04-06-2009, 04:31 PM | #1 |
Vendor Sales Rating: (18)
Member#: 149912
NWIC
Vehicle:06 EAT STi |
Zero/Sports High Quality Suspension + Brakes!
Call or email us for recommended alignment specs for the ZS Suspension! Zero/Sports High quality Stabilizer! If you are considering replacing your suspension, we recommend the stabilizer as a first step in suspension tuning. Zero/Sports Sway Bars will drastically reduce body roll without decreasing ride comfort. The Zero/Sports Sway Bars feature a unique lightweight tubular design. The hollow tube design gives the bars a stiffer response to twisting forces than a similar solid sway bar. These easy to install sway bars will improve handling, steering wheel response, and will reduce your cars natural tendency to under steer in corners. If you use a solid core structure stabilizer, we insist you try our product, you will definitely feel the difference! For maximum performance, we suggest using the front and rear as a set! Structure Front (Weight/Diameter) Rear (Weight/Diameter) Stock OEM Solid Core 2800g / 19mm 3200g/ 17mm Company A Solid Core 3900g/ 22mm 4300g/ 21mm Zero/Sports Hollow 1950g/ 23mm 2400g/ 23mm ·Light weight (2/3 less than stock) and high stiffness is achieved by cold drawn steel piping and the hollow structure! ·Totally different rotational stiffness compared to stabilizer with a solid core structure! ·Controlling rotations with sacrificing ride quality! ·Improved front Turing round with improved rear following capability! ·Highly compatible with Winning R and Winning S Coilovers! Torsion rigidity (comparison w/ Stock) Front 1.47 Rear1.72 MSRP - $390 Price - $370 Each Shipped Front/ Rear Set Price - $700 Shipped Front Sway Bar - 04-07 STi - ZS-0620021 Rear Sway Bar - 04-07 STi - ZS-0620010 Front Sway Bar - 02-07 WRX - ZS-0620009 Rear Sway Bar - 02-07 WRX - ZS-0620011 Front Sway Bar - 05+ Legacy GT - ZS-0620017 Rear Sway Bar - 05+ Legacy GT - ZS-0620018 __________________________________________________ __________ Ball Joint Extender The Zero/Sports Ball Joint extender is intended for use on a lowered Subaru WRX/STi. When you lower your car with springs or coilovers, you alter the vehicle’s suspension geometry out of its optimum range. The Zero/Sports extended ball joints help return the suspension geometry to its ideal position while still allowing you to lower your cars center of gravity. FITS - Subaru Impreza STi/WRX 02-08, Legacy GT, Forester XT MSRP - $350 Price - $329 Shipped __________________________________________________ __________Tie Rod Angle Adjusters These tie rods are mainly meant for cars that already have extended ball joints, like the Zero/Sports Roll Center Adjusters. When ball joint extenders are installed on their own, excessive bump steer can sometimes occur during hard cornering. Bump steer is the change in the toe angle of the wheels as the suspension travels up and down and a certain amount of this is normal. The Zero/Sports Tie Rods fix the excess bump steer sometimes caused by extended ball joints. This is accomplished by changing the angle of the tie rods so that a correct toe angle is maintained during high speed cornering. For the best performance possible, combine these tie rods with the Zero/Sports Ball Joint Extenders. FITS - Subaru Impreza STi/WRX 02-08, Legacy GT, Forester XT MSRP - $350 Price - $329 Shipped __________________________________________________ __________ PG Rear Strut Bar The Zero/Sports PG Rear Strut Bar is constructed from highly rigid aluminum with a hollow bar design. The strut bar attaches the rear left and right shock absorber towers together with a lightweight, yet stiff bar. Placing a bar between the two towers allows them to support each other during hard cornering, increasing the rigidity of the chassis and suspension system. FITS Subaru Impreza WRX/STi 02-07! MSRP - $2800 Price - $188 Shipped _______________________________________ Winning S Coilovers The Zero/Sports Winning S Coilovers were developed with the intent of combining ride quality with a road hugging, racing feel. To maintain ride quality, a reinforced rubber bushing was chosen for the top mount to reduce the stress induced on the body. Ground clearance for a daily driven car is important. With the adjustable height of these coilovers, ground clearance can be perfectly maintained with the recommended lowering height of 35mm. The dampening is 4-way adjustable and when combined with the springs rates of 6k front and 4k rear, can have a wide range of adjustment. Settings 1-2 will provider better ride quality while settings 3-4 should be used for higher stability when cornering and at high speeds. For the best suspension setup, combine the Winning S coil overs with a set of Zero/Sports Swaybars!
