Welcome to the North American Subaru Impreza Owners Club Sunday September 24, 2017
Old 04-14-2009, 07:20 PM   #1
map450
Member#: 197574
07 ebony princess
obp
Default injector question
hello all
right now my car is using helix 820cc injectors, what would the gains be if i switched to dw 850's instead? like would the difference be noticeable on the dyno
map450 is offline   Reply With Quote
Old 04-14-2009, 08:47 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Not worth it at all. If you switched without remapping, you'd go slower since you'd run 4% richer. Bigger injectors are so you can support more airflow/combustion. this small bump is nothing. People usually go up in increments of at least 200 and then remap
Fongers is offline   Reply With Quote
injector question NateDogg Normally Aspirated with bolt-on Forced Induction Powertrain 0 01-17-2002 02:12 AM
fuel injector question mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-26-2001 02:13 PM
R/C 440 Injector Question! adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-02-2001 06:53 PM
fuel injector questions mhj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-12-2001 10:36 PM
injector question WillReckXhop Normally Aspirated Powertrain 0 04-06-2001 10:47 PM
