Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Private Classifieds
Old 03-15-2009, 02:52 PM   #1
ASPENWRXstg4
Member Sales Rating: (1)
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars WTB: Egt Sensor
I need to buy a new or used EGT sensor and i had a question would me car temp gauge say the car is over heating if i pluged my after market uppipe egt hole with a bolt lmk thanks.
ASPENWRXstg4 is offline   Reply With Quote
Old 03-15-2009, 02:54 PM   #2
bhhamblin
Member Sales Rating: (35)
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
that EGT sensor has nothing to do with the temp gauge in the car. that all has to do with water temps. youll be fine plugging the hole in the uppipe but youll get a check engine light for it.
bhhamblin is offline   Reply With Quote
Old 03-15-2009, 02:57 PM   #3
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
but i won't lose boost then right because i installed the new gt 2 spec uppipe in my car plugged the hole with a bolt like alot of people do and no i barley have boost pressure and my temp gauge is of the chart.
Old 03-15-2009, 03:02 PM   #4
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
your water temp gauge is high? that doesnt have anything to do with your EGT temp? What gauge are you talking about.
Old 03-15-2009, 03:04 PM   #5
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
the stock temp gauge in the car is the one im talking about and im gona check all my gaskets because thats the only reason i could see the temp going up.
Old 03-15-2009, 03:12 PM   #6
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
Im pretty positive that the EGT sensor is not causing your over heating. EGT sensor is for exhaust gas temp. Have you checked to see if you have a bubble in the cooling system?
Old 03-15-2009, 03:14 PM   #7
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
how do u check for that?
Old 03-15-2009, 03:17 PM   #8
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
well first of all make sure you have enough coolant, maybe this will help
http://www.buzzle.com/editorials/6-28-2006-100752.asp
Old 03-15-2009, 03:20 PM   #9
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
thanks brody or however you spell ur name haha.
Old 03-15-2009, 03:26 PM   #10
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
you got it.
Old 03-15-2009, 04:10 PM   #11
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
so got a quesiton would my boost cut out or my motor whatever is freaking doing if the uppipe is plugged and if the header o2 is not working.
Old 03-15-2009, 04:13 PM   #12
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
Are you talking about the o2 sensor that is on the header? or the egt in the pipe? If the one in the header isnt plugged in it would probably cause your car to run like crap. It is the heated o2 sensor and thats the sensor that gets all the readings for air/ fuel.
Old 03-15-2009, 04:14 PM   #13
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
its plugged in but the wires got cut some how and im wondering if the car would cut out if the wires are cut.
Old 03-15-2009, 04:15 PM   #14
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
Yes, it would probably do that.
Old 03-15-2009, 04:17 PM   #15
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
**** do you know anyone who has a o2 or do u have one .
Old 03-15-2009, 04:19 PM   #16
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
nope i dont. but i know they are expensive. have you tried splicing the wires?
Old 03-15-2009, 04:20 PM   #17
ASPENWRXstg4
Member#: 192612
2003 WRX
ASPEN WHITE
Subaru Stars
like splicing the wires and hooking them back together i would try that but im not sure there is enough wire hanging off the o2.
Old 03-15-2009, 04:28 PM   #18
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
oh. well maybe give that a try.
WTB: EGT sensor for stock uppipe (can be non-functioning) SC WRX Private 'Wanted' Classifieds 1 05-18-2010 12:15 PM
WTB: EGT sensor/midpipe-downpipe springs/bolts. BrianH MWSOC Private Classifieds 6 04-14-2009 01:44 PM
WTB: EGT sensor of 02 wrx benbr84 Private 'Wanted' Classifieds 2 01-09-2008 05:37 AM
WTB: EGT sensor domestic_abuser Private 'Wanted' Classifieds 1 08-12-2007 10:53 AM
WTB: EGT Sensor wiring harness Twerthi Private 'Wanted' Classifieds 2 01-05-2005 05:05 PM