Spring rate - Front 6k/ Rear 4k Recommended lowering 35mm. *********** Easy 4-level adjustable dampening force 1-2 for high ride quality (The first level of damping force has a even softer initial input compared to the STi stock suspension.) 3-4 for high stability on winding road or high speed driving FITS Subaru Impreza WRX/STi 02-07! MSRP - $1850 Coilovers w/o upper Mounts - $1700 Shipped __________________________________________________ ______ Brake Pads! Zero/Sports brake pads are superior to the brake pads of other companies who specialize in brake systems for many vehicles due to the fact that Zero/Sports brake pads are designed and produced specifically for Subaru vehicles. Zero/Sports Brake Pads are offered in a variety of types for different applications and driving styles.These street pads were designed mainly for everyday street use. They were developed with the reduction of brake dust and squealing in mind, yet still provide a significant improvement in braking performance and resistance to brake fade over the factory brake pads. Zero/Sports Street Brake Pads are made of an asbestos-free compound with an optimal friction coefficient of 0.40 at rotor temperatures of 500 degrees Celsius. Street - The friction materials is slected based on the rotor temperature range fro street driving. Enjoyable street driving is acheieved though stable braking and high repsnonseivness to pedal touch. LOW DUST! Sport - Sport is brake pads for sport driving, which covers wide tempature range from street driving to braking on highways. Anti-fading and rididity, as well as controlability, are all outstanding. Curcuit - Curcuit is of omprved controllabity achieved though high firction coefficeient and an anti-fading property under high temperature condition. This was sepcifically delvelped for curcuit driving where hard braking performance is required. FITS - Subaru Impreza STi/WRX 98-08 Front Brake Pads Zero/Sports Street Front Brake Pads $141 Zero/Sports Sport Front Brake Pads $188 Zero/Sports Circuit Front Brake Pads $235 Rear Brake Pads Zero/Sports Street Rear Brake Pads $131 Zero/Sports Sport Rear Brake Pads $178 Zero/Sports Circuit Rear Brake Pads $225 Front and Rear Brake Pad Combo Zero/Sports Front and Rear Brake Pad Combination 5% OFF __________________________________________________ ____________ Zero/Sports Stainless steel brakelines - $253 __________________________________________________ __________ Zero/Sports 6-POT Brake Caliper Kit(Brake Pads and Rotors included) For when 4 piston brakes will just not do the job, Zero/Sports has developed a 6 Piston Brake Caliper Kit track use. Made of lightweight aluminum, the 6 Piston Brake kit will drastically increase braking power while substantially reducing the unsprung weight attached to the wheel hub. Each Zero/Sports 6 Piston Caliper weighs in at 7.5 pounds, that’s 2.5 pounds lighter than the 10 pound stock calipers.The special heat dissipation characteristics of the Zero/Sports ZP-B brake pad make it possible to reach extremely high temperatures without losing braking efficiency. The Zero/Sports ZP-B Brake Pads included with this kit are made of an asbestos-free ceramic-metallic compound with an optimal friction coefficient of 0.70 at rotor temperatures of 830 degrees Celsius. It is recommended that you use Zero/Sports Sport, Circuit or ZP-B Brake Pads with this kit for your rear brakes.This kit contains the brake calipers, brake pads, brake rotors, brake hoses, mounting brackets and bolts. This is everything you will need to install the caliper kit. FITS - Subaru Forester (SF,SG,XT), Subaru Impreza (GC8,STI,WRX), Subaru Legacy (GT) MSRP - $3759 Price - $3400 Shipped __________________________________________________ __________ Zero/Sports MySpace Coming Soon! www.myspace.com/ZeroSportsUSA Call, AIM, or PM any Questions Call Toll Free 1-866-451-2261 or PayPal - [email protected] Thank you for your business Anthony EAT Motorsports
