2008, 07:44 PM   #1
bnr34rb26dett
Member#: 188424
2012 LS6 FD RX7, Evo
Wink how do you install a vortex generator??
so i just got a vortex generator for my scooby and i was wondering how you guys taped it down to the roof.
did you guys use some special kind of tape? glued it? or bolted it on??
i have heard of stories where people's vortex gens went flying on highway and i dont want that happening to me.
whatever product use, a link would be great!
thanks!!
bnr34rb26dett is offline   Reply With Quote
Old 11-19-2008, 07:58 PM   #2
iheartmysuby
Member#: 83638
duhhhhhhhh 3m double side sticky tape. search
iheartmysuby is offline   Reply With Quote
Old 11-19-2008, 08:06 PM   #3
bnr34rb26dett
Member#: 188424
yea but thats the tape i heard has been falling off on the highway.
i dont know if theres any other ways (better ways) that seems to work
Old 11-19-2008, 11:23 PM   #4
kuhlka
Member#: 155314
2005 STI
If you get the super strong gray 3m tape that comes in the red plastic, that'll hold it on super tight. Just make sure to use a LOT of it. I used a roll on a custom tank pad I made for my motorcycle and it took about an hour to peel off a year later. We're talking yelling and cursing kind of strength to pull that sucker off.
kuhlka is offline   Reply With Quote
Old 11-19-2008, 11:24 PM   #5
kuhlka
Member#: 155314
2005 STI
Oh, and make sure to clean the glass thoroughly using rubbing alcohol and let it dry before you tape it on. Any dirt or other residues will obviously weaken the bond.
Old 11-21-2008, 03:33 AM   #6
kurtiis
Member#: 168748
2010 STI
Just double up on it. I layered mine on top of each other and put super glue in between them to hold it together. Mine flew off on the freeway a couple days ago . Good thing it went right under my wing. haha. Cracked it a little bit though. Whatever, not going to waste my 7 bucks for the part and 30 bucks for shipping :P
kurtiis is offline   Reply With Quote
Old 11-21-2008, 03:54 AM   #7
Lugal
Member#: 193865
Unless you have a tall rear wing that has been wind tunnel tested to work with the vortex generator then there is no reason to put it on.
Lugal is offline   Reply With Quote
Old 11-21-2008, 08:23 AM   #8
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
clean the glass surface, and use heat gun / hair dryer to make the tape very hot, so it is super sticky... and nothing will get it off.
qualityracer is offline   Reply With Quote
Old 11-21-2008, 11:58 AM   #9
rexman2002
Member#: 140244
2002 bugeye
still rippin' hard
I used the 3m super heavy duty double sided tape from Home depot, its red in color about 3/4 inch in width. Applied the tape this way l___l___l___l___l on the back side. Make sure to clean the surface that the vortex will go on really well, I used alcohol. Also clean the back side of the vortex before applying the tape.
Drove at 100mph+ (dragstrip) held fine, on the highway 65mph-70 without problem. Had it for over a month and no issues, its on there for good. It's best to apply the tape above 80F temp.
rexman2002 is offline   Reply With Quote
Old 11-21-2008, 12:26 PM   #10
Admission_Regret
Member#: 131246
2004 STi Snow White
eighteen x ten + thirty
Make sure its warm outside too or it won't stick.
Admission_Regret is offline   Reply With Quote
Old 11-21-2008, 01:48 PM   #11
dremersvision
Member#: 141272
There is another double sided tape called gorilla. The airline industry uses it and believe me, this stuff is so hard to take off.
dremersvision is offline   Reply With Quote
Old 11-21-2008, 03:54 PM   #12
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
JB Weld or a good plastic epoxy, like the stuff Gorilla makes. Put a couple of small pieces of the tape on there, and use the epoxy in between.
Kentrik is offline   Reply With Quote
Old 11-21-2008, 06:46 PM   #13
bnr34rb26dett
Member#: 188424
awesome guys!
+1 on that home depot tape i just got some.
im gonna do the install but its freezing here in PA and i dont have a garage......
should i heat gun it or something?
