Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-09-2009, 08:26 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default 6spd swap - flywheel / clutch dust shield mod?
I wanted to see what you guys think about doing this:
Before cutting the bottom of the plate, I couldn't get the clutch plate on. Now it fits not problem and the shield doesn't look like it's gonna hit anything.
But I wanted to run this by you guys because if for some reason it doesn't work... I don't want to pull the tranny again to get to the shield to get it off.
What do you guys think?
Bad Noodle is offline   Reply With Quote
Old 02-10-2009, 06:50 AM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Morning bump...
I forgot to ask. Does this plate rest on the outside of the tranny? Meaning when I slide the 6mt in, I need to make sure that this plate isn't being bent inward towards the input shaft?
Old 02-10-2009, 07:25 AM   #3
bisonjr
Member#: 102714
Uh, at this point I would just swap it with an STi one. Once the tranny is on theres just about no going back. I bent mine out of the way when I did my swap and after about a week it started rubbing at weird times followed by all the time. Sounded like a steak knife factory under the car. It makes the kind of noise that makes your butt pucker up until you figure out whats going on. I had to go under the car twice with a prybar to bend the crap out of it. Much easier to swap it out now than deal with it later.
It fills in the cutout in the bottom of the tranny like it did on your 5mt. But the 6mt has a different shape/size.
bisonjr is offline   Reply With Quote
Old 02-10-2009, 07:49 AM   #4
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks. My other parts were shipped 3 days ago and I didn't feel like paying $10 shipping for a $8 part and delay the swap another week while I wait for everything to get here.
But I guess patience is key with these things
Old 02-10-2009, 08:57 AM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I just called some dealers and nobody withing a 50 mile radius has the part... so can I get away with mod or do I just need to wait for it to come in
Edit:
Do I really need this thing? I noticed in the master swap thread, the shop who installed the tranny just left this piece off.
Old 02-10-2009, 10:04 AM   #6
bisonjr
Member#: 102714
You can get away with it. Just make sure you have enough room. If that gets popped up it'll catch the clutch plate and will do some damage.
Old 02-10-2009, 10:16 AM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Good Point, I right now I have about 1/4" gap between the clutch bolts and the plate. I'll JBWeld a metal piece between the gaps to make sure that it doesn't flex while driving and hit anything. Thanks for the help.
Old 02-10-2009, 09:40 PM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Here's the solution I ended up going with:
STi swap done and runnig BUT clutch/flywheel dust shield issue NicFunkadelic Subaru Conversions 12 12-31-2018 12:08 AM
How many WRXs w/ STI 6spd using WRX flywheel/clutch? triguy Transmission (AT/MT) & Driveline 2 09-21-2007 05:35 PM
flywheel/clutch for swap MeshmeZ Subaru Conversions 7 05-08-2005 02:33 AM
Brake Dust Shield mods legal? MNbiker Motorsports 11 07-24-2003 01:41 PM
Flywheel/clutch -- Will the dealer replace with mods buymeasti Bay Area Impreza Club Forum -- BAIC 12 03-04-2003 10:52 AM