__________________
[INDENT][INDENT][LEFT] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/LEFT] [/INDENT][/INDENT][INDENT][INDENT][COLOR=Blue][B][SIZE=3] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE] [COLOR=SlateGray]EAT Motorsports Kirkland, WA[/COLOR] [/B][/COLOR][/INDENT][/INDENT][INDENT][INDENT][LEFT][COLOR=Blue][I][SIZE=3][B]Toll Free 1-866-451-2261[/B][/SIZE][/I][/COLOR] [/LEFT] [/INDENT][/INDENT] |
04-09-2009, 11:05 AM | #2 |
Member Sales Rating: (15)
Member#: 113698
That brake setup looks schweet! I have never seen anyone running these and have been eying them for a while. Just need to find $3400. I probably don't need a 6 pot though. 4 would be plenty.
04-09-2009, 01:51 PM | #3 |
Member#: 149912
NWIC
6-POT FTW!
__________________
05-07-2009, 07:11 PM | #4 |
Member#: 149912
NWIC
__________________
06-16-2009, 08:51 PM | #5 |
Member#: 149912
NWIC
All Orders Shipped! Thank you!
__________________
08-10-2009, 08:30 PM | #6 |
Member#: 149912
NWIC
ZS Bump - New shipment due to arrive next week!
__________________
09-12-2009, 04:38 PM | #8 |
Member#: 149912
NWIC
Bumpers
__________________
09-28-2009, 03:24 PM | #9 |
Member#: 149912
NWIC
All Orders shipped, thank you for the support guys!
__________________
10-15-2009, 09:22 PM | #10 |
Member#: 149912
NWIC
Coilovers An easy set up unit that is full adjustable and with ride height adjustments, provides a drastic change in your driving. Recommended for drivers who... has experienced the front slipping on bumpy turn-ins. prefer your own setting for a reasonable price. want lower ride height without loss in suspension stroke. want to advance to adjustable rate units for a reasonable price. (Can upgrade to Zero 2 Coilovers at later time) Rubber Mount WRX 2002-2007 - 667 60E CN STi 2004 - 667 60E CN 2005-2007 - 672 60E CN Price $1650 Pillowball Mount WRX 2002-2007 - 667 60E CP STi 2004 - 667 60E CP 2005-2007 - 672 60E CP Price $1750 The 5 stage adjustable ride height version of the ZERO-1 allows adjustment for all stages for performance and ride comfort. A stainless steel body unit. Recommended for drivers who... want to lower the ride height without sacrificing the stroke length. want to enjoy various setting on road or track or weather conditions by adjusting the ride height, spring rate and pre-load setting to his heart's content. want to try various tires from the production supplied to the S tires. want to take the family or girl friend along on weekdays comfortably, but wants to challenge that pass or track on weekends. The 5 stage adjustable shock absorbers for more fun driving Stage 1 or 2 : for everyday city use Stage 3 or 4 : for high grip radial tires Stage 4 or 5 : for competition tires ECON Compatible Rubber Mount WRX 2002-2007 - 667 60M CN STi 2004 - 667 60M CN 2005-2007 - 672 60M CN Price $1895 Pillowball Mount WRX 2002-2007 - 667 60M CP STi 2004 - 667 60M CP 2005-2007 - 672 60M CP 2008+ - 667 60M CP Price $2025 Cusco's new electronic dampening controller will allow you to have full dampening control