Old 11-22-2008, 03:35 PM   #14
Admission_Regret
Member#: 131246
2004 STi Snow White
yeah, its gotta be above like 60 degrees or something when it makes contact with the two surfaces. Just heat gun it as you go along.
Old 11-22-2008, 03:40 PM   #15
Uber-Charged
Member#: 154313
2002 /2004 Conversio
n Stage 2 WRB
I did that and it flew off at 70 mph....
Uber-Charged is offline   Reply With Quote
Old 11-22-2008, 03:52 PM   #16
subeguy
Member#: 174853
2004 Wrx Impreza
Silver & Blk
yup mine flew off too.... twice and both times i ran out of my car on the freeway to get it. the reason it fly's of is because there is space between the vortex and top of car that doesnt touch well. i bought three packs of the double sided tape and layered it over each other. it takes time but it works. make sure u layer the tape more over the rear closest to the window because its obviously a bit taller than the front
subeguy is offline   Reply With Quote
Old 02-22-2009, 06:14 PM   #17
NOboostSUBIE
Member#: 163322
2002 PSM Impreza RS
DD & Weekend Auto-x'r
I screwed mine to my roof (4 corners) and am regretting it. It expands and shrinks as the seasons change and gets wavy looking. Anyone consider sealing the front edge with silicon or something of that sort to prevent air from getting under there?
NOboostSUBIE is offline   Reply With Quote
Old 02-22-2009, 07:19 PM   #18
Swany
Member#: 142198
02 WRX
Always bet on black!
Staples.
Swany is offline   Reply With Quote
Old 02-22-2009, 07:41 PM   #19
GrundleJuice
Member#: 165749
VG's on a stock aero street car? really? do most people even understand how they work?
Old 02-22-2009, 07:47 PM   #20
NOboostSUBIE
Member#: 163322
2002 PSM Impreza RS
yeah, I see your point. BUT that blanket of a statement can be applied to the rear diffusers, and beloved sti limited lips that tons of people on this forum have......on street cars. Why is it so bad to like the aesthetic appeal of these parts, regardless of the car's track usage?
I rock one on my bugeye, and love it.
Old 02-22-2009, 07:49 PM   #21
mongolloid
Member#: 190798
2004 Wrx
Billy Mays might recomend Might Putty hahahahaa
mongolloid is offline   Reply With Quote
Old 02-22-2009, 07:50 PM   #22
rexman2002
Member#: 140244
2002 bugeye
still rippin' hard
who cares. I was going for the look, I'm a ricer. GTFO with your useless post. Answer to post #19, the 2.5i driver...
Old 02-22-2009, 07:52 PM   #23
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
double is the best cause you won't get paint damage when you want to take it off.
I drove 110 with no problem and pretty hard to take it off without tools.
but just make sure all surface are dry and its not gonna rain 48 hours after you sticked it on,cause the first time I did it without heat gun and it rained 2 hours after so some of the type was kind of falled out a little.
so here is how I put mine on:
1.Clean all the surface then use a heat gun to make it has same curve
as the roof.
2.use the double side type (which can hold 5 pounds) to type 8 points
on the roof.
3.let it sit under the sun for maybe a day and it sould be fine.(heat it again with a heat gun if there's cold,it can help the type hold better)
4.post some pix to show us how you did
sum0325 is offline   Reply With Quote
Old 02-22-2009, 08:32 PM   #24
whoosh
Member#: 40989
OT vag inspector
screws
whoosh is offline   Reply With Quote
Old 02-22-2009, 08:42 PM   #25
TK421
Member#: 146200
2009 Supermoto
hot glue and bubble gum
TK421 is offline   Reply With Quote
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 12:32 PM
How do you get Excel to generate a normal distribution? roffle Off-Topic 5 03-12-2007 02:15 AM
How do you install aftermarket springs? Subie Gal Brakes, Steering & Suspension 9 06-07-2001 01:56 AM
How do you install a fuel pressure regulator? CRAZY KEN General Forum Archive 0 12-24-2000 07:49 AM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 03:41 PM
