Welcome to the North American Subaru Impreza Owners Club Friday January 20, 2017
Old 11-29-2008, 12:38 AM   #1
Lamont
Member#: 125190
Default 4EAT to STi gas pedal wiring guide
One of the last bits for my STi swap was the gas pedal. I swapped the gas pedal because it's hard to heal-toe as the 4EAT gas pedal is way below the MT brake/clutch, and to have the gas pedal not level is a hazard IMHO (my foot got stuck under the brake pedal, not fun ). Also, I noticed the travel is a bit longer in the STi pedal.
06 STi Acceleration Pedal 6 Pin - STi acceleration pedal pinout colors are the same from 04~07. As for functions for the target car... look at your ECU pinout for your year.
Terminal - Color - Where it goes - Function
  • 1 - Sb - ECU Port 136 Pin 16 - Fuel Tank Pressure Sensor - Sub power supply
  • 2 - L - ECU Port 136 Pin 28 - Sub sensor signal
  • 3 - Lg - ECU Port 136 Pin 15 - Main Power Supply
  • 4 - Y - ECU Port 136 Pin 34 - GROUND (main sensor)
  • 5 - R - ECU Port 136 Pin 17 - Main censor signal
  • 6 - RB - ECU Port 136 Pin 35 - GROUND (sub sensor)
06 WRX Acceleration Pedal 6 Pin (MT/4EAT) -
  • 1 - RL - ECU Port 135 Pin 22 & Fuel Tank Pressure Sensor - Sub power supply
  • 2 - RG - ECU Port 135 Pin 30 - GROUND (sub sensor)
  • 3 - L - ECU Port 135 Pin 31 - Sub censor signal
  • 4 - Lg - ECU Port 135 Pin 21 - Main Power Supply
  • 5 - Y - ECU Port 135 Pin 29 - GROUND (main sensor)
  • 6 - R - ECU Port 135 Pin 23 - Main censor signal
So using the information above:
06 WRX - 06 STi
1 - 1
2 - 6
3 - 2
4 - 3
5 - 4
6 - 5
If you're doing a 4EAT to MT swap, I would recommend getting the gas pedal as well.
Lamont is offline   Reply With Quote
WTB: STi gas pedal assm. punkrocksailor North West Impreza Club Forum -- NWIC 7 09-07-2008 03:11 AM
04 STi v1 accessport, 04 STi oem ecu (neither married), STi gas pedal Synacr0n Engine/Power/Exhaust 7 04-04-2008 10:02 AM
FYI: 02-06 Impreza/wrx/STi alarm/Autostart wiring guide 12vpro Car Audio, Video & Security 7 12-16-2006 06:23 PM
how to remove gas pedal? brianc Interior & Exterior Modification 1 03-17-2004 11:43 AM
STi Gas Pedal install [Q] Peaty General Forum Archive 8 10-10-2000 08:28 PM