from the comfort of your seat. With a push of a button you can go from full soft to full hard. No more getting dirty trying to adjust the coilovers on your car when you go from the street to the track. Will only work on the Cusco Zero-2E Coilovers. ECON- 00B 60M 0 - $450 CUSCO's original oil through system. Inverted 5 stage adjustable shock absorber with low friction provides excellent driving and quality comfort. ZERO-2R is the top class equipment with... Lower unladen weight and higher rigidity made possible by the inverted shocks used on many cars competing in the World Rally Championship and All Japan GT Championship. Low friction allows a adaptable ride at any speed. A ride comfort not realized in previous inverted type shock absorbers. Oil circulation system allows a surprisingly low friction. Shock absorber performance at maximum from walking speeds. Rubber Mount WRX 2002-2007 - 667 60R CN STi 2004 - 667 60R CN 2005-2007 - 672 60R CN Price $2250 Pillowball Mount WRX 2002-2007 - 667 60R CP STi 2004 - 667 60R CP 2005-2007 - 672 60R CP Price $2375 ZERO 3/ ZERO 3 X *NEW* It's coil over kit which developed to make up time on 1/100, 1/1000 level. It has newly designed mono-tube shock absorber with 24 steps damping force adjustment (3way 24 steps damping force adjustment with reservoir for ZERO3X) Putting "Carrosser works technology" which has been built through long time experience on motorsport, this is flagship model item. Compare to traditional all round typed products (ZERO2R, ZERO2E) which are looking at usage on street to circuit (radial tire to S tire), ZERO3/3X's form with parts and setting specification are focus on sdriving at circuit with S Tire. Zero-3 (F/R) Inverted Coilover (12/10kgmm) GDB STI 05-07 672 63R CP $3,275.00 Zero-3X (F/R) Inverted Coilover (12/10kgmm) GDB STI 05-07 672 63X CP $5,110.00 *********** Zero-3 Front Inverted Coilover (12/14kgmm) GRB STI 08+ 692 63R CP $3,030.00 Zero-3X Front Inverted Coilover (12/14kgmm) GRB STI 08+ 692 63X CP $4,875.00 Shipping Lower 48 States Ground/Sea - 6-8 Weeks - Free! Air Mail from Japan - 2-3 weeks - $200 Sway Bars and Braces coming soon!
__________________
10-30-2009, 10:19 PM | #11 |
Member#: 149912
NWIC
__________________
11-02-2009, 01:46 AM | #12 |
Member Sales Rating: (1)
Member#: 115299
RMIC
Vehicle:MY01 2.5RS sedan stm |
I've always been interested in Z/S stuff. I did not know what kind of technology went into their swaybars and racing caliper- in the past I thought it was a nice 4 pot- so I'm drooling even more now. I really like their swaybars so I'll probably be replacing my Cusco bars in the future.
11-02-2009, 02:31 PM | #13 | |
Member#: 149912
NWIC
Sounds good, Let us know if you have any questions!
__________________
12-10-2009, 03:00 PM | #14 |
Member#: 149912
NWIC
Zs + Cusco Ftw
__________________
Zero/Sports Racing Suspension Setup | FatStraws | Suspension/Brakes/Handling | 6 | 07-18-2007 08:04 AM |
Zero sports High Performance turbo A/R18? | xCatch22x | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 06-12-2007 06:11 AM |
Zero sports High Performance turbo A/R18? | xCatch22x | Pre-2002 Factory Turbo Powertrain | 3 | 06-05-2007 03:06 PM |
Any one know about the quality of the zero sports replica wing | CrowbarKen | Interior & Exterior Modification | 9 | 08-01-2004 12:32 AM |
(PIC'S) 22B Bumpers, Zero Sports/Jun Body kits, Zero Sports Rep Carbon Fiber Spoilers | Revolutions Motorsports | Vendor 'For Sale' Classifieds | 86 | 08-19-2003 11:06 AM |
