Welcome to the North American Subaru Impreza Owners Club Thursday December 12, 2019
Old 12-12-2008, 08:06 PM   #1
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
Default vacuum diagram help?
I am in need of a vacuum diagram. I can't figure out how these few hoses go. I know that the yellow goes into the red, but i have no clue where the green goes? there are no other hoses close by? Or do i have the blue t on the wrong hose? Please help so I can finish this. Thank you
autvincereautmori is offline   Reply With Quote
Old 12-12-2008, 09:25 PM   #2
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
That is correct, the yellow you have circled would go to the purge control solenoid valve, and the green part circled connects to the fuel pipe assy.
toutanje is offline   Reply With Quote
Old 12-12-2008, 11:41 PM   #3
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
thank you so much just saved my night
Old 12-30-2008, 03:35 PM   #4
SAIKOU
Member#: 92718
04 WRX 2.5 Hybrid
Wow, +1 for searching- I had the exact problem. Thanks for your knowledge toutanje.
SAIKOU is offline   Reply With Quote
Old 01-14-2009, 01:27 PM   #5
rodder
Member#: 86128
2005 OBP STi 355 whp
RIP :(
I'm looking for a full diagram for these lines. I just finished building a motor and it's my first time tearing into one of these things. I need to make sure I'm hooking up all my vacuum lines correctly during the reinstall (which is in progress as soon as I finish typing this).
Car is an 05 STi with an external gate and an HOA bcs.
TIA!!!!
EDIT: whoops, didn't notice this was in the 2.0 section.
rodder is offline   Reply With Quote
Old 01-14-2009, 01:32 PM   #6
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Audiosavvy is offline   Reply With Quote
Old 01-14-2009, 01:40 PM   #7
rodder
Member#: 86128
RIP :(
umm yeah thanks.
Old 03-30-2009, 03:12 PM   #8
dalhedian
Member#: 186513
Default same problem
Do you guys know where i could find the vacuum and coolant diagrams for a ej20k engine ... v3 sti ? i know they pretty much all work the same but i cant figure it out
thanks
dalhedian is offline   Reply With Quote
Old 07-11-2009, 12:40 PM   #9
EE06STI
Member#: 124580
Could you re-host the diagram/picture from post 5?
EE06STI is offline   Reply With Quote
Old 07-15-2009, 09:55 PM   #10
Deznuts05
Member#: 1410
2011 X5 Diesel
Space Gray
Yes please rehost picture.
Also, OP how did you get to that part? I have to replace mine and I'm not sure how to go about it. Please let me know
Thank you,
Rudy Diaz
Deznuts05 is offline   Reply With Quote
Old 04-24-2012, 07:27 PM   #11
RIPNBST
Member#: 314403
2007 STi
This thread is way old, does anyone have a link to or a vac diagram they can post that isn't a dead link?
Thanks!
RIPNBST is offline   Reply With Quote
Old 05-09-2012, 08:33 AM   #12
EE06STI
Member#: 124580
It turns out there is this diagram as a sicker on the bottom of your hood.
Old 05-09-2012, 09:33 AM   #13
nismopowerdqg
Member#: 312580
2010 WRX [email protected]/334
Cobb/Torqued Performance
i was looking under my hood and that system was unplugged in my car. ive been getting all kinds of misfire codes on all four cylinders and a lean af code. i hooked it back up and the codes havent come back on.. i wonder if it was my problem??
nismopowerdqg is offline   Reply With Quote
Old 05-09-2012, 09:29 PM   #14
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
ckswanecamp is offline   Reply With Quote
Old 05-10-2018, 01:48 PM   #15
Tbone714
Member#: 223413
Old thread I know but any chance you know what this blue piece is called? Mine has a crack a deff needs to be replaced
Tbone714 is offline   Reply With Quote
Old 05-10-2018, 04:10 PM   #16
PVNRT
Member#: 483821
2004 WRX 2.0 18g
It's just a vacuum T, take it with you to auto parts store and match it up. Then zip tie it.
PVNRT is offline   Reply With Quote
Old 11-05-2019, 11:01 PM   #17
yeayeaatou
Member#: 278928
2005 sti
no photos work
yeayeaatou is offline   Reply With Quote
HELP!!! NEED 04 STI Vacuum Diagrams!!! WRXINTX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-21-2012 12:14 PM
ej20 vacuum diagram help laxguitarist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-23-2010 01:09 AM
07 sti Vacuum Diagram PLEASE Help BillMac Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 08-29-2007 06:11 PM
2002 WRX Vacuum diagram 02wrxjim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-20-2005 09:22 PM
Toyota 22RE vacuum diagrams?? Hondaslayer Off-Topic 33 07-31-2005 04:13 PM
