11-23-2008, 04:37 AM | #1 |
Member#: 118113
VIC
Vehicle:98' Stagea 260RS Autech Ver. |
02 HVAC swapped with 05+ auto HVAC
Im installing 05+ STI auto HVAC into my 02 WRX. I SEARCHED THROUGH OVER 400 THREADS READING UP ON THIS:
YES it can be done YES it requires effort. you need to remove EVERYTHING from the dashboard including the dash cover its self. its alot to remove. Drain the coolant Discharge the A/C (do it properly for the sake of our ozone) I have the following parts: complete 05+ STI center console 05+ auto HVAC control panel ( knobs and buttons) 05+ auto HVAC Heater core and A/C evaporator assembly with servos the appropriate plugs that connect to the above units. Making my own wiring harness I have 2 questions: 1) is there anything else needed? i heard something about a sunlight load sensor and also something about a "control module" is there any other components i need? special module boxes that may be hidded beneath the dash? Maybe the STI blower motor? 2) Does anyone have a wiring diagram for these components? < i really really really need this..... when finished i will publish a full how-to on this subject but i need a bit of help.
11-23-2008, 02:17 PM | #2 |
Member#: 124724
TXIC
Vehicle:21 Crosstrek |
im tryin to do the same. i would like to do the s204 dash kit but its a bit pricey. you can go to a local subaru dealership and at the parts department ask for a wiring schematic for the blower motor assy.
i have seen some really nice swaps and im a huge fan of the end result. i havent seen a right-up or a sticky about this conversion yet though. |
11-23-2008, 03:25 PM | #3 |
Member#: 118113
VIC
awesome man, id really love to get this working. im gonna pull apart my dash right now and see how the OEM wiring looks.
ill call my dealer tmrw and get both the 02 and 05 diagrams and post them on here. |
11-24-2008, 07:42 AM | #4 |
Member#: 173100
South East
Vehicle:2002 WRX Blue |
I have been researching on this same swap and there is a sun load sensor that goes on the dash where the defrost vents come out and also the is a outside temp sensor that goes in the front of the car like in the grill i think i have the schematic somewhere ill try to find it
11-24-2008, 08:27 AM | #5 |
Member#: 190273
SWIC
Vehicle:05 WRX evoIII-16G WRB |
^You are correct. Sun sensor on the dash, right in the middle and also
Try this schematic (2004, pg3): http://www.autocds.ru/2004%20STI/07....g%20System.pdf It's from |
11-26-2008, 01:17 AM | #6 |
Member#: 118113
VIC
Thanks for the info guys! ive got both wiring diagrams now and im in the process of either trying to find a harness i can buy that will work for me, or just trying to make my own.
11-26-2008, 02:23 AM | #7 |
Member#: 173829
SCIC
Vehicle:04 dom3 +meth pyah 09 triumph daytona 675 |
subscribed... lets see pics!!!
11-26-2008, 07:15 AM | #8 |
Member#: 173100
South East
i contacted millennium auto (www.y2kimports.com) when i was researching doing the swap in my bugeye and the said they would sell dash harnesses for something like $30 so i would check with them that might make the swap easier
11-27-2008, 04:14 AM | #9 |
Member#: 118113
VIC
ok so upon hours of further research, ive concluded that the 02 and 05 ECU's are not compatable. the 05 ECU has 5 plugs with a total of 88 pins. the 02 has 5 different shaped plugs with 120+ pins. not one plug is the same between the two cars. now some of the pins are unused so i even counted the number of wires on all of my plugs. there are 93 IIRC. The 04+ STI's have only 4 plugs but they each have MANY more wires. so long story short: id need some kind of wacky conversion harness.
im almost positive they made a JDM WRX with auto climate controls in 01-02 (bugeye years in japan) but the harness would be RHD and almost unusable in a LHD car. im wiring it all up my self. ive made my own pin out chart which i will post once its tested and working properly. pics to come soon.... |
12-04-2008, 02:34 PM | #10 |
Member#: 190273
SWIC
Keep us posted on your progress. Looks like you're on the right track and research and careful planning is helping you sort it all out.
12-04-2008, 05:02 PM | #11 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Wow. Sounds like a ton of work.
If I were able to swap out my LGT's auto for a manual system easily, I'd do it in a second. I love the manual system in the wife's base outback and the LGT auto one is a pain in the butt that I have to constantly play with for it to just do what I want. jack |
12-12-2008, 04:07 AM | #12 |
Member#: 148597
Vehicle:85 911 White |
you are correct all GDA-GDB Bugeyes had auto hvac, only one that didnt was spec c ra anyways do you have a wiring diagram for the hvac? i just installed a new cluster and it messes with my outside air temp because it is made for a spec c with manual ac.
01-03-2009, 10:57 PM | #13 |
Member#: 118113
VIC
you can find them quite easily online. i may have the instrument cluster diagram. ill pm it to you if you need it.
01-03-2009, 10:59 PM | #14 |
Member#: 191182
Vehicle:2002 WRX MBP |
I have a HVAC control panel with the auto if anyone wants to buy it. real cheap. pm me
got sent the wrong part a while back and its just sitting in my room |
01-04-2009, 04:22 AM | #15 |
Member#: 118113
VIC
i have a complete 04 sti center console for sale including shifter trim ring. i also have
all for $100! + shipping |
05+ auto HVAC in 02 WRX. im doing it and it WILL work. but i need help! | Loomin | Electrical & Lighting | 104 | 06-01-2019 11:12 PM |
02 5mt swap with ej205 engine swap | Gamble_WRX | Drivetrain | 11 | 04-01-2010 05:40 PM |
05+ auto HVAC swapped into 02 WRX | Loomin | Subaru Conversions | 0 | 11-23-2008 04:34 AM |
STI 05 full interior swap with 05 WRX interior | dchou | Private 'For Sale' Classifieds | 7 | 09-22-2004 07:22 PM |
05 STI interior swap with 05 WRX | dchou | Bay Area Impreza Club Forum -- BAIC | 0 | 09-20-2004 09:06 PM |
