Welcome to the North American Subaru Impreza Owners Club Saturday June 24, 2017
Old 01-31-2009, 06:51 PM   #1
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
Default 08 Stage 2 WRX... Day at the Dyno!
Today I decided to join my buddy to the dyno and take advantage of the rare cold fronts that hit South Florida. We hit up Fynetune performance here in Miami, FL.
After my friend finished with his S4, it was my turn... I did three pulls with the first in 4th gear and the other two in 3rd.
My mods are SPT CBE, Cobb DP and Cobb AP with OTS Stage 2 on 93 octane.
My first pull in 4th I ended up getting 205.2 whp and 267.5 ft/lbs torque.
2nd pull I did in 3rd gear and ended with 199 whp and 270.60 ft/lbs torque
All in all, I had hoped for a little better numbers in the horsepower area. But I guess this is a good baseline, plus I love the way my car drives. Hopefully I can get some more stuff in the near future and post better numbers!
Feedback would be great! Let me know what you all think!
See charts below:
sam821 is offline   Reply With Quote
Old 01-31-2009, 07:12 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
WOW...Low #'s especially for a dynojet...
renosubby is offline   Reply With Quote
Old 01-31-2009, 11:04 PM   #3
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
Do you know where my numbers should be? I've heard it should be closer to 220 whp... but not sure.
Old 01-31-2009, 11:25 PM   #4
LITE SPD
Member#: 181308
2016 WRX
They are corrected #s and the car doesn't sound like it has had a protune.
I doubt the #s are really that low for the mods you have. I bet a protune with 17-18psi of boost will put that car around 300-310wtq and 230whp.
LITE SPD is offline   Reply With Quote
Old 01-31-2009, 11:28 PM   #5
LITE SPD
Member#: 181308
2016 WRX
Old 01-31-2009, 11:46 PM   #6
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
yea... So I've heard. So who can't point me to a nice protune?
Old 02-01-2009, 09:37 PM   #7
LITE SPD
Member#: 181308
2016 WRX
How about the shop you got the dyno runs at? If you dynoed it there, they must have a AWD dyno an probably have a Subaru tuner there too.
Old 02-01-2009, 11:01 PM   #8
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
They primarily work with Evo's and they said they can do a tune with ECUtek. I would definitely prefer to go with someone who specializes in subaru's.
I am planning on sticking with the AP for now and in the future when I get to bigger Intercooler, turbo, etc. I will try to find a pro tuner around this area.
Unfortunately, there aren't too many subaru's in my neck of the woods.
Old 02-02-2009, 12:32 PM   #9
1stockwrx
Member#: 162365
06 RSX Type S
its probably the spt(half joke,half serious)
you have nice torque numbers but low hp..restriction? correct me if im wrong
1stockwrx is offline   Reply With Quote
Old 02-02-2009, 04:08 PM   #10
LITE SPD
Member#: 181308
2016 WRX
At this hp and tq level, a SPT exhaust is not a restriction. I think they are pretty free flowing in the 2008 models. I could see the SPT exhaust start to choke up a car over 380whp. Maybe over that even.
Old 02-02-2009, 04:52 PM   #11
benw
Member#: 103320
1998 swapped
Forester L
SPT dual systems are fine, it's the single tip that suck. We're pushing 400whp through a dual SPT on a 08 Spec.B
benw is offline   Reply With Quote
Old 02-02-2009, 05:24 PM   #12
BoostAddict712
Member#: 200983
08 STI
AW
Those #'s seem lower than what a stock STI puts down... am I wrong?
BoostAddict712 is offline   Reply With Quote
Old 02-02-2009, 08:27 PM   #13
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
i think a new stock sti puts down 215 on a dynojet..
BuggeyEYED is offline   Reply With Quote
Old 02-02-2009, 08:31 PM   #14
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
I saw somewhere here yesterday a stock STi putting up 215 whp and 260 wtq.
I did some research and my numbers are actually exactly 13% increase over stock. This is what Cobb claims as number increases for horsepower for their OTS Stage 2 map.
I will be making some changes very soon!
Old 02-03-2009, 10:28 AM   #15
turboge
Member#: 35076
2004 507whp Wagon
Here is what typical results are for my Stage 2. This is on 91oct and E85.
turboge is offline   Reply With Quote
Old 02-03-2009, 12:21 PM   #16
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
turboge - Are those numbers on your WRX!? If so, what the heck stage 2 do you have??? What do you have on there and what tune?
The 227 hp /340 tq is a reasonable for the WRX, but the ~260 hp and ~380 tq on stage 2???
Old 02-03-2009, 12:34 PM   #17
turboge
Member#: 35076
2004 507whp Wagon
This is on a customer car in Albuquerque. Numbers will be better at lower altitudes. Both tunes are the OTS XPT Stage 2 maps. Boost on the pump map was around 16 (altitude) and the E85 was 17psi. Both are designed to run about 1 to 1.5psi higher at sea level.
Old 02-03-2009, 12:44 PM   #18
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
dude... I'm in Miami, as close to sea level as you can get. Those numbers seem out of hand. I know the Cobb map is ultra conservative, but if there are tunes out there getting that dramatic of numbers it's definitely time to switch.
My WRX is using the Stage 2 93 tune and its doing exactly the numbers Cobb is advertising (13% hp increase)
Thanks for the feedback
Old 02-03-2009, 12:45 PM   #19
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
get a EBC (electronic boost controler) or MBC , Wideband and maybe an EGT and turn the boost up.
You are in FLA, the cobb ots maps are pretty leineint for sealevel.
Or not.
c'dalerider is offline   Reply With Quote
Old 02-03-2009, 08:55 PM   #20
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
^^^not sure if I'm ready for that yet... will probably do that when I go Stage 3+
Looking at getting a different map for now and maybe an intake
Old 02-03-2009, 09:36 PM   #21
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Satin White Pearl
That has got to an STI. No way you are getting those numbers out of an 08 WRX.
Dutchman1101 is offline   Reply With Quote
Old 02-03-2009, 09:44 PM   #22
Snow Drift
Member#: 75071
PR18 STI,PG15 XV Hyb
Past: 05, 08, 11 Red WRXs
Or not.
Uh, he has an AP, no need to use an EBC or MBC to adjust boost. Just get the thing protuned professionally.
Old 02-04-2009, 08:40 AM   #23
turboge
Member#: 35076
2004 507whp Wagon
Here is the Stage 1 STi in Comparison to the Stage 2 WRX.
Old 02-04-2009, 08:42 AM   #24
sam821
Member#: 177495
2011 WRX 5-dr
Dark Gray
^^^so the 258/286 is the WRX right?
Old 02-04-2009, 08:43 AM   #25
turboge
Member#: 35076
2004 507whp Wagon
No, thats the STi without tuning.
08 Stage 2 WRX Owners 08EJ25 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-17-2008 08:52 PM
Our first dyno day at the new shop! 5/31/08 Mach V Dan Mid Atlantic Impreza Club -- MAIC 15 05-22-2008 11:02 AM
Extremely hot day at the dyno, and all bodywork done! (swapped gc8) legacy2003 Member's Car Gallery 26 06-29-2007 12:56 PM
Cobb stage 2 STi run at the track turbo tecnica Proven Power Bragging 19 06-23-2006 08:18 AM
stage 2 06 sti on the dyno disillusioned Proven Power Bragging 11 05-15-2006 12:35 PM
